    Hide Wikipost
Old 08-10-2017, 01:11 PM   -   Wikipost
R/C Tech Forums Thread Wiki: Yokomo YZ-2
Last edit by: Bob Barry
Welcome to the YZ2 Wiki!
If you edit the page, please add your name and date prior to your addition. While an admin can view the history, this makes it easier for everyone to just check updates. We'll put the newest additions at the top
Setup Sheets can be found here
Print Wikipost
Like Tree40Likes
Old 09-15-2015, 08:23 PM   #1366
Originally Posted by afm223 View Post
A Main is sold out of the Yokomo shims so I am ordering these.
Serpent 5x8x0.1mm Shim (10)
[SER110423]
Just a heads up. I got these in today and they are NOT the right thing.
afm223 is offline   Reply With Quote
Old 09-15-2015, 08:28 PM   #1367
Originally Posted by pumpkinfish View Post
I set mine like Will on the bench. I will begin at a setting where I slowly tighten diff screw until I can't turn diff gear when holding both outdrives from moving. I then have an old bone cut in half that I toss into my DeWalt and spin one out drive while holding the other. I do this for 2 min then switch. I will check diff tightness and then again use DeWalt. I do this 3 to 4 times, then I install diff into car. I will do final setting by holding both rear tires by hand and doing a quick 1 second full throttle squeeze. I look for the front to come off the table about 2 inches. I also try to listen if diff or slipper make noise and adjust accordingly until everything is set where I want it. When I get to the track I will do a few blasts down the front stretch to make sure it is all ok. Then I go race
Thanks, I always break in my ball diffs with a drill. I chuck one side right in the drill and hold the gear in my hand. I start where the gear just starts to turn when spinning the outdrives, then progress in about 1/8-1/4 turn increments.
Old 09-15-2015, 08:54 PM   #1368
Originally Posted by vw addict View Post
Question for the Yokomo experts, can I use A/E big bore pistons in the shocks? I bought a gently used buggy, rebuilt it, redid the shocks and they feel fine but I'd like to switch to 1.6/1.7 instead of "2"/"3" and I have bags of A/E pistons.
Yes! I use my spare AE Pistons in my yok shox!
jake alton is offline   Reply With Quote
Old 09-15-2015, 09:07 PM   #1369
10mm shims are needed for diff out drives. http://www.amain.com/rc-cars/yokomo-...-s100s/p242340
Old 09-16-2015, 06:53 AM   #1370
[QUOTE=jake alton;14185434]10mm shims are needed for diff out drives.
Thanks, I am going to make the drive up to Amain today to pick them up.
Old 09-16-2015, 08:51 AM   #1371
OriginalDonk's Avatar
Trader Rating: 38 (100%+)
Looks like Carson Wernimont officially joined Yokomo today. We all know he's been driving Shin's cars for a few month but now it looks like there's a contract in place. Source is Lee Martin's Facebook page.
It'll be nice to have a top tier American running the YZ-2 on clay tracks throughout the U.S. Look forward to seeing what he does at the Reedy Race here on clay after running with Shin, Lee Martin, and Tom Cockerill at Worlds.
OriginalDonk is offline   Reply With Quote
Old 09-16-2015, 10:06 AM   #1372
mes
...and I use the machined Yokomo pistons in my T5M.
mes is offline   Reply With Quote
Old 09-16-2015, 10:10 AM   #1373
My T5m doesn't deserve machined pistons!!!!! LOL I just wanted to go a step better than "2" for now, I haven't even had the car on turf yet. Slipper lockouts should be at my LHS Friday, and it's game on for Sunday!!!
don't take it too serious, they are toys....
vw addict is offline   Reply With Quote
Old 09-16-2015, 03:19 PM   #1374
suby723's Avatar
Trader Rating: 21 (100%+)
Hey jake how's it going bro. I moved to Nashville Tennessee and my local track is carpet so it's time for the yokomo!
suby723 is offline   Reply With Quote
Old 09-16-2015, 05:29 PM   #1375
Trader Rating: 53 (100%+)
You check out thunder ?
rkhess is offline   Reply With Quote
Old 09-16-2015, 06:03 PM   #1376
suby723's Avatar
Yep but only had clay tires and needed ss. I will return when they have a big race. Extreme hobbies and wildflower are both within 10 minutes from my house.
Old 09-16-2015, 08:20 PM   #1377
Hey Aaron. I was born in Chattanooga Tennessee All is good. So that explains your non presents around here. Wish I could pick up like that and leave this over priced area. Any how the yz2 is a great choice. Wish you all the luck and fun.
Old 09-17-2015, 05:15 PM   #1378
I took my YZ-2 out to the Outback Raceway at Amain this morning for it's first outing. I started the day with my B5M Lite and ran about 20-25 laps with that car before switching to the YZ-2. On the second lap with the YZ I was within .3 of a second of my fastest lap with the B5M. I built my YZ to STLNLNST's setup with the exception of using Associated oil and the kit pistons. The car felt good but maybe a bit soft for Outback. It definitely was a bit edgier than my Associated. I feel confident that with some more time I can have the car dialed. I'm looking forward to seeing how it works at LSR.
Old 09-18-2015, 03:38 PM   #1379
I might be "thick" or something, but I'm not understanding the options on the set-up sheet for the rear hinge-pin holder spacers. I beleive the manual has you inserting both spacers under the hinge pin holders, but the set-up sheet shows an option for above the hinge pin (on the rear-rear). Is that even possible, or am I reading into this wrong?
What does putting the spacer above the rear-rear holder do? Maybe change angle of gearbox? when would you use it?
TLR 22T and Yokomo YZ-2 and 4
www.corvictoria.com
brew99 is offline   Reply With Quote
Old 09-18-2015, 06:57 PM   #1380
WillS's Avatar
Trader Rating: 30 (100%+)
Send a message via MSN to WillS Send a message via Yahoo to WillS
You found out the little secret hehe those spacers are actually for roll center.
No spacers is a low roll center
Spacers installed is a high roll center
Will Smith
Sponsors:
Cheater Racing, Team Powers, Amain.com/Protek, Dialed RC Hobbies, Sweep Racing
WillS is offline   Reply With Quote
