    Hide Wikipost
Old 10-18-2017, 07:19 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Yokomo YZ-2
Last edit by: Bob Barry
Welcome to the YZ2 Wiki!
If you edit the page, please add your name and date prior to your addition. While an admin can view the history, this makes it easier for everyone to just check updates. We'll put the newest additions at the top
Setup Sheets can be found here
DT CA DTM parts comparison
Print Wikipost
Like Tree105Likes
Old 03-24-2015, 04:43 PM   #811
FLHX1550's Avatar
Originally Posted by dennisV View Post
There's no issue with the steel turnbuckles. Only go Ti if you like them. They won't make you faster.
Less weight overall, less un-sprung weight, and a lower CG are all reasons to justify Ti turnbuckles. However, is someone is just replacing them justified on strength, then the steel ones are just fine (Yokomo uses ultra high-quality steel, they are not like stock AE or Losi turnbuckles)
JConcepts - TKO - RW Mods - B-Fast - MODX Motors & Batteries - Skare OCD Designs
FLHX1550 is offline   Reply With Quote
Old 03-24-2015, 06:43 PM   #812
303slowdown's Avatar
Trader Rating: 24 (100%+)
Originally Posted by FLHX1550 View Post
Because a top of the line $350 car should come with Ti turnbuckles.
Well I haven't seen any car come with them but I guess it wouldn't sway me either way.
The $450 rb6 doesn't come with them either.
Ryan Borgheiinck
303slowdown is offline   Reply With Quote
Old 03-24-2015, 06:47 PM   #813
Wildcat1971's Avatar
Trader Rating: 81 (100%+)
the B5M lite comes with them
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 03-24-2015, 06:57 PM   #814
Like I said I haven't SEEN one that came with them lol.
Ryan Borgheiinck
Old 03-24-2015, 07:48 PM   #815
hollywood3705's Avatar
The ae blue ones don't count. They are weak and honestly alot of people change them out. Steel is nice because it let's each person decide what is better for them. Be it performance or looks. Like all of you here it didn't stop us from running the car so it's a a non-factor
Amain.com / Protek / VRP / The Ohio R/C Factory / The Bearded Wonder
hollywood3705 is offline   Reply With Quote
Old 03-24-2015, 08:52 PM   #816
they are still Ti. Please dont defend the steel. it was just a money saver for them. the yz2 is nice and the steel maybe be "fine", but I am sure people want Ti
Old 03-24-2015, 09:48 PM   #817
low grade ti......I'd rather have steel. They sell the ti as a hopup. The aluminum steering. Front camber block. Toe blocks. Topshaft. hexes. Carbon towers and battery brace.......I'll buy the turnbuckle since I got all that in the box with the yoke.
Old 03-24-2015, 10:23 PM   #818
Racing4Evo's Avatar
Send a message via AIM to Racing4Evo
+1
Ti turnbuckles are cheaper than all those other parts. You have to draw the line somewhere when pricing these kits. If people don't complain about ti turnbuckles, they will complain about ti screws or ti axles etc...where does it stop?
This is not the cheapest kit nor is the most expensive. People can perfectly make their own judgement call whether or not it's a good value.
Let's break down what many might consider performance option parts available for one or another brand kit:
1. Aluminum Hinge Pin Brace
2. Aluminum Front Lower Suspension Mount
3. Aluminum Front Upper Suspension Mount
4. Aluminum Steering Arm
5. Aluminum Steering Rack
6. Carbon Front Shock Tower
7. Aluminum Front Clamping Wheel Hex
8. Carbon Battery Holder
9. Aluminum Top Shaft
10. Aluminum Idler Gear Shafts
11. Steel Gears for Diff
12.Aluminum Rear Inner Suspension Block
13. Aluminum Rear Outer Suspension Block
14. Aluminum Rear Clamping Wheel Hex
15. Carbon Rear Shock Tower
All of these are included with the Yokomo. A lot of these parts were even option parts that you had to buy separate for the older BMax-2 MR!
Racing4Evo is offline   Reply With Quote
Old 03-24-2015, 10:31 PM   #819
WillS's Avatar
Trader Rating: 30 (100%+)
Send a message via MSN to WillS Send a message via Yahoo to WillS
Yokomo uses a way better steel than most companies. Just on their outdrives I burnt through 2 $50 diamond bits trying to make lightweight outdrives. The only real reason to go to ti from the steel would be the weight. These do not bend like the flimsy ones other companies put in their kits to force people to buy titanium. With most electronic setups these cars are under weight as it is with steel turnbuckles.
Will Smith
Sponsors:
Cheater Racing, Team Powers, Amain.com/Protek, Dialed RC Hobbies/Soar
WillS is offline   Reply With Quote
Old 03-24-2015, 10:37 PM   #820
Suspended
Trader Rating: 61 (100%+)
That is purely from user error. A diamond jobber bit when used correctly should last through thousands of holes drilled. You were either drilling at too high of speed, or not using correct or any cutting fluid what so ever.
Best Avatar on rc-tech
Socket is offline   Reply With Quote
Old 03-24-2015, 10:42 PM   #821
teeforb's Avatar
Trader Rating: 94 (100%+)
Send a message via Yahoo to teeforb
One great thing about the Yok, parts are cheap for the best quality car in the market!
$$ Team High Budget $$
17.5 stock buggy fb page
https://www.facebook.com/groups/17.5stockbuggy/
teeforb is offline   Reply With Quote
Old 03-24-2015, 10:54 PM   #822
fullsyzz's Avatar
Trader Rating: 107 (100%+)
Why am I having flashbacks about turnbuckle discussion on a new car? Oh yes. The early B5 days. Haven't seen wild cherry ever since.
fullsyzz is offline   Reply With Quote
Old 03-24-2015, 11:07 PM   #823
Jack Smash's Avatar
Trader Rating: 29 (100%+)
Luckily I missed all that
Kyosho / Orion / Amain.com / Protek / MIP /
Jack Smash is offline   Reply With Quote
Old 03-24-2015, 11:10 PM   #824
fullsyzz's Avatar
Maybe it was ball cups.
Old 03-25-2015, 07:11 AM   #825
WillS's Avatar
That ironic cause I wasnt the one machining but an individual who worked as an aerospace machinist for 40 years. He warned me before trying that the steel is hardened too hard and that this would happen.
Will Smith
Sponsors:
