    Hide Wikipost
Old 08-10-2017, 01:11 PM   -   Wikipost
R/C Tech Forums Thread Wiki: Yokomo YZ-2
Last edit by: Bob Barry
Welcome to the YZ2 Wiki!
If you edit the page, please add your name and date prior to your addition. While an admin can view the history, this makes it easier for everyone to just check updates. We'll put the newest additions at the top
Setup Sheets can be found here
Print Wikipost
Like Tree63Likes
Old 09-24-2015, 07:52 AM   #1411
mes
Originally Posted by zeakemedia View Post
Do the B5 gears, diff and idlers, fit in the gearbox? I'd like to run Speedy's cut gears if I can.
Do any of you know if a slipper eliminator for the B5 will fit the topshaft? Same reason I am asking this.
Blake
Originally Posted by Randy_Pike View Post
Not sure on the idlers but was told the B5 diff fits if you shim it.
The top shaft isn't the same either. I've been testing some Factory RC carbon fiber Avid/Sheele spur slipper eliminators with great success. They're not out yet, but should be shortly.
B5(M) idlers are a direct fit, as is the VBC Racing Firebolt ball diff as a whole. Diff ring inner dimensions are different to the Yokomo ones, though.
mes is offline   Reply With Quote
Old 09-24-2015, 07:57 AM   #1412
Supertruck1's Avatar
***EXCITED TO SHAKE DOWN THE YMAX THIS WEEKEND***
Tekno Rc
Carpy's
SMC Racing
Supertruck1 is offline   Reply With Quote
Old 09-24-2015, 08:09 AM   #1413
Trader Rating: 137 (100%+)
USPS lost mine.... How do these people stay in business?????
TLR 22T 3.0, TLR 22-4 2.0 , TLR 22 4.0 X2, 22SCT 3.0, Tekno SCT 4X4, Tekno EB48.4, Hobbywing, Futaba, LRH Hobbies, Spektrum Servos, iCharger.
jpcopeland1 is offline   Reply With Quote
Old 09-24-2015, 05:20 PM   #1414
zeakemedia's Avatar
Trader Rating: 72 (100%+)
Thanks mes.
Blake
DJO Race Designs | R1Wurks | Speedy's Racing Parts | The Ohio RC Factory
zeakemedia is offline   Reply With Quote
Old 09-25-2015, 12:59 AM   #1415
Has anyone gotten a kit that was missing parts? I'm missing 2 3X8mm screws, and a lower shock seal so I'm dead in the water.
Old 09-25-2015, 07:09 AM   #1416
Yes the first yz I got was missing a couple parts out of box. The second one was all there.
Franzchise is offline   Reply With Quote
Old 09-25-2015, 07:13 AM   #1417
I hate when that crap happens. AMain is sending me a replacement part, but they are sending it first class mail, so 5 days to get to me. Does anyone here have a spare lower collar they could send me? Regular mail would be way way faster then first class through a business.
Old 09-25-2015, 07:21 AM   #1418
I'm on the fence on whether to get the YZ-2 or the Associated B5M Lite?
fernalfer is offline   Reply With Quote
Old 09-25-2015, 07:58 AM   #1419
Team Tekin
Randy_Pike's Avatar
Send a message via Yahoo to Randy_Pike
It's all about what kind of track you're running on. If the grip is good, the Yz2 is tough to beat.
"Things may come to those who wait, but only the things left by those who hustle." Abraham Lincoln
Tekin,Protek,A-Main Hobbies,JConcepts,Avid RC,Yokomo,MIP,SikLidz,FactoryRC, www.randypikerc.com
Randy_Pike is offline   Reply With Quote
Old 09-25-2015, 08:11 AM   #1420
Do you do anything special to your Dirt tech inserts for this car, a friend of mine who has it says it loves blown out softer foams (@ OC/RC). and the Dirt Techs seem like they would be way too stiff.
Old 09-25-2015, 08:26 AM   #1421
Team Tekin
Randy_Pike's Avatar
I find that 2nd "run" Dirt Tech's work better in this car than brand new ones, yes. So I keep used foams out of my 4wd buggy and use them in "new" tires for they Yz.
Other inserts can work too, red aka's are softer than DT's.
Old 09-25-2015, 09:10 AM   #1422
On my way to Outback to do my second shakedown and see if I can get this car dialed.
afm223 is offline   Reply With Quote
Old 09-25-2015, 09:16 AM   #1423
Motorman007's Avatar
Trader Rating: 78 (100%+)
What are you going to try?
What type of track?
What type of tires?
YOU WILL (ALWAYSWIN).....
Motorman007 is offline   Reply With Quote
Old 09-25-2015, 03:13 PM   #1424
I have a set of AKA reds in my slicks for LRH, cause the smoothies Dirt Techs felt super hard. For my Electrons I just use the stock foams they come with cause OC/RC burns up tires like crazy.
Old 09-25-2015, 03:33 PM   #1425
Suspended
Trader Rating: 61 (100%+)
Does anyone actually run this car right out of the box, or are they all covered in added weight, Bmax, B5, losi and VBC parts?
Best Avatar on rc-tech
Socket is offline   Reply With Quote
