Like Tree29Likes
Old 09-28-2015, 06:14 AM   #46
Jmuck69's Avatar
Is it a belt-drive to front and rear geared transmissions? Kinda like the serpent rear transmission I guess.
B6D | B64D
Schelle Racing Concepts - www.schelleracing.com
Amain Hobbies - www.amain.com
Jmuck69 is offline   Reply With Quote
Old 09-28-2015, 06:58 AM   #47
That was my first thought, but still says 2 belts....?
The Tamiya TA06 uses a rear gearbox and then 2 belts though...
Adelaide RC Team Driver - www.adelaiderc.com.au
Support the Shops that Support the Racers
cplus is offline   Reply With Quote
Old 09-28-2015, 07:16 AM   #48
If you look through the front window of the car in the release statement there almost looks like a belt running off the centre line of the chassis, more to the right of the chassis. I'm guessing the car will have two belts running from the central spur gear and then to pulleys and a simple gear transmission at either end. I guess this way they could use the same diffs as the YZ2?
It'll be interesting to see it with the shell off though!
Badger5 is offline   Reply With Quote
Old 09-28-2015, 07:27 AM   #49
NoobRCDriver's Avatar
Originally Posted by cplus View Post
Belt drive? Did I read that right??
When almost every other high end buggy is shaft (except the Tamiya, which has been abandoned) that is cool to see
Serpent spyder srx -4, TLR 22-4, and isnt Schumacher belt? Are those not "High end"?
I'm amazed how Yokomo can keep a secret. ..lol November release date? I can't wait either!
Team (Your name here) Driver - The hobby Shop (Dayton, Ohio) -
NoobRCDriver is offline   Reply With Quote
Old 09-28-2015, 09:04 AM   #50
Transmission of high driveline torques is the usual problem for belt durability. For the same given power you could reduce torque / belt force and increase belt speed by way of gearing at either end of the car. This principle is how WRC cars can use such lightweight prop shafts.
AntH3000 is offline   Reply With Quote
Old 09-28-2015, 11:03 AM   #51
Had no issues with my K1 or KF with belt durability. True running belts at a higher speed will reduce torque but will also increase drag.
I think there will not be two much difference in the belt speeds to notice a difference but with a gearbox at either end it will allow the belt pulleys to be a good size and the spur will not need to be so big as a K1 which is one of this cars issues.
What will be interesting is what the direction of rotation the motor will be compared to the wheels, this makes a big difference to belt driven cars.
I will have to wait and see what this car will be like especially compared to the Schuey K2.
Old 09-28-2015, 11:46 AM   #52
Yep, good point. The 511 was same motor rotation direction as K1, I'm guessing that might influence things....
Old 09-28-2015, 08:21 PM   #53
teeforb's Avatar
Trader Rating: 94 (100%+)
Send a message via Yahoo to teeforb
YZ-4 has adapted the new type of drive-train which enable to reduce the weakness of conventional type of belt drive and shaft drive car,
To me this says a complete different drive train than shaft or belt.
$$ Team High Budget $$
17.5 stock buggy fb page
https://www.facebook.com/groups/17.5stockbuggy/
teeforb is offline   Reply With Quote
Old 09-28-2015, 11:03 PM   #54
Then how do you think the drive is transmitted to the front and rear gearboxes/diffs?
It's already been confirmed the car is a two belt design, but I guess instead of going directly to the diffs like a Schumacher or TRF there is a small gearbox to drive each diff.
Old 09-29-2015, 12:29 AM   #55
Trader Rating: 138 (100%+)
Since the 22-4, assuming Serpent, and Kyosho ZX6 have slippers, this will have one as well? I much prefer ball diffs to gear diffs (had a b44.3, D413) and I like the adjustability and ease of maintenance of a ball diff. I hope its an option. As far as the belts themselves, if you can adjust tension with an insert type setup like the TLR car, your belts can last a long time if maintained correctly (same with a ball diff for that matter). Just picked up and ran my new YZ-2 and was so impressed that I will get this around my b-day time in December to replace my current (as in not even finished being built yet) D413. I'll be very interested to see how this car does on dirt. Was it run as a prototype at Cactus this year?
TLR 22T 3.0, 2X Yokomo YZ-2 DTM, B64D (Temporary 4 wheel) YZ-4 SF (please hurry), Mugen MBX7R Eco, Hobbywing, Futaba, LRH Hobbies, Amain Hobbies, iCharger.
jpcopeland1 is offline   Reply With Quote
Old 09-29-2015, 12:32 AM   #56
That concerns mw a a bit. Extra bearings and moving parts and more revolving mass.
Piles is offline   Reply With Quote
Old 09-29-2015, 08:01 AM   #57
J@UNE's Avatar
Could it be using belts on the sides like the last xFactory prototype?
And have the batery/motor layout of the losi JRXS without the short arms issues...
Or as mentionned earlier no belt in rear like serpent but one front...
Jon Gagnon
DirtTrax - Team FLR
J@UNE is offline   Reply With Quote
Old 09-29-2015, 09:36 AM   #58
Team Tekin
Randy_Pike's Avatar
Send a message via Yahoo to Randy_Pike
Guys you're all looking too far.
"Things may come to those who wait, but only the things left by those who hustle." Abraham Lincoln
Tekin,Protek,A-Main Hobbies,JConcepts,Avid RC,Yokomo,MIP,SikLidz,FactoryRC, www.randypikerc.com
Randy_Pike is offline   Reply With Quote
Old 09-29-2015, 10:30 AM   #59
Doubt that, it sure ain't no Schumacher!
Old 09-29-2015, 11:04 AM   #60
If it were assumed a single mesh in the gearboxes at either end, the motor would be rotating in the same direction as the K2 or Serpent. You'd think it would be mounted near the middle or ahead of the middle as per K2 too....
