Yokomo YZ-2
#1261
#1262
The Y-max shines were the Yz2 may struggle when traction isn't optimal. My local rack also may run gold dirtwebs or even barflys however if the track is damp, slicks work very well also. However if the track is a little dry, the slicks don't work of course and this is where a stock Yz2 would struggle, and where the Y-max does well. The Y-max doesn't lose the pace when traction isn't ideal. Where the Yz2 must have really good traction to be on point.
#1263
#1264
Would adding more weight to the rear of the buggy help vs changing the Diff housing?
#1265
A lot of us have added weight to the rear (up to 100g) with no prevail. From those I have heard doing the swap they were excited with the performance. I heard through the rumor mill that Factory RC should have a conversion kit (minus the transmission) for all YZ owners to convert the cars over. What is great about the kit, is really 2 screw hole drilled and its bolt in. There are other things I have done to mine but not really necessary.
#1266
You could do this, but part of this change is raising the transmission parts and motor height CG. This provides much needed weight transfer, increasing grip.
#1267
Sounds like to be safe have the Max setup Diff and brace on hand if the tracks you go to is low bite.
What is the Cost to change this 10min job over to Y-Max?
Is the inside gears the same for max diff housing?
Thank you
Thank you
#1268
Cost-wise I would say you might be in it around $100-150 depending on option parts you buy but your car would work be the ultimate all year work horse.
#1269
Does the buggy just wash out on low bite track? A$$ happy coming out of the turns?
Anyone have a video of Yz2 on a loose track? Thanx again for everyone help.
#1271
I compensate with a square pack, brass front and rear bulkheads, and weight behind the transmission 1/2 oz, and under steering rack 1/4 oz and it works fine.
Granted not as locked down as a rear motor in loose stuff.
#1272
Thank you all.
I have yet to put it on the track. Just getting all the info i can on this Buggy.
