    Hide Wikipost
Old 10-18-2017, 07:19 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Yokomo YZ-2
Last edit by: Bob Barry
Welcome to the YZ2 Wiki!
If you edit the page, please add your name and date prior to your addition. While an admin can view the history, this makes it easier for everyone to just check updates. We'll put the newest additions at the top
Setup Sheets can be found here
DT CA DTM parts comparison
Print Wikipost
Like Tree105Likes
Old 03-27-2015, 06:23 PM   #856
kbish76's Avatar
Starting on the shock build this weekend and I have a few questions.
Does anyone use green slime in the bottom cartridge? Or dry? And looking at set-up sheets on Petite, which Pistons to use ? The stock ones or others? And anything else I should watch for on the build?
kbish76 is offline   Reply With Quote
Old 03-27-2015, 06:32 PM   #857
303slowdown's Avatar
Trader Rating: 24 (100%+)
I used green slime , but I do on all shock pieces. As for pistons I used the kit ones but other have expressed there unhappiness with them not being machined so the switch to machined ones, either yokomo or schelle I think. I've had no issues with the stock pistons they feel fine to me but what do I know lol.
Ryan Borgheiinck
303slowdown is offline   Reply With Quote
Old 03-27-2015, 06:41 PM   #858
kbish76's Avatar
And ppl are going back to setting a rebound on the shock shaft? Or still no rebound?
Old 03-27-2015, 07:56 PM   #859
FLHX1550's Avatar
The kit pistons are kind of a joke, but fortunately the upgrade ones are pretty cheap. You can also use AE ones with no issue.
I use grease on the build, the biggest reason is that if all the voids in the o-ring cartridge are packed with grease then oil can't leak in from the top.
On rebound, for me it's all track conditions. If I need some more pop off the jumps I run rebound.
FLHX1550 is offline   Reply With Quote
Old 03-28-2015, 08:52 AM   #860
teeforb's Avatar
Trader Rating: 94 (100%+)
Send a message via Yahoo to teeforb
My kit is missing the e clip and sim for the piston assembly. Any notes on this? I looked all over. I can't find them in any bag
$$ Team High Budget $$
17.5 stock buggy fb page
https://www.facebook.com/groups/17.5stockbuggy/
teeforb is offline   Reply With Quote
Old 03-28-2015, 10:15 AM   #861
teeforb's Avatar
Found them
Old 03-28-2015, 06:03 PM   #862
STLNLST's Avatar
Trader Rating: 21 (100%+)
Selling my YZ after today's race. PM me if interested. Nothing wrong with the car if anyone is wondering.
REMEMBER THE GOOD OLE DAYS..........THEY'RE NEVER COMING BACK SO WE'RE STUCK WITH THE MESS IN FRONT OF US!!!!
STLNLST is offline   Reply With Quote
Old 03-28-2015, 06:19 PM   #863
teeforb's Avatar
Why are you selling it?
Old 03-28-2015, 07:20 PM   #864
pumpkinfish's Avatar
Hey guys, I have been running STLNLST's setup and it has been great so far until today. When ever I was going around the 180 turns, my inside rear wheel was lifting. I tried going to the rear inside tower hole and it was better, but it was still lifting. Any ideas what I can do?
Yokomo YZ-2, B-Max4 III
Kyosho RT6
Losi 22b, XX4 Worlds
Associated SC10.2, RC10B2, RC10T2, RC10
pumpkinfish is offline   Reply With Quote
Old 03-28-2015, 09:09 PM   #865
Is the car bottoming out and the wheel is coming off the ground?
jake alton is offline   Reply With Quote
Old 03-28-2015, 09:21 PM   #866
WillS's Avatar
Trader Rating: 30 (100%+)
Send a message via MSN to WillS Send a message via Yahoo to WillS
normally when the inside rear lifts I add a shim internally to the rear shocks. Or your front shock fluid is too light.
Will Smith
Sponsors:
Cheater Racing, Team Powers, Amain.com/Protek, Dialed RC Hobbies/Soar
WillS is offline   Reply With Quote
Old 03-28-2015, 09:31 PM   #867
STLNLST's Avatar
Personal reasons
Old 03-29-2015, 01:29 AM   #868
tlr22jude's Avatar
Trader Rating: 43 (100%+)
PM sent. I was about to purchase a new kit, but would be mnice if I can find a nice used one and save a couple bucks.
tlr22jude is offline   Reply With Quote
Old 03-29-2015, 03:55 PM   #869
teeforb's Avatar
What springs are you guys using for med bite indoor clay track?
Old 03-29-2015, 06:45 PM   #870
Associated White all four corners
Kyosho RT6
