    Hide Wikipost
Old 10-18-2017, 07:19 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Yokomo YZ-2
Last edit by: Bob Barry
Welcome to the YZ2 Wiki!
If you edit the page, please add your name and date prior to your addition. While an admin can view the history, this makes it easier for everyone to just check updates. We'll put the newest additions at the top
Setup Sheets can be found here
DT CA DTM parts comparison
Print Wikipost
Like Tree74Likes
Old 05-18-2015, 04:54 AM   #1066
FLHX1550's Avatar
Some tips for rear grip on the YZ - if you are running this car near legal weight (or under) with its front weight bias, I see this car not wanting to transfer weight front to back.
Yes, moving the weight bias back will help this, but try using lower angles of anti-squat and rear toe than you are used to. People are accustomed to 3-4 degrees of both because "that's what I've always run", but with the smoothness of this car I'm having success with 2.5 degrees of toe and 3 degrees of anti squat
FLHX1550 is offline   Reply With Quote
Old 05-18-2015, 09:36 AM   #1067
Moderator
MarkA's Avatar
Trader Rating: 21 (100%+)
Originally Posted by kbish76 View Post
3rd club race tonight finished 4th getting better. For loose dry conditions the yok needs a lot more weight. Added the yok weights in battery tray, 27/ 30 rear/front oil w/ machined 1.6 pistons. Kyosho pinks/whites rear/front. Rear hubs moved forawrd and rear shocks top in and bottom in. Next is Ricket RC brass rear hinge pin holders. Also the front end is way to twichy need to find the right direction to tame it.
Try 1.7 pistons on the rear; it'll help with initial rearward weight transfer. Also, pull the lower L brace from the rear - astute observers will note Yoke is running the car w/o it even on carpet now.
MarkA is offline   Reply With Quote
Old 05-18-2015, 11:53 AM   #1068
teeforb's Avatar
Trader Rating: 94 (100%+)
Send a message via Yahoo to teeforb
do you have the exact block id that you are using? for front and rear.
Thanks!
$$ Team High Budget $$
17.5 stock buggy fb page
https://www.facebook.com/groups/17.5stockbuggy/
teeforb is offline   Reply With Quote
Old 05-18-2015, 02:11 PM   #1069
Racing4Evo's Avatar
Send a message via AIM to Racing4Evo
Hi everyone,
NEW option parts coming from Yokomo soon.
-Steel Suspension Holders
-Steel Rear Balance weight (20g)
-Aluminum Rear Upper Arm Mount (plus pocket for ballast weight)
-NEW "Black Diamond"(new hard coating TiCn) shock shafts
-Lightweight Slipper Plate Set
-Aluminum Rear Upper Arm Mount (plus ballast weight)
-Lightweight Slipper Plate Set (not sure why but the actual part pictured looks like it's for B-Max4)
Racing4Evo is offline   Reply With Quote
Old 05-18-2015, 02:28 PM   #1070
Moderator
MarkA's Avatar
Several people asked me how I get the Schumacher U6801 pre-mount fronts for carpet racing that were mentioned on my setup sheet here in the U.S. - my local track has carried them for months but Amain just added them as well: http://www.amain.com/rc-cars/schumac...48144?v=445448
Old 05-18-2015, 06:33 PM   #1071
teeforb's Avatar
Will amain carry it?
Originally Posted by Racing4Evo View Post
Hi everyone,
Old 05-18-2015, 06:36 PM   #1072
teeforb's Avatar
Originally Posted by WillS View Post
The exotek is the only one I have found to fit. You need to use a 2mm spacer behind it though to clear the motor plate.
Are you using the rb6 one? It seems the losi or b5m eliminator would work better.
Old 05-18-2015, 06:47 PM   #1073
WillS's Avatar
Trader Rating: 30 (100%+)
Send a message via MSN to WillS Send a message via Yahoo to WillS
Yes the RB6 one. The AE/TLR ones have a smaller shaft which makes them compatible with the Schelle or Avid slipper, which Yokomo and Kyosho will not without a change in the topshaft.
Will Smith
Sponsors:
Cheater Racing, Team Powers, Amain.com/Protek, Dialed RC Hobbies/Soar
WillS is offline   Reply With Quote
Old 05-18-2015, 07:38 PM   #1074
teeforb's Avatar
Exotek is building the yz2. I take he will make it. I'm using the rb6 eliminator as well. I had to use some spacing as well.
Old 05-19-2015, 10:13 AM   #1075
kbish76's Avatar
Could you clarify what the L brace is? And I was looking at those Pistons but Amain have been out for a while.
kbish76 is offline   Reply With Quote
Old 05-19-2015, 10:21 AM   #1076
Racing4Evo's Avatar
MarkA is referring to this part:
The name is Motor Plate support.
You can take it off or just take out the two screws on the bottom that connect it to the chassis.
Old 05-19-2015, 11:19 AM   #1077
kbish76's Avatar
Red face
What will that do for it? And where/when can we get those new products?
Old 05-19-2015, 11:23 AM   #1078
Moderator
MarkA's Avatar
More rear flex than running with it, less flex than cutting the waterfall brace.
Old 05-19-2015, 08:53 PM   #1079
FLHX1550's Avatar
Thanks!
Front Blocks Arrow Down - without the spacer under the mount
Rear Blocks are "3" on top with "1H" on bottom with arrows in
Now I haven't tried it, but I'd remove the motor plate brace as a last resort. Not worried about tweaking the chassis, but if you have too much torsional flex, you can run into issues where the chassis will flex in the corner and give you grip on turn in, but the chassis will unload that flex and "snap" you loose.
What would be ideal is a brace that would mount on the tower and mount centrally in the chassis, like a 1/8 scale car. The brace works best long to stretch that flex over as much of the chassis as possible, so it is slower acting when it releases its pressure
Old 05-20-2015, 07:57 AM   #1080
I removed the motor plate brace on both my high and low grip YZ and prefer the cars that way, found the car too stiff with it even on carpet.
mojo tom is offline   Reply With Quote
