Like Tree15Likes
Old 12-25-2015, 11:28 PM   #631
hacker's Avatar
Trader Rating: 140 (100%+)
Shorter rear arms promote less rear traction, not more!
hacker is offline   Reply With Quote
Old 12-26-2015, 08:10 AM   #632
Trader Rating: 53 (100%+)
in corner entry yes ...maybe depending on roll center front to rear offset but most don't need it ...but on exit every set up theory book,manual, notes for the last 17years ive used has always stated narrowing rear track width will provide more grip on exit and if you payed attention in this thread most where having a problem with wash out on exit due to the natural drag of this car ...so thats why most of us where running narrow rear set-up and the reason why the car was developed with different rear pivot options but im not going to dig into that aspect
check out the Hudy set-up books ....probably the most used worldwide
Rick Hess
Tekno RC--Protek RC
R&C Hobby shop Clarksville TN
RCP Customs
rkhess is offline   Reply With Quote
Old 12-26-2015, 08:43 AM   #633
UK.hardcore's Avatar
isn't it very contra productive to go a short arm to narrow the rear?
because as far as i know a narrowed rear will make the car more grippy but the short arm has the opposite effect.
UK.hardcore is offline   Reply With Quote
Old 12-26-2015, 09:36 AM   #634
DaveG28's Avatar
Trader Rating: 60 (100%+)
Can you explain that? (Not denying it by the way!)
We have several hex and eventually several arm options on this car, so would be interesting to know the theoretical changes behind each!?
Viper ESC's ~ Xpert Servo's ~ Sanwa Radio
DaveG28 is offline   Reply With Quote
Old 12-26-2015, 11:57 AM   #635
dr_hfuhuhurr's Avatar
Trader Rating: 73 (100%+)
Gull arms on the front does what exactly?
"There is a fine line between hobby and mental illness. Which side are you on?"
“Life is hard; it's harder if you're stupid.” - John Wayne
dr_hfuhuhurr is online now   Reply With Quote
Old 12-26-2015, 12:47 PM   #636
A shorter arm normally reduces grip due to different roll caracteristics.
But when you narrow the rear end you will get a car that doesn't want to rotate around it's front end as much, basicly making it more grippy.
So it counteracts each other.
Old 12-26-2015, 04:31 PM   #637
DaveG28's Avatar
Ok cool, so potentially keeping the s4 arm instead of the Yz-2 arm, but using the 5mm or 4.3mm hex on the rear may be a useful thing to test!
Old 12-26-2015, 04:33 PM   #638
DaveG28's Avatar
I've seen contradictory stuff on that, but I am told by someone good who runs the car that it improves it on bumps, and removes some steering.
Old 12-26-2015, 08:55 PM   #639
Trader Rating: 42 (100%+)
On very high grip tracks it makes the steering less twitchy and also handles better in the rough.
This is per some setup sheets I'm seeing the last one being Lee Martins'.
I haven't tried them myself I like a ton of steering and a responsive car on the local indoor clay track. Definitely might try it on Astro.
Aaron Moore
Serpent America/Desoto Racing, McFactory Motorsports, Team Trinity, Pro-Line/Protoform, Hobbywing North America/FalconSEKIDO, HRP Distributing, PTRC Racing, Ho B Max
Antimullet is online now   Reply With Quote
Old 12-27-2015, 02:35 PM   #640
Trader Rating: 30 (100%+)
Has anyone ran their YZ4 with adding -2.5 more kick up? If so what is the verdict? Thinking that running -2.5 inserts may help take some twitch out of the steering especially since I made a mistake in buying the 8 degree aluminum caster blocks when I should have bought 12.5 (I heard the 8 degree aluminum casters are closer to the 10 degree kit composite casters, however I am not sure if that is true.
Thank you
Norse is offline   Reply With Quote
Old 12-27-2015, 03:16 PM   #641
Thank you
If you want to return to something like the kit caster you'll need to increase the rake angle by +2.5. That will give you 10.5, but I'm confused why you dont go back to the original caster blocks and then mess with rake angle inserts from there.
Piles is offline   Reply With Quote
Old 12-27-2015, 03:27 PM   #642
jordan860's Avatar
Originally Posted by MrLean View Post
Where did you get those battery charger wires?
I got them from A main there Made by TQ
jordan860 is offline   Reply With Quote
Old 12-28-2015, 01:32 AM   #643
HSV427's Avatar
Trader Rating: 21 (96%+)
Those who are running the YZ-2 front arms how did they effect the handling of the buggy and secondly to they break as easy as the YZ4 front arms thanks.
XRAY XB4 15, XRAY XB4 16, XRAY XB2, YOKOMO B-MAX4 III FACTORY KIT, YOKOMO YZ4, YOKOMO YZ2,KYOSHO RB6, TAMIYA TRF503, TAMIYA TRF201XMW, TAMIYA TRF 211XM
HSV427 is offline   Reply With Quote
Old 12-28-2015, 07:33 AM   #644
joeymdz's Avatar
Send a message via MSN to joeymdz
Not worth the extra work trying to make them fit. Also broke the yz2arm but in a different spot.. ha!
RC Plus*McKune Designs*NW Hobbies*Premier RC Raceways*Daves Tracks
joeymdz is offline   Reply With Quote
Old 12-28-2015, 09:09 AM   #645
LOW ET's Avatar
Trader Rating: 96 (100%+)
anyone know who might have a rear carbon shock tower #z4-018 in stock in the usa?
when using the schumacher wide stagger rib front tires without inserts, do you vent them (put a hole in them)?
LOW ET is offline   Reply With Quote
