    Hide Wikipost
Old 08-10-2017, 01:11 PM   -   Wikipost
R/C Tech Forums Thread Wiki: Yokomo YZ-2
Last edit by: Bob Barry
Welcome to the YZ2 Wiki!
If you edit the page, please add your name and date prior to your addition. While an admin can view the history, this makes it easier for everyone to just check updates. We'll put the newest additions at the top
Setup Sheets can be found here
Print Wikipost
Like Tree43Likes
Old 09-20-2015, 03:48 PM   #1396
Moderator
MarkA's Avatar
Trader Rating: 21 (100%+)
Originally Posted by Motorman007 View Post
Yes sir the shocks location.
Thanx for the information so loose tracks put the shocks in the rear of the tower?
Basically, yes, shocks on front for real high bite (it really unbinds the rear and lets the car carry more cornerspeed in those conditions) but on the rear if it's loose at all.
MarkA is offline   Reply With Quote
Old 09-21-2015, 01:04 AM   #1397
Yep, the car should feel a bit more loose with the shocks on the front side. And by loose, I mean, you get the more rotation (less grip). MarkA also explains it very well.
If you are not sure HOW it feels, just try them in the front and try them in the rear. It's that easy. I personally run them in the front, but I also know some guys who always (even on high grip) run them in the rear because of that is the way they like it.
株式会社 ヨコモ
dennisV is offline   Reply With Quote
Old 09-21-2015, 09:09 AM   #1398
Team Tekin
Randy_Pike's Avatar
Send a message via Yahoo to Randy_Pike
The Y-max conversion from factory rc in 10 to 14 days.
Thanks for all everyone help. And it takes 10 mins to Change..
The guys at Factory RC told me Amain is due to have a few of these kits up on their site shortly before 10 days.
"Things may come to those who wait, but only the things left by those who hustle." Abraham Lincoln
Tekin,Protek,A-Main Hobbies,KoPropUSA,JConcepts,Avid RC,MIP,SikLidz,ImagineItGraphx, FactoryRC, www.randypikerc.com
Randy_Pike is offline   Reply With Quote
Old 09-21-2015, 03:22 PM   #1399
zeakemedia's Avatar
Trader Rating: 70 (100%+)
Do the B5 gears, diff and idlers, fit in the gearbox? I'd like to run Speedy's cut gears if I can.
Do any of you know if a slipper eliminator for the B5 will fit the topshaft? Same reason I am asking this.
Blake
DJO Race Designs | R1Wurks | Speedy's Racing Parts | The Ohio RC Factory
zeakemedia is offline   Reply With Quote
Old 09-21-2015, 04:14 PM   #1400
Team Tekin
Randy_Pike's Avatar
Blake
Not sure on the idlers but was told the B5 diff fits if you shim it.
The top shaft isn't the same either. I've been testing some Factory RC carbon fiber Avid/Sheele spur slipper eliminators with great success. They're not out yet, but should be shortly.
Old 09-21-2015, 04:32 PM   #1401
zeakemedia's Avatar
Thank you for the reply Randy. As much as I enjoy products from both David and Kurt, Speedy's treats me the goodest. Yes, I meant that.
Blake
Old 09-21-2015, 05:50 PM   #1402
Motorman007's Avatar
Trader Rating: 76 (100%+)
Randy sir do you have a new map for the tekin 17.5t?
Thank you
YOU WILL (ALWAYSWIN).....
Motorman007 is offline   Reply With Quote
Old 09-22-2015, 05:11 AM   #1403
hacker's Avatar
Trader Rating: 140 (100%+)
Blake
I've got a B5 diff in mine at the moment, simply cos the yokomo ball diff was not in stock at the time and had a B5 lying around doing squat. It is a bit of a sloppy fit with the dog bone 'floating' around the B5 outdrives. It's not an ideal setup, but good enough to 'try out' a ball diff in the yz-2. Will be putting a yok diff in soon.
hacker is offline   Reply With Quote
Old 09-23-2015, 08:59 AM   #1404
Trader Rating: 137 (100%+)
So just in case I plan on doing the Ymax mod for my car when it arrives. I lucked out and got my local track directors lightly used Bmax 2 MR V3. for $75.00 bucks (mid-motor parts were never used as he is a rear motor forever guy. What parts do I need from it to do the conversion?
TLR 22T 3.0, TLR 22-4 2.0 , TLR 22 4.0 X2, 22SCT 3.0, Tekno SCT 4X4, Hobbywing, Futaba, LRH Hobbies, Spektrum Servos, iCharger.
jpcopeland1 is offline   Reply With Quote
Old 09-23-2015, 09:11 AM   #1405
Team Tekin
Randy_Pike's Avatar
Thank you
Map? I don't want to fill this Yz2 thread with Tekin stuff. If you wan to discuss the Tekin Gen3 motor lineup, I'd be happy to in another thread
Old 09-23-2015, 09:15 AM   #1406
Team Tekin
Randy_Pike's Avatar
There's a nice list of parts here: http://factory-rc.com/shop/index.php...product_id=100
Since you have all of them off the old car, you're set.
Old 09-23-2015, 10:11 AM   #1407
Nice. Im picking them up today, still want to run it in mostly stock config to see whats up with it. YMax as last resort lol...
Old 09-24-2015, 03:43 AM   #1408
scr8pn4205's Avatar
I just built the yz2 for carpet this winter and all I can say is that if it drives like it built it will be amazing. I cannot get over how easy the build was as the fit and finish was excellent. I have was running a B5m lite so I will see how different it is. Starting with the stock setup for now but with 1.6 2 hole 40wt front and 1.7 2hole 30wt rear asc oil
Airtronics M12
Team Xray XB2 2017 CE
TSR power
scr8pn4205 is offline   Reply With Quote
Old 09-24-2015, 04:57 AM   #1409
8ight-e's Avatar
Trader Rating: 57 (100%+)
Anyone know if the jconcepts 60mm "bullet" style wheels for associated work and keep same offset on this buggy?
Tekno ET48, EB48.2
Durango Fleet - Dex410 v3, Dex210, Desc410, Desc210
8ight-e is offline   Reply With Quote
Old 09-24-2015, 05:07 AM   #1410
Yes.
