Like Tree41Likes
Old 03-01-2016, 01:13 AM   #886
cracky1970's Avatar
Default Diffs
Originally Posted by kerby View Post
Ball diffs? I'm new to Yokomo cars. Same as yz-2 diff !
They are both the same, ball diff or gear diff. Both cars come stock with the gear diff, the ball diff is a option part, so to speak.
cracky1970 is offline   Reply With Quote
Old 03-01-2016, 02:13 AM   #887
Originally Posted by cracky1970 View Post
Heads up for those who run on dirt or clay tracks, I would buy extra front bumpers. I was going to run my car yesterday at OCRC and the car had drag like I've never experienced before. It felt like I had binding in the center mount section. I removed the belts to see where the binding was coming from, it was in the front transmission. I was in the process of removing the front trans, unscrewed the front bumper and removed it to get to the four screws that go into the transmission and what seemed like a hand full of dirt dropped out of the front transmission. I think the front bumper needs to be made out of a stronger material that wont wear out as fast.
At least he looks happy
株式会社 ヨコモ
dennisV is offline   Reply With Quote
Old 03-03-2016, 03:51 PM   #888
Trader Rating: 21 (100%+)
Any other options for the front hinge pin holder?
AE B6
AE B64
kerby is offline   Reply With Quote
Old 03-04-2016, 12:19 AM   #889
cracky1970's Avatar
Not that I know of at the moment.
Old 03-06-2016, 01:09 PM   #890
All I know of is a spacer for it to mount lower by 1mm
Quietman is offline   Reply With Quote
Old 03-06-2016, 05:59 PM   #891
is front ride height measured from the hinge pin holder or back where the kickup starts, ive never seen a car before where the hinge pin holder is mounted under the chassis
2dialed is offline   Reply With Quote
Old 03-06-2016, 08:37 PM   #892
cracky1970's Avatar
I measure ride height where the kick up starts.
Old 03-07-2016, 08:43 AM   #893
Trader Rating: 138 (100%+)
Originally Posted by John Myall View Post
I had the same thing happen in one run on Sunday. I'm pretty sure I hadn't hit anything hard, but the lipo was all the way forward after the run.
I've just bought a new set of holders for now, as I probably won't by running the lipo all the way back when the track is drier.
You could always drill a hole in the carbon battery strap & use a nut & screw to stop the lipo moving.
servo tape in your battery, just a little on each end of the lipo works perfectly.
TLR 22T 3.0, 2X Yokomo YZ-2 DTM, YZ-4 SF (please hurry), Mugen MBX7R Eco, Hobbywing, Futaba, LRH Hobbies, Amain Hobbies, iCharger.
jpcopeland1 is offline   Reply With Quote
Old 03-07-2016, 12:32 PM   #894
That'll get really boring doing it every time you change battery though.
X-Factory UK / Carisma Racing/ Corally/ Vampire Racing /TEKIN/ AVID/ JConcepts / Lunsford / Exotek Racing / Hiro Seiko / RDRP / GRP Tyres/ Tuning Haus/ DMSPARTZ / McKune/ RCS Graphic Workz / WTF / DMS Racing / Model Junction
John Myall is online now   Reply With Quote
Old 03-08-2016, 11:12 AM   #895
I don't change batteries. Never had a problem. I charge safely.
Old 03-08-2016, 11:34 AM   #896
For those that need a starting point for med-high bite clay, here is a set-up sheet for my car. It should be a good start. Please fell free to let me know if you make any changes that will make it better so I can try it myself.
Attachment 1348177
Hey cracky: Why are you limiting up travel by 2mm? Just curious. Mine seems fine at stock, at LRH.
Old 03-08-2016, 12:19 PM   #897
hi john, I've moved to Oroville and been running at amains outback track.... super hooked clay pretty much everyone running primes but still miss running at lrh. I limit up travel to keep the dogbones from hitting the outdrives. i'm using the plastic shock towers and flat front arms, mostly stock with the roll bars and narrow rear belt. I've only had the car a week or so still trying different stuff but for me I need more pack in the rear how they get 1.7 to work I dunno
Old 03-08-2016, 12:56 PM   #898
I've never had a problem with a lipo, but over here in the UK, we have to charge in a lipo sack at race meetings, if not, we're invited to go home.
Old 03-08-2016, 11:11 PM   #899
when will the longer f1 and l5 arms be available to buy in the US?
sealander is offline   Reply With Quote
Old 03-09-2016, 01:07 AM   #900
How should anyone know that? Ask your Yokomo dealer.
株式会社 ヨコモ
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
John Myall
