Like Tree41Likes
Old 12-21-2015, 08:22 AM   #601
dr_hfuhuhurr's Avatar
Trader Rating: 75 (100%+)
Ran the car for the first time Sunday (carpet/RC Madness). The car was pushing on and off power like crazy with the kit setup. Made some changes (springs, oil, shock positions). Can someone share a setup or give me some other things to try.
The drive train has definitely loosened up a bit, still has a way to go though.
"There is a fine line between hobby and mental illness. Which side are you on?"
“Life is hard; it's harder if you're stupid.” - John Wayne
dr_hfuhuhurr is offline   Reply With Quote
Old 12-21-2015, 10:32 AM   #602
trf415msx's Avatar
Trader Rating: 16 (100%+)
Talking
Originally Posted by Slapjack View Post
Was the yz4 meant to be designed for carpet/astro tracks like the YZ2 is?
Different setup on carpet this car fly on clay indoor just fine
trf415msx is offline   Reply With Quote
Old 12-21-2015, 12:12 PM   #603
DaveG28's Avatar
Trader Rating: 64 (100%+)
Its not a setup, but if you want to force some reaction try increasing the front kick up, it should generate at least off power steering... May make the balance horrible though!
Viper ESC's ~ Xpert Servo's ~ Sanwa Radio
DaveG28 is offline   Reply With Quote
Old 12-21-2015, 12:25 PM   #604
DaveG28's Avatar
What internal shock limiters are you guys running on each surface (dirt/carpet)?
Old 12-21-2015, 12:29 PM   #605
trf415msx's Avatar
Thumbs up
On clay indoor I ran no droop
Old 12-21-2015, 06:14 PM   #606
my setup for rcmadness on my bmax4 was 45/40 with the 1.7/1.6 fr/re pistons orange front and rear springs and no droop and 17mm ride height, I used this for both the astroturf and carpet at madmess, I would imaginbe I would start with the same setup on my YZ4 when i go up there.
madmikepags is offline   Reply With Quote
Old 12-21-2015, 06:16 PM   #607
also try less rear toe in, that should loosen up the rear end a bit too.
Old 12-21-2015, 09:34 PM   #608
Thanks! That is pretty close to where I was. When the car started coming together.
Can you explain what you mean by no droop? I haven't really raced off-road in about 8 years.
Old 12-21-2015, 09:53 PM   #609
trf415msx's Avatar
no limiter inside the shock
Old 12-21-2015, 10:00 PM   #610
Gotcha. No droop in a tc would be kinda the opposite. Spacers in the shock would take droop out if I am thinking of it right.
Old 12-22-2015, 08:00 AM   #611
the incubus's Avatar
Trader Rating: 17 (100%+)
Originally Posted by Norse View Post
Dr._hfuhuhurr is correct as recommended FDR can vary from motor to motor.
Say what now?
ROB RIVERA
≈ PRS1 2014 :: SP Reventon Pro 1.1 :: Team Powers Plutonium17.5 ≈
≈ DEX410 :: SP Reventon Pro 1.1 :: Reedy Sonic 6.5T ≈
WWW.TRICOUNTYHOBBIES.COM :: WWW.CRPPLUS.COM
the incubus is offline   Reply With Quote
Old 12-22-2015, 09:10 AM   #612
I know...I was shocked too that I had gotten something right.
Old 12-22-2015, 09:15 AM   #613
Please explain how a motor affect FDR. My dad was a factory Suzuki riders the 70's so I grew up around racing and have myself raced and worked on motorcycles and karts and did RC for many years and I have never heard of such a thing.
As far as all the knowledge I've accrued in my 42 years on this rock, gear ratios can only be altered/affected via introducing different sized gears. The force driving them only changes how much power/speed/torque drives the transmission.
ROB RIVERA
Old 12-22-2015, 09:19 AM   #614
Different motors will work best at different FDR values based on the available torque and RPM.
Old 12-22-2015, 10:01 AM   #615
No droop is the same as TC, it is NOT "no" limiters, its probably 4-5 limiters in the shocks? But haven't done a no droop setup in my YZ4 yet so I dont know how many exactly, also a sway bar in the rear will help loosen up the rear a bit also.
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
micholix
