    Hide Wikipost
Old 08-10-2017, 01:11 PM   -   Wikipost
R/C Tech Forums Thread Wiki: Yokomo YZ-2
Last edit by: Bob Barry
Welcome to the YZ2 Wiki!
If you edit the page, please add your name and date prior to your addition. While an admin can view the history, this makes it easier for everyone to just check updates. We'll put the newest additions at the top
Setup Sheets can be found here
Print Wikipost
Like Tree42Likes
Old 09-12-2015, 08:15 PM   #1351
Originally Posted by Motorman007 View Post
You have the part number for the shims
A Main is sold out of the Yokomo shims so I am ordering these.
Serpent 5x8x0.1mm Shim (10)
[SER110423]
afm223 is offline   Reply With Quote
Old 09-13-2015, 12:03 PM   #1352
Motorman007's Avatar
Trader Rating: 76 (100%+)
Well did some testing
Ball diff
28 g under tran.
1630g total. Got it down
8.5t
Just can't put the power down and have the rear hold. On a dry track. On race day traction is up. On practice days like today not good. .
Two options y-max or smc bass 100 in the rear which is better?
YOU WILL (ALWAYSWIN).....
Motorman007 is online now   Reply With Quote
Old 09-13-2015, 07:00 PM   #1353
WillS's Avatar
Trader Rating: 30 (100%+)
Send a message via MSN to WillS Send a message via Yahoo to WillS
I have done the weight. Go the Y-max route...
Will Smith
Sponsors:
Cheater Racing, Team Powers, Amain.com/Protek, Dialed RC Hobbies, Sweep Racing
WillS is offline   Reply With Quote
Old 09-14-2015, 08:17 AM   #1354
pumpkinfish's Avatar
Originally Posted by WillS View Post
Try this one to start.
Will, do you have a larger, more clear version of this? Some of the text is hard to read.
Yokomo YZ-2, B-Max4 III
Kyosho RT6
Losi 22b, XX4 Worlds
Associated SC10.2, RC10B2, RC10T2, RC10
pumpkinfish is offline   Reply With Quote
Old 09-14-2015, 08:21 AM   #1355
Team Tekin
Randy_Pike's Avatar
Send a message via Yahoo to Randy_Pike
Here you are:
http://www.petitrc.com/setup/yokomo/...ceway20150901/
"Things may come to those who wait, but only the things left by those who hustle." Abraham Lincoln
Tekin,Protek,A-Main Hobbies,KoPropUSA,JConcepts,Avid RC,MIP,SikLidz,ImagineItGraphx, FactoryRC, www.randypikerc.com
Randy_Pike is offline   Reply With Quote
Old 09-14-2015, 08:37 AM   #1356
What Yokomo, Losi or AE springs are closest to the Avid springs?
Kyosho RT6
Old 09-14-2015, 09:13 AM   #1357
Team Tekin
Randy_Pike's Avatar
I believe they're all close or offer one that' close. Losi's are easy enough to find.... Yellow rears and orange fronts look close.
Old 09-14-2015, 10:46 AM   #1358
Fresh shell on my YZ-2
Headling is offline   Reply With Quote
Old 09-14-2015, 08:14 PM   #1359
Do you build the Yokomo ball diff just like an Associated diff? Full tight, then back 1/8 turn?
Old 09-14-2015, 08:59 PM   #1360
WillS's Avatar
Its a good start but I gave up on using that setting a long time ago. I set it until the diff stops barking on a bench test. Diff balls and thrusts are way better now of days than they were in the past.
Will Smith
Sponsors:
Old 09-14-2015, 09:06 PM   #1361
Thanks, I will give that a go.
Old 09-15-2015, 08:28 AM   #1362
Seting the ball diff. The bmax2 instructions from memory said tighten till it stops. Don't back off at all. May want to tighten easily till stop. Or may want to check on the bmax instructions.
jake alton is offline   Reply With Quote
Old 09-15-2015, 10:41 AM   #1363
I set mine like Will on the bench. I will begin at a setting where I slowly tighten diff screw until I can't turn diff gear when holding both outdrives from moving. I then have an old bone cut in half that I toss into my DeWalt and spin one out drive while holding the other. I do this for 2 min then switch. I will check diff tightness and then again use DeWalt. I do this 3 to 4 times, then I install diff into car. I will do final setting by holding both rear tires by hand and doing a quick 1 second full throttle squeeze. I look for the front to come off the table about 2 inches. I also try to listen if diff or slipper make noise and adjust accordingly until everything is set where I want it. When I get to the track I will do a few blasts down the front stretch to make sure it is all ok. Then I go race
Kyosho RT6
Old 09-15-2015, 03:45 PM   #1364
WillS's Avatar
This is a great video that shows the way I do it. Do not mind the vehicle he uses, not everyone knows the potential of the Yokomos.
https://www.youtube.com/watch?v=RoJgZgnk1aA
Will Smith
Sponsors:
Old 09-15-2015, 08:11 PM   #1365
Trader Rating: 38 (100%+)
Question for the Yokomo experts, can I use A/E big bore pistons in the shocks? I bought a gently used buggy, rebuilt it, redid the shocks and they feel fine but I'd like to switch to 1.6/1.7 instead of "2"/"3" and I have bags of A/E pistons.
don't take it too serious, they are toys....
vw addict is offline   Reply With Quote
