    Hide Wikipost
Old 08-10-2017, 01:11 PM   -   Wikipost
R/C Tech Forums Thread Wiki: Yokomo YZ-2
Last edit by: Bob Barry
Welcome to the YZ2 Wiki!
If you edit the page, please add your name and date prior to your addition. While an admin can view the history, this makes it easier for everyone to just check updates. We'll put the newest additions at the top
Setup Sheets can be found here
Print Wikipost
Like Tree63Likes
Old 08-23-2015, 05:40 PM   #1246
Originally Posted by Jim Hughes View Post
anyone know of good servo mounts that have 4 holes to hold servo not really liking the stock setup
Drill and tap 2 more holes. Their is nothing wrong with stock set up,
jake alton is offline   Reply With Quote
Old 08-24-2015, 12:59 PM   #1247
Club races are all high bite indoor carpet and medium traction outdoor turf.
stock class 17.5
What batteries is everyone running. with what ratings for power and weight. I've been trying to find a good weight balance setup, by switching from a shorty to a super shorty it shaved 70 grams but I feel like the buggy needed that extra weight. Also it may have been under legal weight.
Should I go with a heavier battery or add some weights to certain areas of the buggy. Any technical advice on the matter would be much appreciated.
thanks
Franzchise is offline   Reply With Quote
Old 08-24-2015, 01:14 PM   #1248
Team Tekin
Randy_Pike's Avatar
Send a message via Yahoo to Randy_Pike
The car can already be under weight with a regular shorty and regular equipment depending on what you're using.
"Things may come to those who wait, but only the things left by those who hustle." Abraham Lincoln
Tekin,Protek,A-Main Hobbies,JConcepts,Avid RC,Yokomo,MIP,SikLidz,FactoryRC, www.randypikerc.com
Randy_Pike is offline   Reply With Quote
Old 08-24-2015, 01:22 PM   #1249
Im aware of this now, so I might as well go back to a shorty and add weight from there, rather then using a super shorty and having to add double the amount of weights in my car.
Even so if I need weight where to add?? I was going to drop 21g near the servo??
Any recommendations on a good performing shorty. My club used mainly (new wave's) which I don't really like. So I'm looking for some advice on that.
thanks
Old 08-24-2015, 01:33 PM   #1250
Team Tekin
Randy_Pike's Avatar
I've been having great success with these as has our team drivers:
http://www.amain.com/rc-cars/protek-...100-15/p423773
Old 08-24-2015, 02:13 PM   #1251
I heard good things about Protek but being as it is 60- 75 grams lighter, where would I make up the weight.
Old 08-24-2015, 02:52 PM   #1252
Moderator
MarkA's Avatar
Trader Rating: 21 (100%+)
By putting these under the battery.
MarkA is offline   Reply With Quote
Old 08-24-2015, 03:15 PM   #1253
But then aren't the benifits of a lighter battery negated.
Is it still the most powerful shorty? Would someone be better off getting a heavier battery (if there is one better then the prtek surprem power shorty), not using the weights
Old 08-24-2015, 03:36 PM   #1254
Moderator
MarkA's Avatar
Running a short-shorty with the weights under it still produces a lower CoG than running a "tall" pack. That can be particularly helpful on high-grip surfaces.
Old 08-24-2015, 09:15 PM   #1255
thanks
I run with 28 grams under the tranny up against the C plate.
Old 08-26-2015, 04:24 AM   #1256
Just use the stock ones and use shoe goo or servo tape under the servo to minimize movement.
RaceToTheBottom is offline   Reply With Quote
Old 08-26-2015, 07:30 AM   #1257
Motorman007's Avatar
Trader Rating: 78 (100%+)
New Option Parts for Yokomo YZ-2 2WD Off Road Buggy
http://teamyokomo.blogspot.com/2015/...-yz-2-2wd.html
YOU WILL (ALWAYSWIN).....
Motorman007 is offline   Reply With Quote
Old 08-27-2015, 12:36 AM   #1258
Jim Hughes's Avatar
Originally Posted by largoo View Post
Here is my Y-Max2
what did you make the adapter for the batterybrace with do you have an extra for sell
Jim Hughes is offline   Reply With Quote
Old 08-27-2015, 01:17 AM   #1259
The battery brace extender is made from aluminium. Sure i can make one for you if you want to buy one.
You need to drill two countersunk holes to the original battery brace.
largoo is offline   Reply With Quote
Old 08-27-2015, 05:13 AM   #1260
Let me make sure I'm on the same page about thr Y-Max change.. Is this change for loose track aka low bite tracks?
And the YZ2 works grear in high bite tracks and on astro turf?
Y-MAX setup adds more weight to the rear to gain traction with out losing out on the YZ2 steering?
My track is high bite. We run Dirtwebs gold around. Would Dave B. Setup be a good starting point or the stock setup?
This will be a 17.5t build kit.
This is my kit weight with out tires and wheels and body..
Yokomo YZ-2-20150822_200511.jpg   Yokomo YZ-2-20150822_191711.jpg   Yokomo YZ-2-20150822_191817.jpg   Yokomo YZ-2-20150822_191807.jpg
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
