    Hide Wikipost
Old 10-18-2017, 07:19 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Yokomo YZ-2
Last edit by: Bob Barry
Welcome to the YZ2 Wiki!
If you edit the page, please add your name and date prior to your addition. While an admin can view the history, this makes it easier for everyone to just check updates. We'll put the newest additions at the top
Setup Sheets can be found here
DT CA DTM parts comparison
Print Wikipost
Like Tree105Likes
Old 05-20-2015, 09:04 AM   #1081
Moderator
MarkA's Avatar
Trader Rating: 21 (100%+)
Originally Posted by FLHX1550 View Post
Now I haven't tried it, but I'd remove the motor plate brace as a last resort. Not worried about tweaking the chassis, but if you have too much torsional flex, you can run into issues where the chassis will flex in the corner and give you grip on turn in, but the chassis will unload that flex and "snap" you loose.
I've ran without it on carpet - the car really does gain rear grip in a very linear fashion; sometimes almost too much. YMMV
MarkA is offline   Reply With Quote
Old 05-20-2015, 01:44 PM   #1082
joeymdz's Avatar
Send a message via MSN to joeymdz
I put mine back in after last night. I had to much grip which was odd but I did switch out my tires for ones with more pins. (I just drove like crap last night.. lol)
Redemption tonight!
RC Plus*McKune Designs*NW Hobbies*Premier RC Raceways*Daves Tracks
joeymdz is offline   Reply With Quote
Old 05-20-2015, 07:22 PM   #1083
kbish76's Avatar
Talking
Some tips for rear grip on the YZ - if you are running this car near legal weight (or under) with its front weight bias, I see this car not wanting to transfer weight front to back.
Yes, moving the weight bias back will help this, but try using lower angles of anti-squat and rear toe than you are used to. People are accustomed to 3-4 degrees of both because "that's what I've always run", but with the smoothness of this car I'm having success with 2.5 degrees of toe and 3 degrees of anti squat
It's funny you mentioned the front to rear transfer as one of the fast gifts at my local track was talking about the same thing with his Team C. I'm going to be trying the front rear brass weight as well as the different pills you mentioned.
kbish76 is offline   Reply With Quote
Old 05-24-2015, 02:13 PM   #1084
kbish76's Avatar
Talking
Can someone explain to me the "pills"? What each one equates to. And if someone could explain all the set-up sheets for the YZ-2 I would be extremely thankful.
Old 05-24-2015, 02:41 PM   #1085
joeymdz's Avatar
Post 1055
Old 05-26-2015, 08:13 AM   #1086
Is the yokomo tranny top shaft the same as the kyosho rb6?
jake alton is offline   Reply With Quote
Old 06-01-2015, 03:22 PM   #1087
cclifton's Avatar
Send a message via MSN to cclifton
Default loose to medium bite track
I was wondering if any of you have gotten this car to work in lower bite setups. I am getting close on setup to my other cars, but was wondering if any of you have suggestion. I have taken off the waterfall brace and the l bracket screws but it doesn't feel consistent. Any more thoughts
cclifton is offline   Reply With Quote
Old 06-01-2015, 04:57 PM   #1088
Moderator
MarkA's Avatar
Where are you at on added weight? Most of the people trying them on "high-bite" dirt seem to still be getting the weights up - look back a few pages for more on that. I'm out of the loop but I thought you guys were sugaring the dirt down there; still not enough traction from the track itself?
Old 06-01-2015, 05:04 PM   #1089
hollywood3705's Avatar
Front- vrp 3x1.4 pistons 32.5 wt oil. Xgear white. Stroke 21.75mm Middle middle tower and arm. Camber link middle on bulkhead inside on hub. 1mm washer. Spindles down. 25 and 5 for kick up caster. 23.5 mm ride height. 4mm akerman. 2mm spaced down on steering rack. No bump steer washers
Rear- vrp 1.6x2 pistons 30 wt. Xgear white stroke 27.5mm. Inside on tower inside on arm. Camber link middle on bulkhead center on hub. 1mm on bulkhead 2mm on hub. Arms center hubs center. 3deg toe in 1 deg anti squat. Shim under front rear holder. None under rear rear. 23mm ride height
Misc
bmax2 driveshaft
Bmax4 rear arms if little to no dust
yz2 arms if getting dusty
25g weight under battery
shorty back
brass rear front suspension holder
15 gr in front of front rear holder
No rear motor plate brace
trimmed waterfall
4 center rear side pod screws loosed 1 turn from tight
Amain.com / Protek / VRP / The Ohio R/C Factory / The Bearded Wonder
hollywood3705 is offline   Reply With Quote
Old 06-01-2015, 05:33 PM   #1090
cclifton's Avatar
No sugar yet. Only use sugar during the summer....its coming soon. We found that sugar doesnt work till the temp goes up. We molasses the track when the average day temp is 65 or below and sugar when it hotter. I wish we just had clay in this building but because the building is basically covered and we cant control the inside temp...it would be hard to keep clay at the right moisture content/temp for it to work. Im just happy we have a place to race
The Fleet:Xray:XT2 - Associated B6, B64 - Serpent SRX2 MH
Poorboy Raceway and Hobbies
Grants Pass, OR
Old 06-01-2015, 05:36 PM   #1091
cclifton's Avatar
Thanks, Ill try that setup. Do you have a picture of how you trimmed the waterfall brace
Grants Pass, OR
Old 06-01-2015, 05:38 PM   #1092
Put the waterfall back on. I posted what I run in every condition with just changing tires. I don't change much now. The waterfall will give you a more consistent car. Flex is great until it unsprings and leaves the car a mess coming out of corners. It will flex and twist and contort......then snap back violently
Old 06-01-2015, 06:12 PM   #1093
Here you go. I took out the center then I beveled the right and left sides to gain flex and allow the wire to clear. I'm also going to raise the waterfall up with 1.5 mm worth of plastic washers to better clear my wires
Old 06-01-2015, 09:25 PM   #1094
joeymdz's Avatar
Tell management to put carpet in there! 3 out of 6 Oregon indoor tracks are on carpet (hint hint )
Old 06-01-2015, 10:54 PM   #1095
cclifton's Avatar
Thanks man
Grants Pass, OR
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
sickpuppy1
