    Hide Wikipost
Old 08-10-2017, 01:11 PM   -   Wikipost
R/C Tech Forums Thread Wiki: Yokomo YZ-2
Last edit by: Bob Barry
Welcome to the YZ2 Wiki!
If you edit the page, please add your name and date prior to your addition. While an admin can view the history, this makes it easier for everyone to just check updates. We'll put the newest additions at the top
Setup Sheets can be found here
Print Wikipost
Like Tree42Likes
Old 09-11-2015, 07:00 PM   #1336
WillS's Avatar
Trader Rating: 30 (100%+)
Send a message via MSN to WillS Send a message via Yahoo to WillS
In testing we are seeing no need to go to the longer arms. The YZ arms are providing enough traction and stability.
Will Smith
Sponsors:
Cheater Racing, Team Powers, Amain.com/Protek, Dialed RC Hobbies, Sweep Racing
WillS is offline   Reply With Quote
Old 09-11-2015, 08:04 PM   #1337
Motorman007's Avatar
Trader Rating: 76 (100%+)
THANK Sir.
Could you post your high med traction setup please sir
YOU WILL (ALWAYSWIN).....
Motorman007 is offline   Reply With Quote
Old 09-11-2015, 08:55 PM   #1338
WillS's Avatar
Try this one to start.
Will Smith
Sponsors:
Old 09-11-2015, 11:25 PM   #1339
mes
The longer arms are great on astroturf, they make car even more stable and less prone to traction rolling. In these conditions, the front gullwing set-up will also be interesting for you.
If traction is not that high, you will be good with the std arms.
In case you want to convert your rear end, it is:
B2-008R and
B2-010RB
mes is offline   Reply With Quote
Old 09-12-2015, 05:49 AM   #1340
Wills
And
Mes.
Old 09-12-2015, 08:41 AM   #1341
I just started building my YZ-2 yesterday. I bought the ball diff, but when I assembled the gearbox there is a ton of side to side play in the diff. What shims are you guys using to eliminate this? Also are there any other parts needed when using the ball diff? Also, are the machined pistons a worthwhile upgrade? Trying to just make one more order with A-Main. I am looking forward to getting this on the track next Friday night at LSR.
afm223 is offline   Reply With Quote
Old 09-12-2015, 10:12 AM   #1342
Team Tekin
Randy_Pike's Avatar
Send a message via Yahoo to Randy_Pike
I'm actually running the gear diff in mine at the moment with 2k fluid and am happy so far. Note that I'm on a track that does run slicks.
Avid 1.6x2 fronts, and 1.7x2 rears is what I have in my car. They work great.
"Things may come to those who wait, but only the things left by those who hustle." Abraham Lincoln
Tekin,Protek,A-Main Hobbies,KoPropUSA,JConcepts,Avid RC,MIP,SikLidz,ImagineItGraphx, FactoryRC, www.randypikerc.com
Randy_Pike is offline   Reply With Quote
Old 09-12-2015, 12:40 PM   #1343
I think it takes .2mm of shims on each side of the ball diff. May want to get .1mm shims to set correctly.
jake alton is offline   Reply With Quote
Old 09-12-2015, 12:53 PM   #1344
B2-008R and
B2-010RB
Mes....Are the longer rear arms the B2-008r or the B4-008r? All the set-up sheets I've seen seem to have the arms from the B-Max4 not the 2wd? I have no idea what the differences are, just want to order the correct ones
TLR 22T and Yokomo YZ-2 and 4
www.corvictoria.com
brew99 is offline   Reply With Quote
Old 09-12-2015, 01:06 PM   #1345
Moderator
MarkA's Avatar
Trader Rating: 21 (100%+)
The B4-008r arms are the wider ones. You need the Bmax2 rear driveshafts to make them work. My experience has been that a track has to be at a capital "H" level of high-bite for them to actually be an improvement though - they're not something you need to change just for the sake of change.
MarkA is offline   Reply With Quote
Old 09-12-2015, 01:13 PM   #1346
OK thanks MarkA...Can I use the Bmax2 dogbones (B2-010RB) with the longer A-arms, or do I need to get the entire drive line (Out of Stock at A-main now)?
www.corvictoria.com
Old 09-12-2015, 01:21 PM   #1347
Moderator
MarkA's Avatar
The outer axle should be the same so yes, you could change only the bones. However, if your existing setup has seen any significant track time, especially on high grip, I would recommend getting new BM-010TPC pins/joints at the same time as you change those bones.
Old 09-12-2015, 02:52 PM   #1348
Thanks, I will order up some .1 shims. They come in a 10 pack so I should be set.
Old 09-12-2015, 03:13 PM   #1349
perfect, thanks again MarkA....gonna do that then as I run on commercial grade real carpet, which is quite high bite for sure. It's a new build, just want it as an option
www.corvictoria.com
Old 09-12-2015, 03:21 PM   #1350
You have the part number for the shims
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
