Like Tree15Likes
Old 02-08-2016, 11:43 PM   #826
cracky1970's Avatar
Originally Posted by OriginalDonk View Post
He did win one of the 4wd rounds at the Reedy Race. Hoping that's enough of a "win" to get him to post it.
Maybe somebody can lean on them. Lee, Marc, Shin, or Carson could share and help us out a bit here in the land of the TLR 22-4.
There was a couple of pics I saw on Facebook of Lee's car and Carson's car. Lee was running the kit shock towers and Carson was running the carbon towers, that all I could get from the pics.
cracky1970 is offline   Reply With Quote
Old 02-09-2016, 08:41 AM   #827
KrAcOn's Avatar
We have seen plenty of pictures but that doesn't tell you the full setup sheet. You can only guess from the pics.
AE:RC10B5ML,B5M,B4.2,B44.3,B3,RC10TeamRPM,Rc10T,RC10B64D
Yokomo:YZ-2 LD,YZ-2 DT,YZ-4 and MX4
LRH RACEWAY So. Cal
KrAcOn is offline   Reply With Quote
Old 02-09-2016, 10:09 AM   #828
cracky1970's Avatar
It seems like the guys that are sponsored, maybe besides Carson, run the car on carpet/astro/wood surfaces more than dirt or clay hence more setup sheets for the non clay surface. There seems to be more setup sheets for the YZ-2 for clay than the YZ-4. The setups for the Reedy Race might not be good for them but they might be good for someone else who runs on clay.
Old 02-09-2016, 01:27 PM   #829
OriginalDonk's Avatar
Trader Rating: 38 (100%+)
I posted these pics on the Facebook group. Looks like Carson was running the carbon towers and plastic shock caps while Lee was running plastic towers and aluminum shock caps. Two ways to get some more forgiving flex up front.
I sure would like to see the rest of the setups to see where each of them landed in terms of springs, diff oil, shock oil, and inserts/pills.
Yokomo YZ-4-12514058_10156424379685291_7877516281661555092_o.jpg   Yokomo YZ-4-12525366_10156421895800291_6702480344481591903_o.jpg
OriginalDonk is offline   Reply With Quote
Old 02-10-2016, 12:49 AM   #830
cracky1970's Avatar
I'm with you on that. The other thing I remember Carson saying, he was running ball diffs front and rear.
Old 02-11-2016, 03:06 PM   #831
Alright fellas, I am trying to use the Petitrc editable sheet for the YZ-4. I can open the page but its not editable on I-pad or laptop. Im not very computer savy, so do I need a specific program already on my lap top to make it editable?
Piles is offline   Reply With Quote
Old 02-11-2016, 03:34 PM   #832
asalas's Avatar
Send a message via Skype™ to asalas
Just download Adobe reader DC. https://get.adobe.com/reader/
it allows you to fill in the interactive fields.
Adolfo Salas
asalas is offline   Reply With Quote
Old 02-12-2016, 01:45 AM   #833
Thanks for that, Im a bit of a numpty when it comes to computers. Managed to get it to work even on my Iphone now.
Old 02-12-2016, 07:18 AM   #834
Apart from being shiny what do the Ali shock caps offer???
Quietman is offline   Reply With Quote
Old 02-12-2016, 07:28 AM   #835
jordan860's Avatar
Anybody feeling any difference between the 12 and 15 degree casters?
TEAM MADNESS
jordan860 is offline   Reply With Quote
Old 02-12-2016, 09:02 AM   #836
Trader Rating: 24 (100%+)
There aren't any significant benefits other than they look great and are made from aluminum. A yokomo rep once said the fins are supposed to act as heat sinks but they don't really. I've heard one guy complain they leak where his plastic one did not, but there could be other factors at play. The only real benefit is the bleeder screw not stripping like in the plastic caps.
newob is offline   Reply With Quote
Old 02-12-2016, 07:15 PM   #837
Nolan Farmer's Avatar
Yes, I have tried all four angles. The 15's were a bit too slow steering I thought on the high grip clay we run. The car was a bit too relaxed, I went to the 12.5's and my lap times came up. I may go back to test the tens next with our new layout with more hairpin turns.
Nolan Farmer is offline   Reply With Quote
Old 02-13-2016, 03:19 AM   #838
ralphee's Avatar
Play with the front kick up too, im using 12.5 blocks and 2.5 inserts, that feels very nice on carpet, which we run a control Venom tyre, which has way less grip than say a Minipin, so it helps balance the handling out a bit by transferring some weight to the rear.
Lee
ralphee is offline   Reply With Quote
Old 02-13-2016, 04:35 AM   #839
jordan860's Avatar
Thanks for the help I guess I'm going to start with the 12.5's
TEAM MADNESS
Old 02-13-2016, 05:51 AM   #840
Default yz4
I tried everything on this car to make the rear end lock in its pissing me off. I race on pack clay I can tell that this car is made for high grip because if they wet the track before we run its super dialed after it dry a little it's back to fight to get the rear locked in again. I even went down to losi 25wt. With green springs now that soft. Went from to 32.5 in the rear still the same thing. I look at Mark Reinhart setup He had pictures of his car it looks like he had spacers under the rear transmission I'm not for sure at the last race in January 2016 can somebody please look and check it out
legg.j is offline   Reply With Quote
