Yokomo YZ-2
#976
I just received some yz2 parts from Factory-RC...
Fit is great. You can actually tell a difference between flat and gullwing towers. The steering blocks have another hole for Ackerman changes. The battery brace is lengthened to prevent popping out on a hard casing and also made it to have infinite adjustment for the battery.
#977
#979
Yokomo YZ-2 Short Course and Stadium Truck conversion's
I thought I would share the Pics of My Yokomo YZ-2 Short Course and Stadium Truck Conversions. I had the chassis made from the same aluminum as the factory just extended it to make them the right length. They are exactly the same except for length. They use associated T5 arms, kyosho SC6 CVD's, new longer lunsford turnbuckles and some after market body mounts but other than that and a few small parts here and there they are all factory Yokomo YZ-2 parts. They do require a lot of time and testing but after my first race with each taking home the Win in both classes makes it all worth while.
#980
Did you do the conversion or did you have someone do it for you? How does the truck handle compared to the buggy?
On a side note, I really like sct body paint job. I'm curious to know if you used black paint or dark orange for the stenciling and drop shadows.
#981
Conversions
Nice job with the conversions! Just a couple of questions. So the other manufactures arms and dog bones where a correct fit? How about suspension? What shock toweres and what size shocks where used? Any problem with correct fitting? How about off set with wheels? Which wheels where used? Their had to a lot more involved? Thanks!
#983
We have been very happy working with the notorious MO designer. Any design that he's had a part in is credited in the part description. Mo is a good friend and has been a great resource for Factory RC. We give him credit on any and all of his designs.
#984
Thank You for the feedback I did the complete conversion myself .The arms and cvd's are a direct fit on the inner mounts I had to drill the yokomo hubs out to fit the larger associated hinge pins on the outer hubs. I have the T5 arms turned backwards on the back and drilled a hole to mount the shocks on the back. It uses all the stock shocks and shock towers from the YZ-2.The Sct wheels are kyosho offset rear and associated on the front the Stadium Trucks is associated front and rear they also have exotec 9mm hexes on the back it puts the truck to the roar legal max Sct width of 296mm maybe a little less with no tow or camber adjustments and Stadium Truck to 12.75 width under the 13" max for roar. As far as the body goes I had it painted by Larry Genova he does all my bodies to match you can find him on face book. The trucks drive just like the buggies and turn on a dime. I am thinking of selling the conversions but I have not decided yet. I would probably have people send me there buggy and I would complete the conversions and send them back if I do go that route.
#985
Hello all. I have reading this entire thread. After reading the review in Car Action, I just had to get 1 of these YZ-2 cars. I have been running a Durango dex210v2 for a while, which is a great car! So I just ordered a YZ-2 on Friday. Should be here this Friday. I'm really looking forward to the build. I'm going to put my TrakPower system out of my 210 in it with my Spektrum radio system. Can't wait.
#986
Thanks Randy! For some info! I guess I'm not aware of who is all part of Factory Rc! So I am guessing you are also apart of Factory RC.
#987
#988
YZ2
Hey guys I have posted on the for sale thread my YZ-2 . I just don't have time to race it as much as I like . Check it out .
#989
