Like Tree15Likes
Old 03-14-2016, 04:47 AM   #916
Trader Rating: 21 (100%+)
Ended up using 1.5mm which stays put nicely. I agree a 1.2 isn't much a difference than running without
Kyosho Rb6.6
Kyosho ZX6.6
Kyosho Rt6
kerby is offline   Reply With Quote
Old 03-15-2016, 01:01 AM   #917
Originally Posted by jpcopeland1 View Post
I was wonder about mounting the swaybar on the back, but if its too short oh well, just kind of a pain to get to it. I doubt I will change much from 1.2 in the rear anyways. Car is a beast.
I was wondering if you had problems with the chamfered motor mount? The stock aluminum one is soft at the motor screw slots and amain does not list a non chamfered one. Just wondering what kind of hit it takes to knock the motor loose or bend it??
Treasure Valley RC Eagle, Idaho
rc10b6 xb4 22sct3.0 rc8b3e
carpetburner is offline   Reply With Quote
Old 03-15-2016, 07:07 AM   #918
Trader Rating: 137 (100%+)
Pretty decent hit into a wall. Spazzed out and hi the throttle instead of the brakes. If I had the right tools I could possibly try and knock it back into shape, but it's not a pricey upgrade. I'll stick with stock for awhile before I decide to try another upgraded motor mount.
TLR 22T 3.0, TLR 22-4 2.0 , TLR 22 4.0 X2, 22SCT 3.0, Tekno SCT 4X4, Hobbywing, Futaba, LRH Hobbies, Spektrum Servos, iCharger.
jpcopeland1 is offline   Reply With Quote
Old 03-16-2016, 12:38 AM   #919
I ended up with some thick washers on the motor screws to fix my problem . Now I need to get this new 3 disk slipper set so it transfers power smooth .
Old 03-23-2016, 11:50 AM   #920
Originally Posted by 2dialed View Post
graphite front arm flat +1mm z4-008f1
rear arm +1mm z4-008rl5
rear suspension mount front side for l5 arm z4-300lrf
rear suspension mount rear side for l5 arm z4-300lrr
aluminum rear suspension mount spacer (front side) z4-300rfs
aluminum rear suspension mount spacer (rear side) z4-300rrs
aluminum narrow pulley z4-630
aluminum pulley flange outside z4-630f3 inside z4-630fc
aluminum main shaft z4-644h
rear hard stabilizer set b4-412rh
5mm rear wheel hub b4-011r
these are some of the parts available from mibo but not amain
These can be achieved using ballstud washers no?
Old 03-23-2016, 05:30 PM   #921
amain has the YOKZ2-300RS . I sandwiched them and got 1.8mm under the hangers for low grip.
Old 03-24-2016, 07:32 AM   #922
amain has the YOKZ2-300RS . I sandwiched them and got 2mm under the hangers for low grip.
I figured there was another way. Still got the shims from Mibo, but in the meantime ballstud washers seem to work well.
Old 03-24-2016, 11:30 AM   #923
I did have to put some orings on the shock shaft to limit up travel . The arm would hit the outdrive on full compression without them. I stacked 3 of those 0.6 mm shims under both hangers and put a 0.2 mm shim on top of the rear hanger to compensate for the 2mm pastic spacer I removed between the trans and hanger. I wish their were some setup sheets listing the thickness in mm of the shims you got from mibo to use as a reference point .
Old 03-26-2016, 06:41 AM   #924
I plan on measuring them when I get them in, will share the info when I have it. From the pictures I saw on Mibos page they aren't that thick. I have one black shim under the under the RR suspension block (stock shim from kit), and 1mm between that block and the aluminum YZ-2 camber link, and the car is really good now, also ditched the sway bars, and dropped shock oil to 35/30 to eliminate traction roll on high grip smooth clay, car is a dart now. Definitely has that carpet driving feel now.
Old 03-27-2016, 09:06 AM   #925
anyone know if Z4-300SRF and z2-300rf are the same or what the difference is?
sealander is offline   Reply With Quote
Old 03-27-2016, 09:54 AM   #926
Im not sure there is any such part as Z4-300srf. The Z2-300srf however is a steel version of Z2-300rf.
Piles is offline   Reply With Quote
Old 03-27-2016, 05:59 PM   #927
asalas's Avatar
Send a message via Skype™ to asalas
Default Roll bars
Guys,
When building the antiroll bars; How deeply should the bar get into the metal ball ends before securing it with the grub screws? Also I would appreciate it if anybody could share some tips as to when and how to use the antiroll bars.
asalas is offline   Reply With Quote
Old 03-27-2016, 06:33 PM   #928
Originally Posted by asalas View Post
Guys,
I have mine set so that the bar is perpendicular to the link . The grub screw ends up grabbing about 3mm from the end of the bars . I copy driver setup sheets on http://site.petitrc.com/setup/yokomo...YokomoYZ4.html for bar thickness . Some are running piano wire on a local carpet track . I am gonna run without them this week on a loamy dirt track for more side bite .
Old 03-27-2016, 06:49 PM   #929
The yz2 and yz4 use the same rear/front hanger for the standard s4 arms . The rear/rear hanger YOKZ4-300SRR has different dimensions to match the yz4 chassis and Upper Arm Mount .
Old 03-27-2016, 07:34 PM   #930
thank you, that was what I was trying to figure out. looks like on some setups the standard braces are used with L arms to make it even wider.
