Like Tree37Likes
Old 08-15-2016, 09:08 PM   #1051
Send a message via AIM to Twotan
Thank you guys.
www.monarch-wheels.com
Magic Film's automotive car protection. Deals on the first 15 people.
Twotan is offline   Reply With Quote
Old 08-16-2016, 09:36 PM   #1052
SAMCRO's Avatar
I have the kit setup on this thing, what is the best way to free up the drive train? I have read about running the narrow rear pulley. Anything else?
SAMCRO is offline   Reply With Quote
Old 08-16-2016, 10:41 PM   #1053
drive it. They stretch.
scoobyrs25 is offline   Reply With Quote
Old 08-17-2016, 07:31 AM   #1054
Get rid of the front belt tensioner, it's not needed.
You can run slightly small dia bearings on the rear tensioner, and/or put an extra washer between it and the top deck.
X-Factory UK / Carisma Racing/ Corally/ Vampire Racing /TEKIN/ AVID/ JConcepts / Lunsford / Exotek Racing / Hiro Seiko / RDRP / GRP Tyres/ Tuning Haus/ DMSPARTZ / McKune/ RCS Graphic Workz / WTF / DMS Racing / Model Junction
John Myall is offline   Reply With Quote
Old 08-19-2016, 12:24 PM   #1055
Trader Rating: 31 (100%+)
+1 on Jonny's suggestions. I just recently went from using one 1mm spacer on the rear top deck tensioner to using two 1mm spacers. It made a huge difference. make sure the rear belt tensioner on layshaft bulkheads is at its loosest setting being all the way down.
Front tensioner is not needed however if you want it on just add a 1mm spacer.
I have heard people using a little Eureka pro lube their belts, thus rubbing a very little into the belts and letting sit for 1 to 2 hours, then wipe off any and all remaining residue. Its basically conditioning the belts.
Norse is offline   Reply With Quote
Old 08-20-2016, 08:17 AM   #1056
Panic09's Avatar
Guys I bought the Lunsford titanium quick change shock mounts but they are too thin - they don't fit properly in the plastics shock caps. Any idea how to mount them ?
"I was so far behind I thought I was first"
MIKES RC WORLD(r.i.p) | TACOMA RC RACEWAY | FOUR SEASONS RC RACEWAY(r.i.p) | ISLAND RACEWAY
Panic09 is offline   Reply With Quote
Old 08-20-2016, 02:49 PM   #1057
Did you use the kit plastic spacer ball things? If not, you need to.
Mine fitted really well, only downside I found was the posh alloy spacer ball things, don't fit over the threads.
Old 08-20-2016, 04:56 PM   #1058
Panic09's Avatar
Oh I see, tried to mount the aluminum ones too and wasn't working. I guess I ll try the plastic ones. Thanks for the help bud
Old 08-24-2016, 11:16 PM   #1059
Just out if curiosity has any one broke an outdrive on the the front diff after a decent hit ?
I did the other day and snapped it in half and thought maybe i just had a faulty one ?
PENN01 is offline   Reply With Quote
Old 08-25-2016, 12:14 AM   #1060
Not yet & I had a massive crash the other week, flat out into a car on a long straight, which managed to bend the front drive shaft.
Old 08-25-2016, 01:43 AM   #1061
Thanks John , I have never seen something like this so must not be a common thing so i guess i will not need to stock up on diff outdrives then
Old 08-25-2016, 01:47 AM   #1062
Does any one have any experience with the narrow rear belt drive set ? Does it really make a big difference in freeing up the drive train when running a 6.5t mod motor ?
Old 08-25-2016, 05:58 AM   #1063
I've got it on mine, never ran the car with the fat belt, but the narrow belt did feel better on the bench.
Old 08-26-2016, 01:03 AM   #1064
Thanks again , Might get it anyway as i intend to keep this car for a while as its that good to drive
Old 08-26-2016, 05:11 PM   #1065
Yes the narrow belt is great. Drop the rear upper tensioner for a total of 1.5mm to 2mm works wonders.
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
Triple A
