Like Tree15Likes
Old 07-05-2016, 01:34 PM   #1021
LOW ET's Avatar
Trader Rating: 95 (100%+)
Originally Posted by scoobyrs25 View Post
In-line, perfectly centered instead of offset. LMR and others sell parts for this, but the battery post is directly under the belt.
here's a couple pics to show how close it is. maybe 3mm of clearance.
LOW ET is offline   Reply With Quote
Old 07-06-2016, 04:21 AM   #1022
thanks!
scoobyrs25 is offline   Reply With Quote
Old 07-07-2016, 07:12 AM   #1023
Trader Rating: 30 (100%+)
Hey LOW ET, you are not using the top tesnsioners correct? If so how are the belts grabbing the pulleys and are you running mod, narrow rear pulley and belt? Also do you have the rear tensioner via below the layshaft set at its lowest point? I am assuming you run on lower bite conditions.
Thanks buddy
Norse is offline   Reply With Quote
Old 07-07-2016, 02:10 PM   #1024
LOW ET's Avatar
belt grabs just fine running mod with narrow rear pulley and belt. i set tensioners the way i feel the belts need to be set. maybe if the belts stretched out i would have to play with the tensioners but i'd probably just replace the belt for a tighter one, although i havent had this problem yet. i would say i run on high bite cuz i run on grass.
here's a pic of the belt setup. (the belt runs to close to the battery strap for my liking but it hasnt posed a problem yet)
Old 07-11-2016, 08:01 PM   #1025
Are you using stock sized tensioner bearings on the
Are you running stock sized bearings per the layshaft tensioners.
Old 07-12-2016, 03:22 AM   #1026
LOW ET's Avatar
yes
Old 07-12-2016, 10:39 AM   #1027
the incubus's Avatar
Trader Rating: 17 (100%+)
Yousah that's close. Some batteries have the connection port section taper down a bit lover than the rest of the battery which should provide more clearance should this ever be an issue for anyone.
ROB RIVERA
≈ PRS1 2014 :: SP Reventon Pro 1.1 :: Team Powers Plutonium17.5 ≈
≈ DEX410 :: SP Reventon Pro 1.1 :: Reedy Sonic 6.5T ≈
WWW.TRICOUNTYHOBBIES.COM :: WWW.CRPPLUS.COM
the incubus is offline   Reply With Quote
Old 07-28-2016, 04:19 PM   #1028
LOW ET's Avatar
i've changed lipos and my new one is about 1mm taller compared to the old one. i added the top rear belt tensioner (all tensioners at the loosest setting) to add more clearance and now there's tons of room. i'm sure no tensioner is needed with the taller lipo but you'd have to play with the wire and the angle it's soldered to the plug to get everything just perfect for the proper clearance. save time and do yourselves a favor and use the top rear tensioner.
Old 08-04-2016, 06:09 PM   #1029
Has anyone tried these new goodies https://www.amainhobbies.com/yokomo-...-415rs/p509096 ??. I was hoping for dcj axles but maybe these will be noticeable.
Treasure Valley RC Eagle, Idaho
rc10b6 xb4 22sct3.0 rc8b3e
carpetburner is offline   Reply With Quote
Old 08-04-2016, 10:33 PM   #1030
I have them on mine, I found the car went faster round my local track first time out with them. I can't say why they're better, the rear just feels nicer, without changing anything else.
X-Factory UK / Carisma Racing/ Corally/ Vampire Racing /TEKIN/ AVID/ JConcepts / Lunsford / Exotek Racing / Hiro Seiko / RDRP / GRP Tyres/ Tuning Haus/ DMSPARTZ / McKune/ RCS Graphic Workz / WTF / DMS Racing / Model Junction
John Myall is offline   Reply With Quote
Old 08-04-2016, 10:59 PM   #1031
That's good news. My yz-4 has driven really good this summer in the loose stuff. I thought I saw a pic of lee martins yz-4 somewhere with dcj's on the front? Maybe he made something work off a bd7 or somethin....
Old 08-05-2016, 07:40 AM   #1032
There are some dcj's coming for the YZ-4.
Think I saw somewhere, that it might be next month.
Bit annoying, since I just had to get some new fronts shafts, after a massive crash at the weekend & bent one. Found an upside down car on the straight at full speed, that no one had shouted out
Looooong straight + 5.0 Tekin, so going very fast
Old 08-05-2016, 03:44 PM   #1033
Yokomo is releasing DCJ fronts soon.
Old 08-05-2016, 03:48 PM   #1034
Yes, I have them and really improves the stability on the back end and really helps in rough bump conditions. Much better than the kit rear 62.5mmCVDs with long axle and spacer and hubs. I plan to put Yokomo front DCJ on and XRAY DCJ on the back as I don't think Yokomo is making rear DCJ at least they won't be releasing rears soon. I know Yok guys used Spec R XB4 front DCJ but needed to do a lot of dremeling to make work as the caster blocks are tad tight for free movement.
XB4 rear DCJ fit well on the YZ4 when using the new rear hubs. There about 1.25 mm longer than the new Yok 66.5mm. The tad extra length is not an issue.
Old 08-05-2016, 03:52 PM   #1035
Ran an 16 XB4 with DCJ front and back and do smooth. It's like having superior balance drive shafts that rotate so smooth and tightly. Jumping and landing is much easier.
