    Hide Wikipost
Old 08-10-2017, 01:11 PM   -   Wikipost
R/C Tech Forums Thread Wiki: Yokomo YZ-2
Last edit by: Bob Barry
Welcome to the YZ2 Wiki!
If you edit the page, please add your name and date prior to your addition. While an admin can view the history, this makes it easier for everyone to just check updates. We'll put the newest additions at the top
Setup Sheets can be found here
Print Wikipost
Like Tree39Likes
Old 09-04-2015, 06:54 AM   #1306
Motorman007's Avatar
Trader Rating: 76 (100%+)
All this weight stuff. I'm about to scale my buggy.
YOU WILL (ALWAYSWIN).....
Motorman007 is offline   Reply With Quote
Old 09-04-2015, 07:31 AM   #1307
Info on my Buggy.
I have these items on my buggy.
Yokomo Aluminum Rear Camber Block w/Optional Weights
[YOKZ2-300RUW]
12 grams.
Yokomo Steel Rear-Front Suspension Mount
[YOKZ2-300SRF]
This mount weighs about 12g.
Yokomo Steel Rear-Rear Suspension Mount
[YOKZ2-300SRR]
This mount weighs about 13g.
I also, Have 7 lead weights at 7g each.
Total 49g under the Tran box.
Zero Wheels or Pack
Old 09-04-2015, 07:33 AM   #1308
Zero Wheels w/ pack
Old 09-04-2015, 07:34 AM   #1309
Wheels zero Battery
Old 09-04-2015, 07:36 AM   #1310
Wheels and Pack
Old 09-04-2015, 07:37 AM   #1311
Body on
Old 09-04-2015, 07:39 AM   #1312
Trader Rating: 81 (100%+)
Originally Posted by Motorman007 View Post
Body on
Damn, my stadium truck weighs 1790.
dpcardoza is offline   Reply With Quote
Old 09-04-2015, 07:59 AM   #1313
Added 86g
1194
1439 With pack my pack must be
-245 pack must
1194
1426 with wheels
-232 wheels and tires and foam
1194
1688 with pack and wheels
494 with pack and wheels
1194
1688 w/body
Body 42 g? WOW to much paint?
RTR
1730
Gain 536 total weight RTR
Now where can I loss some weight?
Or my tires and wheels to heavy?
Is my pack to Heavy?
Old 09-04-2015, 08:16 AM   #1314
Supertruck1's Avatar
That seems awfully heavy......my car, ready to run, minus the body, is 1551 grams. The car has titanium tierods and screws, but ive also added 80g of tungsten under the transmission.
Tekno Rc
Carpy's
SMC Racing
Supertruck1 is offline   Reply With Quote
Old 09-04-2015, 08:20 AM   #1315
Less wires and large plugs. Screws and tie rods change for titanium. Don't paint windows of body, and light Coates of paint.
jake alton is offline   Reply With Quote
Old 09-04-2015, 08:30 AM   #1316
WillS's Avatar
Trader Rating: 30 (100%+)
Send a message via MSN to WillS Send a message via Yahoo to WillS
When you measure a car on scales it always has to be supported by the axle in order to get a true measurement. By setting it on the arm you are not allowing the suspension to relax and move the weight where it needs to go.
That viper is a very heavy esc (over 60g without wires). That connector is also adding a ton of weight. I recently redid my yz (y-max conversion), only real hopup I have is titanium turnbuckles I am at 1520 with 25g added to the car.
Will Smith
Sponsors:
Cheater Racing, Team Powers, Amain.com/Protek, Dialed RC Hobbies, Sweep Racing
WillS is offline   Reply With Quote
Old 09-04-2015, 08:48 AM   #1317
Originally Posted by DS1969 View Post
With tires and no body it's at 1630gr I think but will be at the track today and will weigh it to make sure. I can remove 2 of the brass plates I have behind the shorty and it will be 60gr lighter. I could also remove the Yokomo rear camber link aluminum part as when I put it on it really didn't change how the car ran so I just left it on there as my lap times were pretty much the same.
I feel that I have made the car way more stable and the good thing is it should be very easy to make the car lighter and add steering if need be. By removing the 2 brass plates behind the shorty and the brass part in front of the motor this reduces the weight by 94gr. I can also remove the rear aluminum camber link part which I think is around 15gr more than the plastic one.
He is at 1630gr
Me 1688 w/body
I'm a 58gr over him.
So if I take off all the weight 101 total it will be 1587. All the dang wiring and plugs.
Old 09-04-2015, 10:41 AM   #1318
No Pack wiring.
took off 29g along.
Took off all the weight.
Old 09-05-2015, 07:24 AM   #1319
I'm having trouble getting my steering setup to get full throw both directions..... I can make it lockout to the left, but still 2-3mm from locking to the right. I've tried shortening the arm, lengthening the arm, offsetting the servo horn, I just can't get it. Is it not supposed to go lock to lock ?
Tekno Rc
Carpy's
SMC Racing
Old 09-05-2015, 07:56 AM   #1320
Jim Hughes's Avatar
i cant remember any car ive ever ran lock to lock on if you could you probably couldnt drive it too much steering just set it even at the most throw you can get then adjust downward with dual rate
Jim Hughes is offline   Reply With Quote
Currently Active Users Viewing This Thread: 6 (2 members and 4 guests)
fantomdude, rcgerber
