Like Tree15Likes
Old 01-08-2016, 12:11 AM   #706
cracky1970's Avatar
Any body looking for the longer shock ends, here's a link.
http://www.rc-race-and-drift-japan.c...yword=SD-008RC
cracky1970 is offline   Reply With Quote
Old 01-08-2016, 01:36 PM   #707
Trader Rating: 24 (100%+)
No mesh problems here using stock pinion and spur.
newob is offline   Reply With Quote
Old 01-08-2016, 05:04 PM   #708
Out of curiosity, what is the stock pinion that comes with the kit, and the FDR with it and the 87 spur?
Having trouble searching for it specifically, with my kit on it's way to me in the post
Zarathrustra is online now   Reply With Quote
Old 01-08-2016, 08:52 PM   #709
Trader Rating: 30 (100%+)
20t pinion in kit. Internal gear ratio is 2.6 FDR calculation: Spur gear size divided by pinion size = ? Multiply answer times internal gear ratio. 87 divided by 20 = ? Multiple answer by IGR
Go to Novaks suggested FDR per motor sizes and application. Their FDR per different sized motors is really similar to other brands suggestions. If anything Novaks FDR's may be .5 higher than others.
Norse is offline   Reply With Quote
Old 01-10-2016, 04:47 PM   #710
HSV427's Avatar
Trader Rating: 21 (96%+)
Does anyone no why yokomo built the carbon front flat shock tower completely different to the composite one, its gotten to the point that i have to run the longer AE springs to get the ride height i need for the setup i want to run.
XRAY XB4 15, XRAY XB4 16, XRAY XB2, YOKOMO B-MAX4 III FACTORY KIT, YOKOMO YZ4, YOKOMO YZ2,KYOSHO RB6, TAMIYA TRF503, TAMIYA TRF201XMW, TAMIYA TRF 211XM
HSV427 is offline   Reply With Quote
Old 01-10-2016, 06:00 PM   #711
No idea why HSV. Sorry my friend.
Did you try the gullwing CF tower with the flat a arms? I guess using the GW shock tower is much closer to the kits stock comp front shock tower.
Old 01-10-2016, 07:25 PM   #712
Default Breaking In
I just got my car built and was curious how to setup the clicker diff and slipper. .also how much break in time do I need on the car..it seems like the car is a little tight
jjohnson555 is offline   Reply With Quote
Old 01-10-2016, 07:43 PM   #713
Lower bit conditions don't lock the clicker down as you will like the off power steering coming into tight turns.
You will want the rear 6mm narrow belt and pulleys. Less drag. Try the slipper at the manual suggestion.
Old 01-11-2016, 09:03 AM   #714
Cool. Thanks for the help..I'm running on turf so I'll lock the clicker.
Old 01-11-2016, 12:15 PM   #715
Crawlin's Avatar
Trader Rating: 22 (100%+)
Quick question -
Is the gear diff included with the yz-2 the same as what is in the yz-4? I usually end up buying an extra or 2 to fill with different fluids for easier testing and swapping. Since I went ball diff in the yz-2 just would make it easier not to have to mess with buying another since I still have that extra one.
edit - just saw on amain they say compatibility is for both
Crawlin is offline   Reply With Quote
Old 01-11-2016, 12:21 PM   #716
Originally Posted by Crawlin View Post
Quick question -
They are the same my friend
Old 01-12-2016, 11:01 AM   #717
I'm just curious about you guys breaking the arms on this car. I now have 4 race days on my car and have crashed (a lot) and some pretty hard crashes. The last one I bent a shock shaft and broke the drive cup on the front diff by hitting a brick pole at the track off a jump, but have not broken an arm yet. These are the original kit arms from the first batch of kits delivered and they were not boiled??????
madmikepags is offline   Reply With Quote
Old 01-12-2016, 02:37 PM   #718
I've broken one front and one rear arm so far.
The front one was on the first meeting, 2nd race with it, went into a chicane with too much confidence, thought there was a straight line through it, hit the track marking pipe, but there was something harder behind it. Result, broken front arm, snapped across the middle shock mounting hole. Didn't worry me too much, as I knew what I'd hit, plus it was around 0degreesC, so temperature might've had something to do with it.
Next meeting, I did the opposite side rear arm. This one was more of a worry, as I didn't think I'd hit anything, or if I did, it wasn't a hard hit. Snapped the arm across the inner hinge pin.
Car is from the first batch into the UK, arms weren't boiled.
I've since boiled the arms & had no more problems in two meetings.
X-Factory UK / Carisma Racing/ Corally/ Vampire Racing /TEKIN/ AVID/ JConcepts / Lunsford / Exotek Racing / Hiro Seiko / RDRP / GRP Tyres/ Tuning Haus/ DMSPARTZ / McKune/ RCS Graphic Workz / WTF / DMS Racing / Model Junction
John Myall is offline   Reply With Quote
Old 01-12-2016, 03:24 PM   #719
It wasn't a wide-spread issue; I haven't broken any arms (or any part) either.
My kit was purchased on 11/18 in the states.
Old 01-12-2016, 03:47 PM   #720
trf415msx's Avatar
Trader Rating: 14 (100%+)
Thumbs up
Since I ran this car indoor clay about 10f in Chicago no break anything so far
trf415msx is offline   Reply With Quote
