Like Tree15Likes
Old 01-21-2016, 09:43 AM   #766
trf415msx's Avatar
Trader Rating: 14 (100%+)
Thumbs up
Originally Posted by joeymdz View Post
mines the same
In the front they have2 of belt tensioner no way it will hit the motor at least you didn't put belt tensioner the one in the back
trf415msx is offline   Reply With Quote
Old 01-21-2016, 03:53 PM   #767
LOW ET's Avatar
Trader Rating: 95 (100%+)
just got my first order from http://www.rc-race-and-drift-japan.com/
everything went smooth and only took a few days to get. buy with confidence!
LOW ET is offline   Reply With Quote
Old 01-21-2016, 08:20 PM   #768
The belt seems to ride on the casting were the bearing on the motor is.
Also ended up dremeling the chassis were the back of the motor is as it was hitting on the bottom preventing the chassis from flexing .
Treasure Valley RC Eagle, Idaho
rc10b6 xb4 22sct3.0 rc8b3e
carpetburner is offline   Reply With Quote
Old 01-22-2016, 08:27 AM   #769
Trader Rating: 24 (100%+)
mines the same
ditto
newob is offline   Reply With Quote
Old 01-22-2016, 10:17 AM   #770
just a heads up, amain has a bunch of new alu option parts and more in link
Old 01-22-2016, 11:42 AM   #771
Trader Rating: 42 (100%+)
Originally Posted by newob View Post
just a heads u p, amain has a bunch of new alu option parts and more in link
Thanks for the heads up!
I still wonder why they don't sell the aluminum pulley and flanges to replace the front clicker though? Everywhere else overseas that sells the stuff sells those parts individually.
Aaron Moore
Serpent America/Desoto Racing, McFactory Motorsports, Team Trinity, Pro-Line/Protoform, Hobbywing North America/FalconSEKIDO, HRP Distributing, PTRC Racing, Ho B Max
Antimullet is offline   Reply With Quote
Old 01-22-2016, 02:21 PM   #772
DBL15's Avatar
Is anyone else having trouble with there shorty holders not holding the lipo in and allowing it to move during a run ?
I run my lipo across the back side ways but the lipo holder bracket tabs fold or bend and allow the lipo to move
Any thoughts ?
C/O Coast2coastrc (www.coast2coastrc.com.au) SMC Lipo
Tekno Rc , Team Tekin , Panther-Rc , De Racing , Upgrade Rc , Team Triton rc , M2C clutches , Nitro X fuels
DBL15 is offline   Reply With Quote
Old 01-23-2016, 12:51 AM   #773
I e-mailed a-mains sales department about that pulley . They replied back and said they have several parts on special order from yokomo that they have been waiting for . Seems like they are adding a part or two every other week .
Old 01-23-2016, 04:28 AM   #774
Any thoughts ?
I had the same thing happen in one run on Sunday. I'm pretty sure I hadn't hit anything hard, but the lipo was all the way forward after the run.
I've just bought a new set of holders for now, as I probably won't by running the lipo all the way back when the track is drier.
You could always drill a hole in the carbon battery strap & use a nut & screw to stop the lipo moving.
X-Factory UK / Carisma Racing/ Corally/ Vampire Racing /TEKIN/ AVID/ JConcepts / Lunsford / Exotek Racing / Hiro Seiko / RDRP / GRP Tyres/ Tuning Haus/ DMSPARTZ / McKune/ RCS Graphic Workz / WTF / DMS Racing / Model Junction
John Myall is offline   Reply With Quote
Old 01-23-2016, 08:19 PM   #775
Thanks for the info!
Aaron Moore
Old 01-24-2016, 05:13 PM   #776
asalas's Avatar
Send a message via Skype™ to asalas
Default 17.5 gearing
Hi guys,
What gearing combo are the 17.5 stock guys using?
I tried fitting a 69 spur and a 32 pinion but due to the spur shaft and motor holder design the gears wouldn't even touch each other. I moved the motor as close as possible to the spur but it was still too far away.
What is the lowest FDR spur/pinion combination for 17.5 one can use in this buggy?
Adolfo Salas
asalas is offline   Reply With Quote
Old 01-25-2016, 01:11 AM   #777
Default Should i replace the shaft to belt
Hi Guys
i have B-max 4iii and i love it, i race on a dirt tracks.
Now seems that our local track decided to change to turf.
should i replace the B-max shaft drive to YZ-4 belt drive?
i heard belt are good for turf...
thanks
Yokomo bmax4 iii, RC8B3e, AE b4.1
Orion 6.5T, Orion 1950 KV, HK 8.5T, LRP/Orion ESC, futaba 4pl, Savox
kavee is offline   Reply With Quote
Old 01-25-2016, 11:00 PM   #778
DBL15's Avatar
Originally Posted by asalas View Post
Hi guys,
69/35 on mine works good comes off at 60 deg C after 7 to 8 mins
You won't fit smaller then a 34 cause you can't move motor over far enough.
You could use a 72 tooth though
Old 01-25-2016, 11:47 PM   #779
cracky1970's Avatar
I have 2mm gap or so between the motor and belt, the motor sits up off of the chassis, I don't know if your motor mount is bent or not spaced rite.
cracky1970 is offline   Reply With Quote
Old 01-26-2016, 04:35 AM   #780
I unscrewed the top deck , motor mount and layshaft and was able to reposition the motor mount to get the clearance . It really freed up the drivetrain . Thanks for your help .
