    Hide Wikipost
Old 08-10-2017, 01:11 PM   -   Wikipost
R/C Tech Forums Thread Wiki: Yokomo YZ-2
Last edit by: Bob Barry
Welcome to the YZ2 Wiki!
If you edit the page, please add your name and date prior to your addition. While an admin can view the history, this makes it easier for everyone to just check updates. We'll put the newest additions at the top
Setup Sheets can be found here
Print Wikipost
Like Tree43Likes
Old 08-27-2015, 06:52 PM   #1276
Motorman007's Avatar
Trader Rating: 76 (100%+)
86 in parts screws and stuff.
Plus factory 57 so he was right $150 to turn it into a Y-MAX
YOU WILL (ALWAYSWIN).....
Motorman007 is offline   Reply With Quote
Old 08-28-2015, 07:56 AM   #1277
What is the function of the rubber pads under the diff housing and motor plate support? The one under the little motor plate support just squishes out when I tighten down the two screws thru the chassis
TLR 22T and Yokomo YZ-2 and 4
www.corvictoria.com
brew99 is offline   Reply With Quote
Old 08-28-2015, 09:11 AM   #1278
OriginalDonk's Avatar
Trader Rating: 38 (100%+)
I've been running my YZ-2 and damn I love the cornering, just hoping for a touch more bite. Ended up trying one of these yesterday and found it helped quite a bit. Not RM bite but closer to B5M bite territory.
http://www.amain.com/rc-cars/revolut...rp0011/p231348
OriginalDonk is offline   Reply With Quote
Old 08-28-2015, 09:25 AM   #1279
Team Tekin
Randy_Pike's Avatar
Send a message via Yahoo to Randy_Pike
I don't like having to add weight to the car just to find grip. This is why I have the Y-max a try. No additional weight, just the grip and handling I was looking for.
"Things may come to those who wait, but only the things left by those who hustle." Abraham Lincoln
Tekin,Protek,A-Main Hobbies,KoPropUSA,JConcepts,Avid RC,MIP,SikLidz,ImagineItGraphx, FactoryRC, www.randypikerc.com
Randy_Pike is offline   Reply With Quote
Old 08-28-2015, 09:42 AM   #1280
Jpdanger's Avatar
I think the YZ-2 suffers from the same problem as the Schumacher KF2. There isn't enough rearward weight since the motor is further forward than other MM cars like the B5M, RB6, BMax, etc. Since the motor is closer to the CG, the forces the motor exerts on the chassis are lessened due to the shorter leverage. Adding weight helps a bit, but it ultimately only makes the car heavier.
I buy RC cars for my kids like a man buys a bowling ball with his name on it for his wife.
"What I say makes sense in my head. Once it comes out of my mouth it's for you to figure out." -me
Jpdanger is offline   Reply With Quote
Old 08-28-2015, 09:42 AM   #1281
What are the Yokomo Graphite Steering Block Set and the other Graphite items used for?
High bite tracks
Found it lol
This is an optional pair of Yokomo Graphite Front Steering Hub Carriers, with included hub inserts.
These hubs provide improved durability, stability and steering response on high-bite surfaces.
Is this needed?
Old 08-29-2015, 02:09 AM   #1282
mes
High bite tracks
Found it lol
Is this needed?
Some people will find the need for it, some don't. If your car bounces a little after jumps with perfectly maintained shocks or if you want a more direct feel, give them a try.
mes is offline   Reply With Quote
Old 08-30-2015, 10:30 PM   #1283
I tested out my YZBMaX2! It worked very well on hard pack clay, medium to high bite traction. The car felt very solid and stable. i could push the car much harder through out the entire track! Highly recommend trying the bmax2 tranny change!
jake alton is offline   Reply With Quote
Old 09-01-2015, 08:26 PM   #1284
Default YZ-2 Setup for Mod on lower bite tracks.
I've been running the YZ-2 in mod for awhile now and run on a track that is low to low/medium bite at best. As mentioned in my previous posts the YZ-2 out of the box has way more front end weight and less rear weight than most other cars. I also believe the front end is very strong on this car as I built a YZ-2 with Bmax-2 transmission and it still has very good steering even if it has 2% more rear weight than my YZ-2. After spending 2 weeks testing the YZ-2 and the YZmax I've come to the conclusion that the way I have my YZ-2 setup it's every bit as good if not better than the YZmax.
I run M4 Electrons at my local track and it's hard packed clay that is mostly dry so traction is not the best.
I've put my setup in 2 pictures as the PDF file was a bit to big and some pictures of the brass parts I use and my car.
The key things on my setup are the B-max4iii rear arms as these give a bit more rear bite.
MIP pucks I feel these improve forward bit and keep the rear end working the same all the time.
Inside hole on the rear arms. This helps stability/traction in my opinion.
Front end is also adjusted to make it less aggressive.
The results is a car that still has very good steering and much more stable and easier to drive. In fact I'm so confident in the YZ-2 the way I have it setup that I'm building the YZmax back into a YZ-2.
I know many want to try the Bmax-2 transmission but I feel there is no need to if you give my setup and parts I use a try. The brass parts will be available around the 15th of September from SMC and are on pre-order now.
The brass front rear pivot weighs 68.8gr and the brass part that replaces the L brace in front of the motor weighs 34.1gr.
Yokomo YZ-2-yz2p1.jpg   Yokomo YZ-2-yz2p2jpg.jpg   Yokomo YZ-2-yz-2frrearpivot.jpg   Yokomo YZ-2-yz-2lbracebrass.jpg   Yokomo YZ-2-yz-2brassinstalled.jpg
DS1969 is offline   Reply With Quote
Old 09-01-2015, 10:07 PM   #1285
Trident69's Avatar
Hi DS1969,
thank you sharing your setup, which i am very much incline to try it out.
however, and i understand that we will need ball diff for this, but unfortunately, we only have the stock gear diff on hand. our local track is sandy and very loose traction, do you have any advise how heavy the diff oil should be?
cheers!
"Power is nothing without Control"
Yokomo - Yz-2/Yz-2 DT/ Yz-4 / Bmax2MR/Bmax 4/3
Xray - XB4'16
Awesomatix - Evo 2
Trident69 is offline   Reply With Quote
Old 09-01-2015, 10:14 PM   #1286
Sorry I've never ran the gear diff. If this is all you have then I would try 1000 oil but I believe in low to medium bite a ball diff will give you better results.
Another thing to note is the rear pills are done to give 4 degrees of toe-in which I forgot to mention. The key to my setup is the extra rear weight. You can still try it without the brass parts and see if it helps. I've spent allot of time testing various setup changes and so far this setup has been the one that generates the most stability.
Old 09-01-2015, 10:19 PM   #1287
Which Puck system are you currently using? I know many of us are leaning on MIP to produce a YZ-2 specific set of alloy pucks for 17.5 and I imagine Shiny Pucks for mod.
Thanks for posting your setup.
Old 09-01-2015, 10:31 PM   #1288
What is the overall weight of the car with all the brass added?
Old 09-01-2015, 10:58 PM   #1289
Trident69's Avatar
thank you so much, will try it out..cheers!!
Xray - XB4'16
Awesomatix - Evo 2
Old 09-02-2015, 05:08 AM   #1290
Also, how did you get 4 deg of toe?
Did you use the .5 rear hubs?
Or the 1.0 rear hubs and 3 deg pills?
( B-max4iii rear arms)
Do you not need the longer axle?
And can you just buy the longer part of the cvd? And who had then in stock? Don't need to full set. Amain is out of them..
Yokomo Rear Universal Bone
[YOKB2-010RB]
Thank you
