    Hide Wikipost
Old 08-10-2017, 01:11 PM   -   Wikipost
R/C Tech Forums Thread Wiki: Yokomo YZ-2
Last edit by: Bob Barry
Welcome to the YZ2 Wiki!
If you edit the page, please add your name and date prior to your addition. While an admin can view the history, this makes it easier for everyone to just check updates. We'll put the newest additions at the top
Setup Sheets can be found here
Print Wikipost
Like Tree63Likes
Old 04-03-2015, 04:57 PM   #916
Originally Posted by FLHX1550 View Post
My advice would be to take the weight out of the back of the car and move it forward.
On my preparation for the race on clay (my first experience on dirt with the YZ) I prepped the car wit Lee's setup from cactus. By the end of practice I was back to being very close to where I was on carpet with the setup (short of shock oil and rear link). Even on dirt, the car feels better and better the more forward the weight bias is.
And it's not like it's slow, I qualified 6th overall and as high as 3rd in the first round of qualifying in 17.5. Finished 7th with some horrific first lap traffic, but I'd consider it to be respectable for a car that's "only good on carpet" ( and driven by a 40 year old amongst teenagers)
Does not work for me on low grip running mod motor though, I would have loved a rear link assembly made of brass to put weight up and at the rearmost part of the car (and remove 50g lipo weight).
Car is capable on low grip, I got 50g underlipo, around 35g behind motor and a brass rear hanger and could have used some more weight on the rear.
mojo tom is offline   Reply With Quote
Old 04-03-2015, 06:57 PM   #917
FLHX1550's Avatar
If anyone is interested I could post my setup, but honestly taking the weight out from under the battery and take the weight under the trans and put it under the steering rack.
JConcepts - TKO - RW Mods - B-Fast - MODX Motors & Batteries - Skare OCD Designs
FLHX1550 is offline   Reply With Quote
Old 04-03-2015, 07:30 PM   #918
STLNLST's Avatar
Trader Rating: 21 (100%+)
Originally Posted by wstuart View Post
So would you not recommend messing with front droop too drastically?
Go with what works for you. You won't know what droop does until you try it. I liked the feel of the car with my setup and never had to add weight to the rear to get it to hook up.
REMEMBER THE GOOD OLE DAYS..........THEY'RE NEVER COMING BACK SO WE'RE STUCK WITH THE MESS IN FRONT OF US!!!!
STLNLST is offline   Reply With Quote
Old 04-04-2015, 05:57 AM   #919
teeforb's Avatar
Trader Rating: 94 (100%+)
Send a message via Yahoo to teeforb
This car is awesome! I'm looking into buying another for 17.5.
$$ Team High Budget $$
17.5 stock buggy fb page
https://www.facebook.com/groups/17.5stockbuggy/
teeforb is offline   Reply With Quote
Old 04-04-2015, 09:28 AM   #920
FLHX1550's Avatar
My clay setup
Old 04-06-2015, 12:25 AM   #921
tony2's Avatar
Really?? I'll try it, but my experience has been that the car is super loose without some weight in the rear
I tried to get the same weight as the arrowmax rear bulkhead from the bmax2 part on saturday at a med traction outdoor track. it was a donut machine with 35grams there.
took the weight out of it and bang fast.
anyway i have gone around .8 faster lap time then my bmax2 and it was only 1.1 sec from my best 4wd lap.....
maybe my 4wd needs some work
Anthony Campbell
Ryper Hobbies l AKA | AE
tony2 is offline   Reply With Quote
Old 04-06-2015, 02:56 AM   #922
hacker's Avatar
Trader Rating: 140 (100%+)
Why are some opting to use bmax2 driveshafts?
hacker is offline   Reply With Quote
Old 04-06-2015, 06:26 AM   #923
FLHX1550's Avatar
Because the stock ones are too short to run full droop with the stock YZ arm much less the longer BMax arm
Old 04-08-2015, 01:18 PM   #924
teeforb's Avatar
Yz2 ball diff are in stock. And TI turnbuckles.
I just ordered another yz2
Old 04-08-2015, 10:09 PM   #925
teeforb's Avatar
What's the shim size for the diffs
Old 04-08-2015, 10:18 PM   #926
Racing4Evo's Avatar
Send a message via AIM to Racing4Evo
10mm
Racing4Evo is offline   Reply With Quote
Old 04-08-2015, 10:20 PM   #927
Racing4Evo's Avatar
http://www.amain.com/rc-cars/yokomo-10mm-stainless-steel-shim-kit-30-yokzc-s100s/p242340
Any 10mm inner diameter shim will work.
Old 04-08-2015, 10:50 PM   #928
teeforb's Avatar
Old 04-08-2015, 11:13 PM   #929
Anybody looking to sell a Yz2 then let me know
Mi4cxl is offline   Reply With Quote
Old 04-10-2015, 11:51 PM   #930
Issue with carbon fiber battery brace popping out from under the rear chassis brace. More than once. Most likely by casing a jump. Anyone have this problem? Chassis flex!
jake alton is offline   Reply With Quote
