Like Tree15Likes
Old 08-05-2016, 04:19 PM   #1036
Trader Rating: 30 (100%+)
Originally Posted by carpetburner View Post
That's good news. My yz-4 has driven really good this summer in the loose stuff. I thought I saw a pic of lee martins yz-4 somewhere with dcj's on the front? Maybe he made something work off a bd7 or somethin....
The first DCJ tested on Lee's were Spec R XB4 front DCJ. I guess a lot of dremeling was required to make the work. DJ barrel was tight fight within the caster blocks.
Norse is offline   Reply With Quote
Old 08-05-2016, 07:21 PM   #1037
What is DCJ?
scoobyrs25 is offline   Reply With Quote
Old 08-05-2016, 10:03 PM   #1038
Double Cardane Joint Rotation is much smoother than your CVD, CVA, Swingshafts. Less chattering on turns, more responsive smoother turning, jumps and lands better plus better air control or I should say control in the air.
Old 08-05-2016, 10:20 PM   #1039
so I found these http://www.superiorhobbies.com/store...ing+Shaft++XB4 part #SBG-X11101 . I was about to order them but cant figure out if these are the front or rear ones. The pic makes them look like they are the longer front ones.. Do you happen to know how I can find the rear xb4 dcj?
Treasure Valley RC Eagle, Idaho
rc10b6 xb4 22sct3.0 rc8b3e
carpetburner is offline   Reply With Quote
Old 08-05-2016, 11:55 PM   #1040
kiwidave72's Avatar
Send a message via MSN to kiwidave72
Default shock pistons
can someone point me to what machined pistons you are all using?
Yokomo YZ-4 / Speedpassion 17.5. / Hobbywing v3 ESC
Yokomo BD7 / Speedpassion 13.5 v3. / Hobbywing v3 ESC
kiwidave72 is offline   Reply With Quote
Old 08-05-2016, 11:55 PM   #1041
kiwidave72's Avatar
I think you are look for fronts anyway....thats were all the moment is.
Old 08-06-2016, 12:06 AM   #1042
For front I run https://www.amainhobbies.com/vrp-12m...p2h1.6/p450902 and rear I run https://www.amainhobbies.com/vrp-12m...p2h1.7/p450903 .
Old 08-06-2016, 12:15 AM   #1043
I think the most common pistons people run are the yokomo Part# YOKBM-S162 front and Part# YOKBM-S172 rear . I like the vrp ones too though they work good in the dirt .
Old 08-06-2016, 08:10 AM   #1044
Definitely go with the VRP pistons. 1.6 front 1.7 rear is a great combo also the 1.3 for the rear is a great choice.
Old 08-06-2016, 08:15 AM   #1045
Rear XB4 DCJ are called ECS and are 68mm. For front DCJ wait for Yokomo to release as modifying SpecR XB4 is a pain and when modified they still are not optimal.
You will need the new rear hubs. 2 piece hub as the camber carrier can be flipped.
Old 08-06-2016, 08:17 AM   #1046
Those are fronts. SpecR only makes front DCJ for the XB4 at 81mm.
Old 08-06-2016, 08:19 AM   #1047
DCJ are normally more important in the front however having both front and rears in your wheeler is amazing. The difference is so noticeable.
Old 08-14-2016, 05:52 PM   #1048
Send a message via AIM to Twotan
What degree are the stock caster blocks?
www.monarch-wheels.com
Magic Film's automotive car protection. Deals on the first 15 people.
Twotan is offline   Reply With Quote
Old 08-14-2016, 06:02 PM   #1049
Regional Moderator
RobsRacin's Avatar
I believe 10 degree is stock but I could be wrong.
RobsRacin is offline   Reply With Quote
Old 08-15-2016, 12:40 AM   #1050
10 degree is stock.
matterooth is offline   Reply With Quote
