    Hide Wikipost
Old 08-10-2017, 01:11 PM   -   Wikipost
R/C Tech Forums Thread Wiki: Yokomo YZ-2
Last edit by: Bob Barry
Welcome to the YZ2 Wiki!
If you edit the page, please add your name and date prior to your addition. While an admin can view the history, this makes it easier for everyone to just check updates. We'll put the newest additions at the top
Setup Sheets can be found here
Print Wikipost
Like Tree42Likes
Old 06-15-2015, 03:46 AM   #1111
Hi guys, this weekend was the first round of Finnish nationals at Vaasa. My YZ-2 was dialed, even on morning when track was damp. My setup is at PetitRC
-Joel
Joel_V is offline   Reply With Quote
Old 06-15-2015, 07:27 AM   #1112
wstuart's Avatar
Trader Rating: 112 (98%+)
Send a message via AIM to wstuart
Originally Posted by RaceToTheBottom View Post
Have you guys had any trouble with the plastic rear hubs? I want to try them on my bmax2, but someone told me they break easy.
Yes I have. The ball stud can strip out laterally because there isn't alot of support around the plastic (because of all the holes). To fix this I've put long set screws into the holes around the ball stud.
Yokomo Yz-2 x2
Yokomo B-max4iii
Awesomatix a700 evo
Team El Cajon Hobbies
wstuart is offline   Reply With Quote
Old 06-15-2015, 01:25 PM   #1113
Originally Posted by st.ray View Post
Does anyone know how moving the rear linkage on the hub to the forward or aft holes will affect handling? I've read all the setup guides and google searched but never really found a good answer. Theres got to be a good enough reason for 6 holes
Forward gives more rotation. More aggressive feeling. Back is less aggressive less rotation makes rear much more lazy.
jake alton is offline   Reply With Quote
Old 06-15-2015, 02:44 PM   #1114
Captcha's Avatar
Question, what wheels are everyone using 60mm tires seem to be popular at the local track.
Captcha is offline   Reply With Quote
Old 06-15-2015, 03:22 PM   #1115
KrAcOn's Avatar
I like to use the Pro-Line Velocity "VTR". They are lighter than JC and they protect the wheel nuts.
AE:RC10B5ML,B5M,B4.2,B44.3,B3,RC10TeamRPM,Rc10T,RC10B64D
Yokomo:YZ-2 LD,YZ-2 DT,YZ-4 and MX4
LRH RACEWAY So. Cal
KrAcOn is offline   Reply With Quote
Old 06-15-2015, 05:02 PM   #1116
Captcha's Avatar
Brand isn't the question, I am more worried about which chassis specific really. I.e. B5m, Rb6, 22, etc. Which chassis is the best closest to the offset.
Old 06-15-2015, 06:02 PM   #1117
WillS's Avatar
Trader Rating: 30 (100%+)
Send a message via MSN to WillS Send a message via Yahoo to WillS
b5/rb6 front
b5 rear, some rb6 fit but the AE rear tends to allow for more grip on the nut
Will Smith
Sponsors:
Cheater Racing, Team Powers, Amain.com/Protek, Dialed RC Hobbies, Sweep Racing
WillS is offline   Reply With Quote
Old 06-16-2015, 04:35 AM   #1118
Captcha's Avatar
Originally Posted by WillS View Post
b5/rb6 front
Thank you! I am looking forward to giving this buggy a try.
Old 06-18-2015, 09:36 PM   #1119
xxx-ntad2 racer's Avatar
Trader Rating: 24 (100%+)
hey guys, got a question for everyone who has this buggy.
im really thinking about buying this buggy for my next kit. currently i run a hobbypro usa prs1 and like it alot, i just like to switch up brands every once and a while. so my question is, what are some suggestions on parts that may need upgrading before it even hits the track? in other words, is there any parts that should be upgraded or built differently to prevent failure before car hits turf? thanks.
Hobby Pro USA
www.Hobbyprousa.com
xxx-ntad2 racer is offline   Reply With Quote
Old 06-18-2015, 10:34 PM   #1120
Moderator
MarkA's Avatar
Trader Rating: 21 (100%+)
For durability, basically nothing. You may want the ti turnbuckles if not having them bothers you but this car will make the hobbypro look toy-grade next to it. You will want to get the under-battery weights and some variation of weighted front bulkhead/weight for the stock bulkhead for setup though as well as the machined shock pistons but otherwise, it's good to go, especially for turf.
MarkA is offline   Reply With Quote
Old 06-19-2015, 04:45 AM   #1121
Car is great as it comes out of the box. No options needed.
株式会社 ヨコモ
dennisV is offline   Reply With Quote
Old 06-19-2015, 08:55 AM   #1122
Hi guys,i gonna get a yz2 next couple of days soon. any idea which model of motors is suit for the kit.☺
ts chan is offline   Reply With Quote
Old 06-19-2015, 09:25 AM   #1123
Moderator
MarkA's Avatar
What are the class rules you'll be using and what surface are you racing on?
Old 06-19-2015, 04:02 PM   #1124
I will be running in a 1/10 scale track and is solid ground with carpet ramp☺
Old 06-20-2015, 01:27 AM   #1125
ralphee's Avatar
Weight is your biggest friend, i run 20g in front of the servo, 50g under the lipo, and use the brass rear hangers that gives me 18g in the rear, car is much more planted and stable.
Springs for sure but that will depend on your surface/track, but i did have a blinding meeting last week on kit springs, sure, the car was soft, too soft for carpet really, but was so planted and a lot of fun to drive in that set up.
TBH, there isnt much id say you need to mod or buy, its spot on from the get go, but if your running on high grip, try 4mm spacers on the front ackerman plate, really helps!
lee
ralphee is offline   Reply With Quote
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
Y8Duster
