Like Tree41Likes
Old 09-05-2016, 09:20 PM   #1081
Trader Rating: 31 (100%+)
you will want a FDR of 7.0 thus take the spur gear size and dived by pinion size then multiply by the IGR being 2.6
I not positive if you can use a spur smaller than 78t however I am not positive as I have not ran 13.5 in my YZ4 as of yet.
Norse is online now   Reply With Quote
Old 09-05-2016, 09:27 PM   #1082
Front belt does not need the top deck tensioner. Rear deck belt tensioner use 2 1mm shims thus drops the bearing a tad lower. The rear belt layshaft tensioner set at its lowest position. There is a nut on the backside that sits in a vertical channel that allows one to raise or lower the tensioner a bit. Use rear narrow belt and aluminum pulleys throughout. Set your slipper correct per the bite on the track.
Old 09-06-2016, 05:42 PM   #1083
Originally Posted by Deerek761 View Post
I need help with gearing 13.5 motor
80t spur gear with 29t to 30t pinion. 30t pinion with 80t spur will have your FDR just under 7.0 at 6.93. 29t pinion with 80t spur will have your FDR at 7.17.
Old 09-06-2016, 05:52 PM   #1084
Has anyone had a clicking sound coming from the drive train after a crash ?
Pulled it all apart last night and i can't find the culprit ? Belts don't seems to be rubbing on anything also
PENN01 is online now   Reply With Quote
Old 09-06-2016, 06:39 PM   #1085
Trader Rating: 24 (100%+)
Could be a Damaged Idler gear. Pull each belt and spin each gearbox feeling for roughness
Scott R is offline   Reply With Quote
Old 09-07-2016, 10:27 AM   #1086
Agreed as it could be an idler gear or a bearing if a bearing I would check these first (lay shaft bearings, top shaft bearings, or out drive bearings
Old 09-07-2016, 02:48 PM   #1087
Thumbs up
Thanks guys i will check all that out
Old 09-07-2016, 06:15 PM   #1088
I Definetly think it's beneficial to run better bearings in this wheeler. Especially the layshaft bearings, and all the gear box bearings. ACER sells a full set of ceramics for the YZ4 for $66 shipped. They are not rubber seals however I have had no issue with dirt dust and debri. I brush a light coating of dry gear fluid on the bearings side walls. It goes on wet but dry in 5 seconds leaving a white is colored dry polymer that seals the bearings against dust and debri. This product is also great for lubricating gears, bearings, cvd joints, hinge pins, ball studs, out drives etc as it is a dry powder polymer that is delivered via alcohol with quickly evaporates. You will want the dry gear fluid as the make 2 types with the dry gear being more concentrated with the dry polymer,
Kind of pricey however a bottle will last for a very long time,
Old 09-08-2016, 06:19 AM   #1089
Who makes the dry gear fluid?
Old 09-08-2016, 02:46 PM   #1090
Not positive, but I believe it is made in Germany. AMain carries it.
Old 09-08-2016, 02:47 PM   #1091
LOW ET's Avatar
Trader Rating: 97 (100%+)
is this it? https://www.amainhobbies.com/dryflui...arlube/p378093
LOW ET is offline   Reply With Quote
Old 09-08-2016, 07:38 PM   #1092
Originally Posted by LOW ET View Post
Hey Low ET that is it my friend. I have both the xtreme gear and the RC car. The extreme gear lube is more concentrated which I would recommend over their other. Shake vigoursly before using. Stuff works great.
Old 09-08-2016, 07:44 PM   #1093
I ran a track that was treated with a calcium compound in which after running one should clean all their alloy parts other wise major oxidation/rust occurs quickly. I did noy know about this calcium compound until weeks later. I took apart my 4 SCT and all the hinge pins were perfa which was do to previously brushing on the dry gear lube.
Old 09-09-2016, 05:05 PM   #1094
Derek you should be able to run a 75t spur with a 27t pinion with no issues as I just received word from a friend that they are running 74tspur with 27t pinion.
Both of the above combos set your FDR right around 7.0 give or tad a tiny tad, thus good to go.
Old 09-10-2016, 03:30 AM   #1095
revsinc's Avatar
Trader Rating: 15 (100%+)
whats your typical race weights ??
Full Speed , Half Price
revsinc is offline   Reply With Quote
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
