    Hide Wikipost
Old 08-10-2017, 01:11 PM   -   Wikipost
R/C Tech Forums Thread Wiki: Yokomo YZ-2
Last edit by: Bob Barry
Welcome to the YZ2 Wiki!
If you edit the page, please add your name and date prior to your addition. While an admin can view the history, this makes it easier for everyone to just check updates. We'll put the newest additions at the top
Setup Sheets can be found here
Print Wikipost
Like Tree42Likes
Old 03-20-2015, 01:29 AM   #781
alport78's Avatar
Originally Posted by kbish76 View Post
Ok thanks nitrorush27. I still have a stick pack from my SC. I didn't notice the yok could hold a traditional stick
Here you go !
Schumacher KF2
alport78 is offline   Reply With Quote
Old 03-20-2015, 05:12 AM   #782
pumpkinfish's Avatar
I will be picking up my yok tomorrow and very excited to run it. I've read pretty much every post on this thread and think I've made the right choice over the B5m "lite". I'm looking for some setup help as I run a med size, dirt/clay mix. It's usually damp to drying and gets dusty offline. Fast guys run worn chain links or electrons rear and ribbed in the front. Compounds soft or superfsoft, depending on temp. I've downloaded some of the setup sheets from here but any additional help would be much appreciated!
STLNST's petite setup is a great starting point.
http://www.petitrc.com/setup/yokomo/...YokomoYZ2.html
Yokomo YZ-2, B-Max4 III
Kyosho RT6
Losi 22b, XX4 Worlds
Associated SC10.2, RC10B2, RC10T2, RC10
pumpkinfish is offline   Reply With Quote
Old 03-20-2015, 05:32 AM   #783
hollywood3705's Avatar
Anybody have any insight on the taller or shorter servo horns? Just curious if it an adjustment for the rack rising and falling or if it is just 20mm because of leverage with the system
Amain.com / Protek / VRP / The Ohio R/C Factory / The Bearded Wonder
hollywood3705 is offline   Reply With Quote
Old 03-20-2015, 10:03 PM   #784
kbish76's Avatar
thanls for the set-up sheets and pics. Going to start the build this weekend. I have two more questions. First anything to watch for during the build? And second with my track type on mind should I get the ball diff instead?
kbish76 is offline   Reply With Quote
Old 03-20-2015, 10:52 PM   #785
STLNLST's Avatar
Trader Rating: 19 (100%+)
Ball diff would be the better all around choice in those conditions.
REMEMBER THE GOOD OLE DAYS..........THEY'RE NEVER COMING BACK SO WE'RE STUCK WITH THE MESS IN FRONT OF US!!!!
STLNLST is offline   Reply With Quote
Old 03-21-2015, 12:01 AM   #786
Trader Rating: 15 (100%+)
Man guys, I am LOVING this car. I think I found a really good starting point for a Med-Low bite track running the gear diff. If you guys want I can make a setup sheet. I can't seem to find a editable one online that.
Website: http://michaelsasher.com
masher81 is offline   Reply With Quote
Old 03-21-2015, 12:08 AM   #787
I put the car on the scales tonight. Here is how it scaled out with the the current setup I am running and 42g of weight added between the motor and hinge pin holder(Under the transmission)
Old 03-21-2015, 07:38 AM   #788
teeforb's Avatar
Trader Rating: 94 (100%+)
Send a message via Yahoo to teeforb
most of the individual pieces for the ball diff are in stock on amain.. Here is what i ordered. I have diff balls and the two bearings...
In Stock Products
1 x YOKB2-503D Yokomo Ball Differential Gear $5.09
1 x YOKZS-507 Yokomo Differential Thrust Bearing Set $2.59
1 x YOKBM-508 Yokomo Differential Adjustment Screw Kit $3.59
1 x YOKB2-506 Yokomo Differential Drive Ring Set (2) $5.09
1 x YOKB2-508TS Yokomo Ball Differential T-Nut & Spring Set $6.89
1 x YOKB2-501MR Yokomo Ball Differential Outdrive Set (2) $13.49
$$ Team High Budget $$
17.5 stock buggy fb page
https://www.facebook.com/groups/17.5stockbuggy/
teeforb is offline   Reply With Quote
Old 03-21-2015, 07:42 AM   #789
Taz_S's Avatar
ok guys need to do this again only way MIP is going to make a 17.5 system is if you keep riding there a$$ to make one.
1. Need to post on there Facebook page, your own post saying you want a Bmax and YZ-2 17.5 systems.
https://www.facebook.com/MIPonline
2. Like and Comment ever other post with the same request. (still have to do your own post) You find that in down on the left side saying "Posts To Page" click on that and look down the post and like and Comment.
3. Email MIP at support@miponline.com Contact: Michael Hamilton
matt@MIPonline.com Marketing, Sales
4. Call them Mon. - Fri.: 9am-5pm PST. 1-626-339-9008 ext.27
only way this get down if you step up and help.
Jake's Performance Hobbies http://www.jphracing.com/
https://www.facebook.com/groups/757500284356171 Facebook Group for Pro 10
Taz_S is offline   Reply With Quote
Old 03-21-2015, 11:32 AM   #790
I've been running the YZ-2 on a low to medium bite dry clay track. The car has allot of corner speed and steering due to it's weight distribution of 40% front and 60% rear when used out of the box. The car I was running before the YZ-2 was 34%/66% for distribution.
On our local track with M4 Electrons I could do fast laps with the YZ-2 with a normal setup but the consistency was an issue as the car lacks some grip in my opinion. I was able to improve my consistency and lap times by adding toe-in in the rear. I'm now using 5 degrees. I know some will think this is a bit crazy but it really helped. I played with anti-squat and found that 4 degrees worked well for me.
Last week I tried a rear front pivot made of brass that weighs 22gr and some brass battery weights that weigh 30gr each. I used 3 of these battery weights placed behind the shorty. By adding weight to the car it improved stability some more and made my laps even more consistent.
Prior to the brass rear pivot and brass battery weights I was running the YT-RW25 steel 25gr plate under the pack.
Hope this can help some who race on lower bite conditions.
DS1969 is offline   Reply With Quote
Old 03-21-2015, 03:37 PM   #791
kbish76's Avatar
I tried to go the same route as teeforb In regards to a ball diff. But amain are out of some of those parts already. Any ideas on getting those parts anywhere else? Also are all diff & thrust balls the same size for 1/10th scale? Maybe a could just buy b-fast
Old 03-21-2015, 03:51 PM   #792
STLNLST's Avatar
AE diff balls are a direct fit. I haven't tried another thrust as of yet.
Old 03-21-2015, 07:26 PM   #793
teeforb's Avatar
You should be able to use most 3/32 sized balls. Protek has 3/32 cermaic diff balls.
Old 03-21-2015, 08:41 PM   #794
kbish76's Avatar
I see that B-Fast has the diff and thrust balls for B-maxIII 4, B-max2,B-max4. Has anyone tried them out on yz-2?
Old 03-21-2015, 10:59 PM   #795
teeforb's Avatar
It should work. The yz2 diff is for the bmax
