    Hide Wikipost
Old 10-18-2017, 07:19 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Yokomo YZ-2
Last edit by: Bob Barry
Welcome to the YZ2 Wiki!
If you edit the page, please add your name and date prior to your addition. While an admin can view the history, this makes it easier for everyone to just check updates. We'll put the newest additions at the top
Setup Sheets can be found here
DT CA DTM parts comparison
Print Wikipost
Like Tree74Likes
Old 04-01-2015, 05:02 PM   #886
Racing4Evo's Avatar
Send a message via AIM to Racing4Evo
Another way to look at how the caster angle affects the steering is relating it to throttle input. I think it is much easier for me too think of it in this way since in a very limited and rudimentary understanding, you are almost always off throttle when entering a corner, but on throttle when exiting a corner.
Lower Caster Angle gives you:
-More off throttle steering
-Less on throttle steering
Higher Caster Angle gives you:
-Less off throttle steering
-More on throttle steering
Sorry if I confused anyone
Racing4Evo is offline   Reply With Quote
Old 04-01-2015, 05:42 PM   #887
303slowdown's Avatar
Trader Rating: 24 (100%+)
Thanks guys, I understand quite well what caster does just thought there was more to it since it not only changes caster but changes angle on the suspension arms. I might be over thinking it.
Ryan Borgheiinck
303slowdown is offline   Reply With Quote
Old 04-01-2015, 06:47 PM   #888
Trader Rating: 14 (100%+)
In my kit there were two angled ball cups but in the manual they are not indicated to use. Does anybody know where these go? I am assuming the steering tie rods?
Thanks!
sstriano is offline   Reply With Quote
Old 04-01-2015, 06:48 PM   #889
JEFFs SC10's Avatar
Trader Rating: 14 (94%+)
so is this pretty much THEE car to have for carpet?
anyone run on med clay just to see how it does?
we got a carpet track being built locally.
XRAY 2017 T4
CRC Gen X SE- 17.5 GT
Xray X12-17' GT12
check out the new 12th scale GT class! https://www.facebook.com/groups/148391312353349/
support your local tracks- Beachline Raceway-386-Full Throttle Raceway
JEFFs SC10 is offline   Reply With Quote
Old 04-01-2015, 08:20 PM   #890
Racing4Evo's Avatar
Thanks!
Those are for the old bmax2 rear hubs that have a horizontal mount like on the stock B5 rear hubs. The switched to vertical ball studs on the option aluminum hub and stock YZ-2 hub.
You don't use them.
Old 04-01-2015, 08:46 PM   #891
You don't use them.
Thank you!!
Old 04-01-2015, 08:53 PM   #892
Caster also adds dampening.
jake alton is offline   Reply With Quote
Old 04-01-2015, 08:59 PM   #893
What is a good starting gearing for stock 17.5T on carpet? I am using the stock 81T (I think it is) spur.
Thanks!!
Old 04-01-2015, 09:15 PM   #894
17.5. A 72 May be a better choice. Maybe start with a 28 to 30 pinion then go up if need.
Old 04-01-2015, 09:26 PM   #895
What brands of spurs fit it? Do I have to stay with Yokomo?
Old 04-01-2015, 09:29 PM   #896
Moderator
MarkA's Avatar
Trader Rating: 21 (100%+)
Any AE-style spurs work
MarkA is offline   Reply With Quote
Old 04-01-2015, 09:34 PM   #897
Racing4Evo's Avatar
Look at the front of the thread for common tips and info.
Old 04-01-2015, 09:35 PM   #898
kbish76's Avatar
Finally Amain has parts back in stock! Does anyone know the correct size bearings that fit inside the ball diff?
kbish76 is offline   Reply With Quote
Old 04-01-2015, 10:00 PM   #899
5x8x2.5mm I believe. Saw on the avid site were it indicates their bearing kit does not include it. I am gonna piece out all the ball diff parts separately too. Goin with the bfast stuff.
carpetburner is offline   Reply With Quote
Old 04-02-2015, 05:33 AM   #900
pumpkinfish's Avatar
I have been running the buggy on med-med/high bite clay and it is very easy to drive. Once I got a neutral setup on the buggy it felt a lot better. Now if i could drive better it would be unbeatable! I will say at this moment, I have been doing better with my YZ-2 than i ever did with the B5m.
Yokomo YZ-2, B-Max4 III
Kyosho RT6
Losi 22b, XX4 Worlds
Associated SC10.2, RC10B2, RC10T2, RC10
pumpkinfish is offline   Reply With Quote
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
