Like Tree26Likes
Old 02-14-2016, 03:28 PM   #841
cracky1970's Avatar
Default Med-high bite clay
For those that need a starting point for med-high bite clay, here is a set-up sheet for my car. It should be a good start. Please fell free to let me know if you make any changes that will make it better so I can try it myself.
cracky1970 is offline   Reply With Quote
Old 02-14-2016, 04:21 PM   #842
asalas's Avatar
Send a message via Skype™ to asalas
Originally Posted by DBL15 View Post
69/35 on mine works good comes off at 60 deg C after 7 to 8 mins
You won't fit smaller then a 34 cause you can't move motor over far enough.
You could use a 72 tooth though
Hi,
I have just fitted a 69/35 combo, just like yours. Do you get good top speed? What diff oil are you using?
It just seems to me that my 2wd (its a durango dex210) buggy (69/34 combo) has more punch and top speed than my YZ4.
This may be a very noob/stupid question but should I expect my yz4 to have less punch and top speed than my 2wd buggy? maybe because my 2wd is lighter than my 4wd? I have both running a 17.5 with the same end-bell and esc setup.
Adolfo Salas
asalas is offline   Reply With Quote
Old 02-14-2016, 04:56 PM   #843
OriginalDonk's Avatar
Trader Rating: 41 (100%+)
The YZ-4 does weigh more than your YZ-2 but what's having a greater impact here is the fact that your YZ-2 has the motor, spur gear, and 4 gears in the transmission transferring power to the outdrives.
In the YZ-4 you've got two transmissions and two belts increasing the rotating mass and drag in the drive system. Things may free up a bit as you run the car. Some people swear by shaft driven cars for 17.5 and 13.5 cars because you've got fewer places to accumulate drag.
Sounds like a few people are running the YZ-4 in 17.5 successfully. There's definitely enough motor in modified to overcome any issues with drivetrain drag.
Carn the Tiges!
OriginalDonk is offline   Reply With Quote
Old 02-14-2016, 10:10 PM   #844
KrAcOn's Avatar
Attachment 1348177
I only stock AE oil. What would the 450 translate to? 35w?
AE:RC10B5ML,B5M,B4.2,B44.3,B3,RC10TeamRPM,Rc10T,RC10B64D
Yokomo:YZ-2 LD,YZ-2 DT,YZ-4 and MX4
LRH RACEWAY So. Cal
KrAcOn is offline   Reply With Quote
Old 02-14-2016, 11:51 PM   #845
cracky1970's Avatar
I believe so. I'm using the Yokomo brand oil, 450 cst.
Old 02-15-2016, 06:28 AM   #846
Doesn't Associated quote cst ratings on their bottles?
X-Factory UK / Carisma Racing/ Corally/ Vampire Racing /TEKIN/ AVID/ JConcepts / Lunsford / Exotek Racing / Hiro Seiko / RDRP / GRP Tyres/ Tuning Haus/ DMSPARTZ / McKune/ RCS Graphic Workz / WTF / DMS Racing / Model Junction
John Myall is offline   Reply With Quote
Old 02-15-2016, 06:40 AM   #847
Originally Posted by LOW ET View Post
a few quick part # questions:
is the part # for the aluminum suspension bracket #z4-300rf or #z2-300rf?
when you use the above bracket along with part #z4-300srr, we need to use #b4-300b bushings?
will we need to use spacers #z4-300rfs and #z4-300rrs when using the above suspension brackets?
thanks for any info
I am planning on changing my setup to run on a low bite dirt track. I have 2 bags of the YOKZ2-300RS spacers . I also picked up the YOKZ4-300SRR and YOKZ2-300RF mounts and the bushings . I am trying to figure out how to copy shins low traction clay setup sheet as he has listed 2 black spacers above the mount and 1 black and 1 brown below the YOKZ4-300SRR mount . Wondering if it can be done with the $3 spacers instead of the $30 Z4-300RFS and Z4-300RRS spacers ?
Rc10b6 Kyosho tki4e
carpetburner is offline   Reply With Quote
Old 02-15-2016, 07:22 AM   #848
Trader Rating: 30 (100%+)
Should be able to do so.
Norse is offline   Reply With Quote
Old 02-15-2016, 07:48 AM   #849
This may help:
http://site.petitrc.com/reglages/OilChart.pdf
Piles is offline   Reply With Quote
Old 02-15-2016, 11:01 AM   #850
Does anyone know if they aluminum hangers come with inserts?
turtle189 is offline   Reply With Quote
Old 02-15-2016, 11:56 AM   #851
Send a message via AIM to Bastos
Default YZ2/YZ4 Rear shock tower Mod'
Hi Yok Drivers,
For YZ2/4 owners, I have design a New part : "Shock Tower Spacer" ( for both YZ4 and YZ2 ) - Printed part.
You can install the rear shock tower on the back of the car, behind the shocks.( Screws length needed : 42mm & 26mm )
That make the cars more easy to drive and give more traction.
https://www.shapeways.com/shops/brc_designer
The link SHAPEWAYS to order :
http://shpws.me/Lqsr
Bastos is offline   Reply With Quote
Old 02-15-2016, 12:00 PM   #852
Another 3D part for your YZ4, to get your Shorty on the length and centered.
Great to get a good balance Left & Right with the shorty on the length.
(Screws length needed : 6mm )
The link to shapeways :
http://shpws.me/LzTY
Bastos
Old 02-15-2016, 12:00 PM   #853
The hangers do not come with inserts . The part # for the inserts is YOKB4-300B .
Rc10b6 Kyosho tki4e
Old 02-15-2016, 12:29 PM   #854
Old 02-15-2016, 03:08 PM   #855
Bastos
Why would you centre the battery? Are you having issues? I thought the battery is offset to compensate for the motor and servo. With the battery off set you get a perfect L/R balance.
