    Hide Wikipost
Old 10-18-2017, 07:19 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Yokomo YZ-2
Last edit by: Bob Barry
Welcome to the YZ2 Wiki!
If you edit the page, please add your name and date prior to your addition. While an admin can view the history, this makes it easier for everyone to just check updates. We'll put the newest additions at the top
Setup Sheets can be found here
DT CA DTM parts comparison
Print Wikipost
Like Tree102Likes
Old 06-01-2015, 10:58 PM   #1096
cclifton's Avatar
Send a message via MSN to cclifton
Originally Posted by joeymdz View Post
Tell management to put carpet in there! 3 out of 6 Oregon indoor tracks are on carpet (hint hint )
Id love carpet...I miss onroad racing since I moved here. The cost of the carpet to cover our track area of 6000 square feet is more then the owners can afford. Its pretty tight there on money right now with us loosing racers all the time
The Fleet:Xray:XT2 - Associated B6, B64 - Serpent SRX2 MH
Poorboy Raceway and Hobbies
Grants Pass, OR
cclifton is offline   Reply With Quote
Old 06-02-2015, 04:55 PM   #1097
KrAcOn's Avatar
Originally Posted by hollywood3705 View Post
Here you go. I took out the center then I beveled the right and left sides to gain flex and allow the wire to clear. I'm also going to raise the waterfall up with 1.5 mm worth of plastic washers to better clear my wires
Wow that looks very clean and sexy.
AE:RC10B5ML,B5M,B4.2,B44.3,B3,RC10TeamRPM,Rc10T,RC10B64D
Yokomo:YZ-2 LD,YZ-2 DT,YZ-4 and MX4
LRH RACEWAY So. Cal
KrAcOn is offline   Reply With Quote
Old 06-02-2015, 05:18 PM   #1098
hollywood3705's Avatar
Thank you. I do offer my services for building and wiring. I enjoy it.....Pm if anyone us interested we can discuss it
Amain.com / Protek / VRP / The Ohio R/C Factory / The Bearded Wonder
hollywood3705 is offline   Reply With Quote
Old 06-03-2015, 12:26 AM   #1099
MikeO's Avatar
What 3 tracks are on carpet? Premier and RC Plus, but who else?
MikeO is offline   Reply With Quote
Old 06-03-2015, 09:25 AM   #1100
Moderator
MarkA's Avatar
Trader Rating: 21 (100%+)
The indoor track at Santiam is still there; they raced some Friday nights over the winter/spring so among indoor tracks the split is 3/3. The key metric though is that, for example, a "small" night on carpet at RCP is 30%+ bigger than a "good" turnout on clay at NW these days. On Weds 5/20, Premier outdrew the outdoor track that was running on Saturday 5/23 even; something previously unheard of for an indoor track to do in the northern part of the state, regardless of surface, once outdoor season started.
We're a carpet state and that snowball is running downhill but that's probably enough highly regionalized surface discussion for now in here - there's a thread for that here: Carpet/Astro tracks in the US
MarkA is offline   Reply With Quote
Old 06-03-2015, 11:33 AM   #1101
MikeO's Avatar
Ahh, forgot about Santiam! Well I know a bunch of us southern Oregon guys wish we could come have some fun with the northern Oregon guys more often!
Old 06-03-2015, 12:40 PM   #1102
Moderator
MarkA's Avatar
Setup item some might want to try - if running with the L brace pulled as discussed a couple pages ago - try also pulling the gearbox spacer sheet. You get back some of the on-power rotation you lose from having pulled the brace, lower the cg slightly and around the rest of my setup on my particular track (carpet) at least, seem to carry a touch more corner speed.
Old 06-06-2015, 08:09 PM   #1103
I purchased a kit the other day and finished building the roller, but I have this part left over and can't see where I would have missed it, can someone please point me in the right direction?
suchislife is offline   Reply With Quote
Old 06-06-2015, 08:12 PM   #1104
It's in the back of the manual one of the last build pages. It's used to space back the rear tower on the transmission when running the shocks mounted on the back of the arms
Old 06-12-2015, 08:36 PM   #1105
st.ray's Avatar
Does anyone know how moving the rear linkage on the hub to the forward or aft holes will affect handling? I've read all the setup guides and google searched but never really found a good answer. Theres got to be a good enough reason for 6 holes
st.ray is offline   Reply With Quote
Old 06-13-2015, 05:43 AM   #1106
Have you guys had any trouble with the plastic rear hubs? I want to try them on my bmax2, but someone told me they break easy.
RaceToTheBottom is offline   Reply With Quote
Old 06-13-2015, 06:55 AM   #1107
FLHX1550's Avatar
All that matters is the length of the link. Forward or back on the hub doesn't change anything
FLHX1550 is offline   Reply With Quote
Old 06-13-2015, 11:20 AM   #1108
Moderator
MarkA's Avatar
Have not broken one myself - have not even seen one get broken on anyone else's car as well (knock on wood... )
Old 06-13-2015, 01:03 PM   #1109
WillS's Avatar
Trader Rating: 30 (100%+)
Send a message via MSN to WillS Send a message via Yahoo to WillS
Using small roll center spacers I have cracked them and caused them to bend. I use the 6mm wide ones (TLR,12r5, etc) with no problems since.
Will Smith
Sponsors:
Cheater Racing, Team Powers, Amain.com/Protek, Dialed RC Hobbies/Soar
WillS is offline   Reply With Quote
Old 06-13-2015, 05:14 PM   #1110
Thanks, I appreciate the help. I ordered a set. I'll make sure to use the larger spacers (I have some schumacher 6mm spacers).
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
boostedRN
