Like Tree15Likes
Old 05-18-2016, 12:21 PM   #976
Trader Rating: 137 (100%+)
Originally Posted by thecman26 View Post
I am not gonna lie, these things sure look sexy!
I have a lot to think about before fall season comes around...
If I do get a wheeler it's looking like either a 22-4 2.0 or the YZ4...
YZ-4 is still going to be the more durable car. Since they fixed the front arms, I haven't broken, stripped, or wore out anything. The 22-4 is an awesome car, but will still be way more fragile due to thin belts, and a bad front arm design. A gear diff and thin belts only really works in on-road. Your asking a lot of those small belts with a 6.5, 5.5 motor is such a heavy car.
TLR 22T 3.0, TLR 22-4 2.0 , TLR 22 4.0 X2, 22SCT 3.0, Tekno SCT 4X4, Hobbywing, Futaba, LRH Hobbies, Spektrum Servos, iCharger.
jpcopeland1 is offline   Reply With Quote
Old 05-18-2016, 02:40 PM   #977
asalas's Avatar
Send a message via Skype™ to asalas
Default Belts
Guys,
When running mod is the rear narrow belt something one shouldn't use? I know it's a stock hopup for generating less drag but I just wanted to know what you think about it.
asalas is offline   Reply With Quote
Old 05-18-2016, 05:32 PM   #978
But the 22-4 splits its power among 3 belts instead of 2 so maybe that's why it doesn't need that thick of a belt? Either way the new Yokomo cars have definitely caught my interest.
CRF Pilot is offline   Reply With Quote
Old 05-18-2016, 08:51 PM   #979
Originally Posted by asalas View Post
Guys,
I got a 5.0 turn with 20/87 pinion/spur and the narrow belt holds up great. 2mm shim between topdeck and tensioner and loose setting on the tensioner bye the layshaft. Besides even the thin yokomo belt is about 2mm wider than the 22-4.
Treasure Valley RC Eagle, Idaho
rc10b6 xb4 22sct3.0 rc8b3e
carpetburner is offline   Reply With Quote
Old 05-18-2016, 08:59 PM   #980
The 22- 4 has problems with the front belt design .The 22-4 racers at my club break a lot of front arms .
Old 05-18-2016, 11:13 PM   #981
Guys,
I've been using it since release on super high grip astro turf with a 6.5 Tekin, no problems so far.
Running slightly smaller bearings on the tensioner, to reduce drag as well.
X-Factory UK / Carisma Racing/ Corally/ Vampire Racing /TEKIN/ AVID/ JConcepts / Lunsford / Exotek Racing / Hiro Seiko / RDRP / GRP Tyres/ Tuning Haus/ DMSPARTZ / McKune/ RCS Graphic Workz / WTF / DMS Racing / Model Junction
John Myall is offline   Reply With Quote
Old 05-18-2016, 11:15 PM   #982
I only snapped one front belt in the year I ran a 22-4 & that was possibly caused by a lot of heavy breaking on high grip astro, with the one-way locked.
Never broke a front arm, but they have changed them on the 2.0, to make them stronger. Still won't make me go back to one though
Old 05-19-2016, 05:07 AM   #983
thecman26's Avatar
Trader Rating: 98 (100%+)
I saw a 22-4 2.0 pretty much destroy every other 4wd but it's an upper eschelon driver though. There were xrays and hot bodies in attendance along with many old B44's... Pretty sure no Yokes. I've always been a belt wheeler guy from the XXX-4 G+ and XX-4 personally. I never did prefer the shaft drive wheelers. Would be nice to be able to run in a club race though, not much local turnouts unless big races. Looking hard at this one though!
Chris Keen: Viola, Kansas
Kyosho RZ6, TLR 22 3.0, TLR 4.0 SR (soon),& 22T 3.0
"I'm too drunk to taste this chicken!", Col. Sanders
thecman26 is offline   Reply With Quote
Old 05-23-2016, 01:44 AM   #984
asalas's Avatar
Thanks for the advice. Would you mind sharing your general esc settings for your 6.5? Timing, punch, drag brake, etc. I'm trying to doggie or a good base esc setup for my yz4.
Cheers
Old 05-23-2016, 05:10 AM   #985
Yeah, I notice a lot of people don't have a wheeler class which would suck for me since anything 4 wheel drive is my preferred drive train. on-road, off road 4 wheel is just so much more fun then 2 wheel. Drove the car this weekend, slapped a few pipes, rolled over a couple of times (after I had TQ'd wheeler, and wanted to push the buggy as far as I could). Ended up second after a bad start, lost by 2 seconds. Still very happy as I spazzed the start. Car is legit. Got a lot of compliments on how it looked compared to the other cars on the track.
Old 05-23-2016, 12:27 PM   #986
Cheers
This is what I got from Ellis Stafford when I changed over to Tekin last year;
"I'd start at about 20 on the boost and I set the top revs to 45000 and the start to about 11000. If you need more bottom end just drop the start revs down to 6000 or if this is still not enough then add more boost but anything above 30 and they are crazy fast. I don't run any turbo on mine normally."
He doesn't mention drag brake, but I'm pretty sure I'm not running any.
Old 05-23-2016, 06:28 PM   #987
SAMCRO's Avatar
Does this car have a center gear diff?
SAMCRO is offline   Reply With Quote
Old 05-23-2016, 06:53 PM   #988
Trader Rating: 21 (100%+)
Slipper
Kyosho Rb6.6
Kyosho ZX6.6
Kyosho Rt6
kerby is offline   Reply With Quote
Old 05-23-2016, 07:55 PM   #989
Car has natural drag brake due to the belt design. I don't know many people who run any drag brake on any 4 wheel drive.
Old 05-27-2016, 04:21 AM   #990
asalas's Avatar
Thanks so much, I'll take your advice on board.
