Like Tree36Likes
Old 05-31-2016, 08:37 PM   #991
SAMCRO's Avatar
What does running a narrow rear belt do? I saw a few setup sheets that reference that
SAMCRO is offline   Reply With Quote
Old 05-31-2016, 08:39 PM   #992
Trader Rating: 45 (100%+)
Makes the driveline a LOT freer.
Pro-Line/Protoform, HRP Distributing, PTRC Racing, Ho B Max
Antimullet is offline   Reply With Quote
Old 06-01-2016, 07:05 AM   #993
SAMCRO's Avatar
What degree are the kit front plastic caster blocks?
Old 06-01-2016, 07:11 AM   #994
10
matterooth is offline   Reply With Quote
Old 06-01-2016, 06:53 PM   #995
SAMCRO's Avatar
What does moving the shock to the front do on this car?
Old 06-01-2016, 10:00 PM   #996
It turns better for me with the shocks on the front and suits my driving style better. With the shocks on the back the car seems to over rotate on dirt . I also did not like the effect I got when I added 50 grams behind the battery. On carpet I did not notice as much of a difference.
Rc10b6 Kyosho tki4e YZ-4 sf ( < soon )
carpetburner is offline   Reply With Quote
Old 06-02-2016, 05:49 AM   #997
Trader Rating: 21 (100%+)
On dirt did you feel a difference in traction? With shocks forward?
AE B6
AE B64
kerby is offline   Reply With Quote
Old 06-02-2016, 07:14 AM   #998
I actually did not feel a loss of forward traction just more rotation on corner entry and less oversteer on exit wich is what I was looking for. I have found tire selection to be way more important than shock location . I am running holeshots up front with 3ds in back .
Old 06-03-2016, 10:22 AM   #999
Send a message via AIM to Bastos
Originally Posted by cracky1970 View Post
Heads up for those who run on dirt or clay tracks, I would buy extra front bumpers. I was going to run my car yesterday at OCRC and the car had drag like I've never experienced before. It felt like I had binding in the center mount section. I removed the belts to see where the binding was coming from, it was in the front transmission. I was in the process of removing the front trans, unscrewed the front bumper and removed it to get to the four screws that go into the transmission and what seemed like a hand full of dirt dropped out of the front transmission. I think the front bumper needs to be made out of a stronger material that wont wear out as fast.
Hello Cracky,
I have made mine in 3D, available in shapeways.
Some drivers were asking for it, with a better gear box seal and covering the front suspension mount.
I have made it in "normal" plastic or in Alumide ( Metallic plastic ).
I personally use the Alumide material ( painted with black tamiya spray TS-6 )...it is enough resistant.
The link to order ( sold by Pair ) :
http://shpws.me/MgCl
After 5 days of training on a track with big jumps.
https://www.facebook.com/BRCDesignYokomoFriendly/
https://www.shapeways.com/shops/brc_designer
Bastos is offline   Reply With Quote
Old 06-03-2016, 11:13 AM   #1000
Originally Posted by Bastos View Post
Hello Cracky,
Nice part... Is the stronger one $ 15.80 or $ 16.27 ?
Old 06-03-2016, 11:36 AM   #1001
Both are made with Alumide...the less expensive is not polished.
Old 06-07-2016, 01:40 AM   #1002
HSV427's Avatar
Trader Rating: 22 (96%+)
Originally Posted by jpcopeland1 View Post
YZ-4 is still going to be the more durable car. Since they fixed the front arms, I haven't broken, stripped, or wore out anything. The 22-4 is an awesome car, but will still be way more fragile due to thin belts, and a bad front arm design. A gear diff and thin belts only really works in on-road. Your asking a lot of those small belts with a 6.5, 5.5 motor is such a heavy car.
I see yokomo fixed the arm braking problem and was wondering did the part number stay the same or do the revised arms have a new part number. Thanks in advance.
Serpent 988, OS speed shimo edition, Serpent 977 35th anniversary. OS speed shimo edition Serpent 977 evo2, Novarossi Mito WC35 2017, Shepherd Velox, O.S Speed r2102, Motonica p81rs2, REDS Racing M7 WCS V3.0, , CM 1/8 INFINITY O.S Speed 2103.
HSV427 is offline   Reply With Quote
Old 06-07-2016, 02:15 AM   #1003
same part number . I have been running the same set for 4 months with brutal hits and no breakage .. thing is a tank .
Old 06-12-2016, 04:04 AM   #1004
Trader Rating: 138 (100%+)
Same since I switched the kit arms I got for a new set I ordered. Broke one, but I smacked HARD right into a brick wall at super high speed.
TLR 22T 3.0, 2X Yokomo YZ-2 DTM, YZ-4 SF (please hurry), Mugen MBX7R Eco, Hobbywing, Futaba, LRH Hobbies, Amain Hobbies, iCharger.
jpcopeland1 is offline   Reply With Quote
Old 06-14-2016, 03:45 PM   #1005
KrAcOn's Avatar
The part number may be the same but the arm is no longer flat. I got 3 sets that looked gull wing-ish. I sent a picture to A-Main and so they sent me another set... It was the same thing I already had..
So oh well I'm running them on the car.
AE:RC10B5ML,B5M,B4.2,B44.3,B3,RC10TeamRPM,Rc10T,RC10B64D
Yokomo:YZ-2 LD,YZ-2 DT,YZ-4 and MX4
LRH RACEWAY So. Cal
KrAcOn is offline   Reply With Quote
