Like Tree15Likes
Old 12-28-2015, 09:15 AM   #646
jordan860's Avatar
Originally Posted by LOW ET View Post
anyone know who might have a rear carbon shock tower #z4-018 in stock in the usa?
when using the schumacher wide stagger rib front tires without inserts, do you vent them (put a hole in them)?
Just got one from my local hobby shop give them a call there closed on Mondays though.
http://www.rcmadness.com
jordan860 is offline   Reply With Quote
Old 12-28-2015, 09:25 AM   #647
LOW ET's Avatar
Trader Rating: 95 (100%+)
thanks, i'll check 'em out
LOW ET is online now   Reply With Quote
Old 12-28-2015, 09:29 AM   #648
Normally we use an insert in the wide 4wd staggers, it's the slim 2wd ones you can run without one.
X-Factory UK / Carisma Racing/ Corally/ Vampire Racing /TEKIN/ AVID/ JConcepts / Lunsford / Exotek Racing / Hiro Seiko / RDRP / GRP Tyres/ Tuning Haus/ DMSPARTZ / McKune/ RCS Graphic Workz / WTF / DMS Racing / Model Junction
John Myall is offline   Reply With Quote
Old 12-28-2015, 09:32 AM   #649
LOW ET's Avatar
gotcha, thanks
Old 12-28-2015, 01:28 PM   #650
Trader Rating: 30 (100%+)
Originally Posted by Piles View Post
If you want to return to something like the kit caster you'll need to increase the rake angle by +2.5. That will give you 10.5, but I'm confused why you dont go back to the original caster blocks and then mess with rake angle inserts from there.
That's what I did Brudda added more caster 2.5 inserts. The aluminum 8 degree caster blocks actually seem to match the kits 10 degree caster blocks. Strange as they say 8 degree but they definetly fall in line with the kits caster blocks.
Thanks Brudda
Norse is offline   Reply With Quote
Old 12-29-2015, 02:53 AM   #651
HSV427's Avatar
Trader Rating: 21 (96%+)
So i decided to boil the arms today for 30 minutes and lets just say i was pleasantly surprised, had a couple of descent crashes that would have normally destroyed the arms and they held up just fine, if your having arm breaking problems i highly recommend.
XRAY XB4 15, XRAY XB4 16, XRAY XB2, YOKOMO B-MAX4 III FACTORY KIT, YOKOMO YZ4, YOKOMO YZ2,KYOSHO RB6, TAMIYA TRF503, TAMIYA TRF201XMW, TAMIYA TRF 211XM
HSV427 is offline   Reply With Quote
Old 12-29-2015, 09:56 AM   #652
LOW ET's Avatar
they had one, thanks a ton
Old 12-30-2015, 05:31 PM   #653
jordan860's Avatar
No prob glad I could help
Old 12-31-2015, 02:02 PM   #654
OriginalDonk's Avatar
Trader Rating: 38 (100%+)
Just sitting down to throw a few more aluminum bits in my YZ-4 and finding that the aluminum steering bell crank for YZ-2 (Z2-201BA) required different bearings than those provided with the YZ-4. Both AMain and Mibo list the Z2-201BA as compatible with both cars.
Anybody encounter this? I'm thinking I could pick up four bearings and be good to go. Just didn't expect this.
OriginalDonk is offline   Reply With Quote
Old 12-31-2015, 02:22 PM   #655
UK.hardcore's Avatar
There are yz4 specific ones.
UK.hardcore is offline   Reply With Quote
Old 12-31-2015, 02:33 PM   #656
LOW ET's Avatar
part #?
Old 12-31-2015, 02:50 PM   #657
part #?
Everywhere I look Z2-201BA is called out as the part number. Wondering if I pick up four 5x8 bearings it'll work. Looks like the YZ-4 bell cranks use 5x10 bearings. A little uneasy about changing the steering geometry event slightly.
Old 12-31-2015, 02:59 PM   #658
LOW ET's Avatar
i was asking UK what's the part # for the yz-4 specific part. i'm in the same boat as you because i was just gonna buy the z2-201ba part also. glad i seen this first, now i gotta do some more home work.
Old 12-31-2015, 06:08 PM   #659
Trader Rating: 42 (100%+)
The aluminum bellcranks are the same between the yz2 and yz4.
The steering rack itself is different between models.
I just took a look at both of my manuals.
The yz4 stock plastic bellcranks take 5x10mm (4) bearings.
The yz2 aluminum (and yz4 option) bellcranks take 5x8mm (4) bearings.
Aaron Moore
Serpent America/Desoto Racing, McFactory Motorsports, Team Trinity, Pro-Line/Protoform, Hobbywing North America/FalconSEKIDO, HRP Distributing, PTRC Racing, Ho B Max
Antimullet is offline   Reply With Quote
Old 12-31-2015, 06:22 PM   #660
So if you want to use the option bell cranks you'll need to pick up four 5x8mm bearings. Thanks Antimullet.
