    Hide Wikipost
Old 10-18-2017, 07:19 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Yokomo YZ-2
Last edit by: Bob Barry
Welcome to the YZ2 Wiki!
If you edit the page, please add your name and date prior to your addition. While an admin can view the history, this makes it easier for everyone to just check updates. We'll put the newest additions at the top
Setup Sheets can be found here
DT CA DTM parts comparison
Print Wikipost
Like Tree102Likes
Old 09-27-2015, 11:33 PM   #1441
WillS's Avatar
Trader Rating: 30 (100%+)
Send a message via MSN to WillS Send a message via Yahoo to WillS
Originally Posted by afm223 View Post
I went back up to Outback this morning. The car was dialed and about 1/2 second faster than my b5M early in the day when the traction was good. It was a bit of a handful late in the day when the traction went away.
Shoot, I was up there all day. You should have slapped me upside the head and asked to drive the Y-max. I was driving it all day trying to make it get loose, which was very hard to do. Worth the swap in my book.
Will Smith
Sponsors:
Cheater Racing, Team Powers, Amain.com/Protek, Dialed RC Hobbies/Soar
WillS is offline   Reply With Quote
Old 09-28-2015, 04:36 AM   #1442
scr8pn4205's Avatar
Looking for input on a setup that is geared towards 17.5 on ozite. Petit rc is down so cant look there. thanks
Airtronics M12
Team Xray XB2 2017 CE
TSR power
scr8pn4205 is offline   Reply With Quote
Old 09-28-2015, 08:09 AM   #1443
I'll hit you up next time.
afm223 is offline   Reply With Quote
Old 09-28-2015, 11:39 AM   #1444
scr8pn4205's Avatar
can someone explain what the rear suspension mount spacers are used for. Some setups show it removed from the rear front mount and on the rear rear mount it is place on top versus using it in the factory location? is it a roll center change?
Airtronics M12
TSR power
Old 09-28-2015, 01:32 PM   #1445
I asked that question a page or so back, and that is the response I got (roll center change)
TLR 22T and Yokomo YZ-2 and 4
www.corvictoria.com
brew99 is offline   Reply With Quote
Old 09-28-2015, 03:16 PM   #1446
Jack Smash's Avatar
Trader Rating: 29 (100%+)
Yes, It is a roll center adjustment and has a larger effect than the inner ball stud adjustment. Raising the arm mount raises roll center, lowering arm mount lowers roll center (opposite of inner ball stud adjustment).
Jack Smash is offline   Reply With Quote
Old 09-29-2015, 04:30 AM   #1447
scr8pn4205's Avatar
thank you for the response. Coming from the B5m lite I do seem to enjoy this car better
Airtronics M12
TSR power
Old 09-29-2015, 02:41 PM   #1448
hollywood3705's Avatar
Removing the mount spacers made the car roll a bit more in the corners. It gave a more balanced feel on a tight high bite track for me
Amain.com / Protek / VRP / The Ohio R/C Factory / The Bearded Wonder
hollywood3705 is offline   Reply With Quote
Old 09-29-2015, 05:59 PM   #1449
8ight-e's Avatar
Trader Rating: 58 (100%+)
Tips for ball diff install? What washer size and what side is the screw on,, the gear side or opp the gears?
Edit, yes for spacers and if you put the longer drive shafts on, at least on one side you will need to put the shorter shafts back on. Looks like the short shafts are perfect w/ the ball diff,, outdrives just a touch longer.
Tekno ET48, EB48.2
Durango Fleet - Dex410 v3, Dex210, Desc410, Desc210
8ight-e is offline   Reply With Quote
Old 09-29-2015, 09:28 PM   #1450
Has anyone tried the aluminum rear camber block? What are your thoughts for a medium bite clay track.
Old 09-29-2015, 11:21 PM   #1451
C4PT4IN's Avatar
picking this buggy up in a week, can't wait to put this together also getting an mr v2 for my daughter so it should be a very fun week for us..
this new buggy looks awesome! i've been wanting a yoke for a long time and now i finally get to pull the trigger. Anyone driving this thing that can help me with set-up? I'm in the oc/rc / lrh / pegasus hobbies areas. pegasus is closest but oc isn't too far a drive.
C4PT4IN is offline   Reply With Quote
Old 09-30-2015, 04:29 AM   #1452
Trader Rating: 138 (100%+)
I run frequently at LRH and have a good setup that translates to OC/RC very well. Be aware that it used all of the steel spare parts and the big brass battery weights.
TLR 22T 3.0, 2X Yokomo YZ-2 DTM, YZ-4 SF (please hurry), Mugen MBX7R Eco, Hobbywing, Futaba, LRH Hobbies, Amain Hobbies, iCharger.
jpcopeland1 is offline   Reply With Quote
Old 09-30-2015, 08:31 AM   #1453
lewis110's Avatar
Screw head always goes on the Right rear.
lewis110 is offline   Reply With Quote
Old 09-30-2015, 09:31 AM   #1454
scr8pn4205's Avatar
anyone know when Petit rc will be back up ?
Airtronics M12
TSR power
Old 09-30-2015, 11:31 AM   #1455
C4PT4IN's Avatar
Perfect! Im just looking for a base set-up that i can go back to. How much were the weights and where could i find them?
Currently Active Users Viewing This Thread: 3 (1 members and 2 guests)
kurtblastoff
