Like Tree41Likes
Old 02-15-2016, 05:27 PM   #856
Just ordered this kit today. Was wondering when you order the aluminum rear hangers can you use the stock a arms and can you use z4-008rs4 and what is the difference between the two?
turtle189 is offline   Reply With Quote
Old 02-15-2016, 05:32 PM   #857
LOW ET's Avatar
Trader Rating: 97 (100%+)
z4-008rs4 is the stock arm
LOW ET is online now   Reply With Quote
Old 02-15-2016, 05:39 PM   #858
Right my bad z2-008 was the other one from the yz2 I know it's listed on amain as a yz4 a arm so it fits right on nothing else needed?
Old 02-15-2016, 05:42 PM   #859
LOW ET's Avatar
not sure about the fit but from my understanding
z2-008 = 1mm shorter length
z4-008rs4 = stock
z4-008rl5 = 1mm longer length (takes different suspension blocks)
Old 02-15-2016, 05:50 PM   #860
z4-008rs4 = stock
Ok thanks.
Old 02-15-2016, 05:53 PM   #861
LOW ET's Avatar
i was reading that they use the z2 arm on clay tracks to narrow up the rear for better bite and use the l5 long arms on carpet/turf. im sure they all work, just have to adjust the setup accordingly.
Old 02-15-2016, 06:34 PM   #862
asalas's Avatar
Send a message via Skype™ to asalas
Default hmm
Originally Posted by Piles View Post
Why would you centre the battery? Are you having issues? I thought the battery is offset to compensate for the motor and servo. With the battery off set you get a perfect L/R balance.
How could you know that having the battery on the opposite side of where the motor is achieves perfect L/R balance? By what one can see with the naked eye it may look like that but, Has anybody actually used a scale and done the maths for this? I mean unless you managed to precisely calculate the weight of all the electronics and parts your buggy has on each side...
Marc Rheinard was using it centered: http://eos.redrc.net/2016/01/chassis...marc-rheinard/
Lee Martin had it opposite to the motor but with what looks like added weight on the left side of the battery: http://eos.redrc.net/2015/11/chassis...-lee-martin-8/
What are your opinions gents?
Adolfo Salas
asalas is offline   Reply With Quote
Old 02-15-2016, 10:55 PM   #863
Send a message via AIM to Bastos
Originally Posted by Bastos View Post
The link to shapeways :
http://shpws.me/LzTY
Picture from FB "Yokomo YZ-2 & YZ-4" - Post of Eirik Andreassen.
The car is well balance like this, that's why I have made this battery rack.No more weight to set the position of the shorty.
On the Front Left - Read 392gr.
https://www.shapeways.com/shops/brc_designer
https://www.facebook.com/BRCDesignYokomoFriendly/
Bastos is offline   Reply With Quote
Old 02-16-2016, 12:13 PM   #864
asalas's Avatar
I think he added extra weight with those little black blocks next to the battery (1on the motor side and 2 on the opposite side)??
Old 02-16-2016, 01:05 PM   #865
Trader Rating: 138 (100%+)
Build it, run it, tweak it to your liking.
TLR 22T 3.0, 2X Yokomo YZ-2 DTM, YZ-4 SF (please hurry), Mugen MBX7R Eco, Hobbywing, Futaba, LRH Hobbies, Amain Hobbies, iCharger.
jpcopeland1 is offline   Reply With Quote
Old 02-16-2016, 06:15 PM   #866
I was having a Issue with Rear end stepping out I put diff balls front and back plus I looked at marc Reinhart And lee's car they both look like they raise their transmission and Rear camber link up 2 mills from the pictures. I'm still working on the set up I got most of the rear locked in.
legg.j is offline   Reply With Quote
Old 02-17-2016, 02:19 AM   #867
Not sure they raise the transmission...the blue shims you have seen on the photos exist yet in plastic shim in one
Piece.
If they raise the Rear transmission they have to raise all, including the top deck...and it is not the case...
Old 02-17-2016, 03:21 AM   #868
Eirik's Avatar
That is correct, I put 2 x 5gr weights on the right side and 1 x 5gr on the left side, it was an easy way to secure the battery trackside.
Innline centered battery is only recomended for very high bite carpet etc. it takes away chassis roll and makes the car less edgy on this surface.
For dirt I would have run the battery sideways for more sidebite.
Eirik is offline   Reply With Quote
Old 02-17-2016, 11:16 AM   #869
Just got a email yesterday from place I ordered my kit it's outta stock. Bummed out was a great deal. Anyone know where else I can pick one up at a good price close to what rc market had them on for?
Old 02-17-2016, 11:45 AM   #870
Trader Rating: 31 (100%+)
Possibly try Race Drift Japan. They had some killer deals back when the kit was first released, which I believe at that time on could purchase a kit for under $350 thus included 3-5 day shipping to the US. I would highly doubt if they had prices that low but it is worth a try. Tim at Race Drift Japan is a super nice fella.
Norse is offline   Reply With Quote
