Like Tree17Likes
Old 11-27-2015, 03:11 AM   #421
HSV427's Avatar
Trader Rating: 21 (96%+)
Put the car on the track for the first time today and to say i was impressed would be an understatement, the buggy was awesome and just does everything right. Is it normal to get a 20mm front ride height i had to screw the shock retainer almost all the way down is this normal. Now on a different not a buggy hit me from behind and my car rolled about 3 times nothing serious however it broke a front and rear arm and like people are saying my arms are full of air bubbles, does any one know if yokomo plan to fix this i found it real dissapointing especially considering how small the hit was.
Serpent 977 35th anniversary. Serpent 977 evo2, Shepherd Velox, Motonica p81rs2, OS speed shimo edition.
HSV427 is offline   Reply With Quote
Old 11-27-2015, 03:37 AM   #422
tony2's Avatar
Hey mate, what track did you have it at?
Yes the arms should be fixed in the future, never have they broken and seen the air bubbles like a couple people have.
How long have you had the shocks built for and did you rebleed them? The clear xring swells after a couple days of being in oil which makes it tight thus you will get a low ride height as it will have pressure on the seals holding the shaft.
I use green slime in mine and if the oring gets tight you can (a little dodgey) back the cartridge nut off 1/4 turn.
For an outdoor dirt track 22mm ride height is a good starting point.
Anthony Campbell
Ryper Hobbies l AKA | AE
tony2 is offline   Reply With Quote
Old 11-27-2015, 05:21 AM   #423
If you use the Yatabe springs, they are 5mm shorter apparently.
I broke a front arm when I ran mine on Sunday, it had a bubble or two in there, I know Lee Martin said he was going to report to Yokomo about it, so you'd think there will be a fix.
X-Factory UK / Carisma Racing/ Corally/ Vampire Racing /TEKIN/ AVID/ JConcepts / Lunsford / Exotek Racing / Hiro Seiko / RDRP / GRP Tyres/ Tuning Haus/ DMSPARTZ / McKune/ RCS Graphic Workz / WTF / DMS Racing / Model Junction
John Myall is offline   Reply With Quote
Old 11-27-2015, 09:53 AM   #424
Trader Rating: 30 (100%+)
Originally Posted by John Myall View Post
So far, yes shorty only. Might give saddles a go at some point.
Me to. Another great thing about this buggy is all the lipo options and lay out possibilities.
Norse is offline   Reply With Quote
Old 11-27-2015, 10:08 AM   #425
+1 on the AE green slime. Works excellent! I also use it on my diff o-rings after I soak them in oil for half a day.
Old 11-27-2015, 10:43 AM   #426
UK.hardcore's Avatar
Well the GHEA pistons i wanted to use are a little bit too thick.
Put AE 4x1.3 tapered in instead.
Diff's are really tight, might want to use a shim less in the beginning.
UK.hardcore is offline   Reply With Quote
Old 11-27-2015, 12:51 PM   #427
If anyone want wants to smooth out the diff gears, thus break them in: 1. Put all off them in a bag filled with very very fine sand. 2. make sure the you use a cloth type bag. 3. toss the back in your dryer and tumble dry on low heat to no heat for 15 minutes.
This is super OCD method a friend of mine at a machine shop told me about, thus its definetly not necessary as they will break in running the first couple packs threw.
Old 11-27-2015, 02:55 PM   #428
HSV427's Avatar
Hi mate i ran the buggy at my local track(keilor) and i have rebuilt the shocks and bled them, for me to get 22mm ride height the shock collar is screwed all the way down and the eyelet has to be unscrewed 1mm on the shock shaft, I'm wondering if its because the front springs are very soft and also very short.
Old 11-27-2015, 03:04 PM   #429
HSV427's Avatar
As for the arms breaking i have fixed the problem for the rear arms by using Bmax4 3 rear arms it too a bit to get them to work, but once i trimmed the arms 1mm front and rear they fit and have the same adjustability as the stock arms, i also had to add the Bmax4 3 rear axle the actual dog bone is the same its the axle that is different , it feels fine and the car works flawlessly.
Old 11-27-2015, 03:04 PM   #430
MIBOSport has insane shipping speed as I ordered the Z4 300SRR rear rear hanger late Tuesday and it just arrived. Czechelslovocia to Wisconsin in 48 hours. Michal at MIBO has his business totally dialed providing customers A+ service
Old 11-27-2015, 03:52 PM   #431
True... Good service and fast shipping.
rhodopsine is offline   Reply With Quote
Old 11-28-2015, 01:51 AM   #432
HSV427's Avatar
Does anyone know if the graphite front arms are stronger than the stock ones, or is being graphite more likely to make them more brittle.
Also does any one know if the yz2 front arms are compatible with the yz4./
Old 11-28-2015, 05:36 AM   #433
Trader Rating: 53 (100%+)
i had a set of yz2 flat arms i mocked up .....i didnt really want to hack them up ....unfortunately in my opinion you would have to trim too much off to get the hubs to fit in the arm
so i went the other route boiled a brand new set 30 mins they feel a tad more flexible
after 3 small adjustments im on pace with my bmax4 but more consistent .....its a very good car
Rick Hess
Team C USA
R&C Hobby shop Clarksville TN
RCP Customs- RC Juice-
rkhess is offline   Reply With Quote
Old 11-28-2015, 10:27 AM   #434
+1 on boiling the a-arms
Old 11-28-2015, 07:27 PM   #435
Wonder if this would work on tyres, to scuff them up before gluing them to the rim?
Aussie RC is offline   Reply With Quote
