Like Tree17Likes
Old 12-17-2015, 07:50 PM   #586
jordan860's Avatar
Here's a couple of pics of mine.
jordan860 is offline   Reply With Quote
Old 12-17-2015, 08:00 PM   #587
Trader Rating: 30 (100%+)
Looks Great Jordan!!! Did you get the FDR calculations down? Looks like you did from your previous posts however feel free to ask any further questions you may have as I will help as will others on this thread.
Again looks great
Norse is offline   Reply With Quote
Old 12-17-2015, 08:12 PM   #588
jordan860's Avatar
Again looks great
Yes I finally did. I went with 78/29 and it works great on our layout. Thanks again for all your help. It still needs a bunch of work but I'm happy with it right out of the box. Tomorrow will be the first race on it I just picked it up last week. The only other problem I'm having is on power turns the inside front wheel picks up I'm sure stiffer springs in the rear should help.
Old 12-18-2015, 12:08 PM   #589
UK.hardcore's Avatar
I would go down on your diff oils being you are on dirt. Thus as well run heavier in the front diff and lighter in the rear which should help out. Try 7kf 3kr or 7k 5k and I have heard people running 5kf 3kr. Have you tried your clicker both locked down as well as dialed back?
Running Saddle packs or bricks sets the back end down. Yes it's added weight but that helps as well as the added weight covering more of the chassis rear surface area. Try a little more kick up with your inserts being set to add more neg caster. 2.5. You could try more droop in all your shocks. I have the thinnest limiters inside( more so for a little added protection on the bottom side of the shock piston) thus they are so thin they really aren't limiting my droop. More droop in the front will tend to shift weight towards the backend when you apply power.
You may want to drop your shock oils down a tad being -2.5. I believe AE is a little lighter than other brands.
Also the car needs to a good amount of packs run through it to breaking the diffs and belts.
If you have any drag break set on your ESC dial it way back or even totally off.
I hope this helps and I am sure some of the other YZ4 owners will share their advice.
Are you running the saddle/square transverse or lenghtwise?
UK.hardcore is offline   Reply With Quote
Old 12-18-2015, 01:39 PM   #590
Running Saddles lengthwise. But will try them transverse once I make a new jumper.
On another note: has anyone noticed the front aluminum brace tends to be really loose? I glued a plastic shim to the back inner side of my bumper to keep the hinge pin brace tight. Also going to put the YZ2 front bumper/skid on to fill the void on the backside of the a-arm hanger.
Old 12-19-2015, 03:29 AM   #591
I am running saddles perpendicular to the chassis, thus I wil try running standard style but need to rig a low pro jumper.
Old 12-19-2015, 07:10 AM   #592
joeymdz's Avatar
Send a message via MSN to joeymdz
Sways would stop that
RC Plus*McKune Designs*NW Hobbies*Premier RC Raceways*Daves Tracks
joeymdz is offline   Reply With Quote
Old 12-19-2015, 07:14 AM   #593
jordan860's Avatar
Just placed a order thanks.
Old 12-20-2015, 05:13 PM   #594
DaveG28's Avatar
Trader Rating: 60 (100%+)
I have noticed the front brace moves easily I glued a plastic shim on the inner side of the front bumper to keep the aluminum brace snug.
I think the front hanger could be redesigned thus to make the front solid as well as take stress off the front a arm barrels. Not a huge deal as with releasing new platforms providing total perfection from the start is almost impossible. Yokomo has done an amazing Job with the YZ4 and I believe they will design and produce improvements they feel necessary.
The team guys at the worlds had a brace which clamped around the chassis, hopefully it will come out!
Viper ESC's ~ Xpert Servo's ~ Sanwa Radio
DaveG28 is offline   Reply With Quote
Old 12-20-2015, 05:14 PM   #595
DaveG28's Avatar
Yep so far I am finding soft springs but with a heavier than expected sway bar (1.4) at the rear works as a combination!
Old 12-20-2015, 05:18 PM   #596
DaveG28's Avatar
I've now got a couple race days in my dirt car and one on my more standard carpet car, and slowly getting more impressed! Having run both with the steering option parts and without, I would say these are some of the more crucial bits to get, really reduce slop.
I have destroyed a servo horn... Anyone finding suitable alternative horns to use? On the upside the arm did not break in the crash which killed the horn, so looks like they are holding up!
Anyone know why the setups currently posted on petit have more droop for carpet running than dirt? Would expect the other way round! What limiters inside the shocks are you all running? I had 2 limiters on the dirt car and none on the carpet car... May remove a set of limiters as even with the extra droop the car doesn't seem too lazy, and I would think more droop on low grip is better?
Old 12-20-2015, 05:29 PM   #597
trf415msx's Avatar
Trader Rating: 15 (100%+)
Thumbs up
I finally got a good setup for clay indoor or I can call comfortable drive for 13.5 nice and smooth and fast ....I ran at leisurehours raceway was a fun night for practice with 1.6 in front 37.5 yellow spring Ae and 1.7 in the rear 32.5 with white Ae spur 78 pinion 35 was done deal....no more nose down dial in like on road car I was so happy
trf415msx is offline   Reply With Quote
Old 12-20-2015, 11:02 PM   #598
I'm using one of the alloy Exotek horns for the Associated cars. The holes line up pretty well, only half a mm or so different.
X-Factory UK / Carisma Racing/ Corally/ Vampire Racing /TEKIN/ AVID/ JConcepts / Lunsford / Exotek Racing / Hiro Seiko / RDRP / GRP Tyres/ Tuning Haus/ DMSPARTZ / McKune/ RCS Graphic Workz / WTF / DMS Racing / Model Junction
John Myall is offline   Reply With Quote
Old 12-21-2015, 07:10 AM   #599
Slapjack's Avatar
Trader Rating: 19 (100%+)
Originally Posted by trf415msx View Post
I finally got a good setup for dirt or I can call comfortable drive for 13.5 nice and smooth and fast ....I ran at leisurehours raceway was a fun night for practice with 1.6 in front 37.5 yellow spring Ae and 1.7 in the rear 32.5 with white Ae spur 78 pinion 35 was done deal....no more nose down dial in like on road car I was so happy
Was the yz4 meant to be designed for carpet/astro tracks like the YZ2 is?
Tekno Eb48.3, EB48.2, Tekno ET48, X-Ray XB4'14, '15 & '16, X-Ray XB2 CE, X-Ray T4'15, Hot Bodies D413, Serpent SRX-2, Axial Wraith (full custom Mattzilla Build), Blade 180QXHD
Slapjack is offline   Reply With Quote
Old 12-21-2015, 07:16 AM   #600
It's developed on astro/carpet. With a good tune it should do fine on dirt/clay.
