    Hide Wikipost
Old 10-18-2017, 07:19 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Yokomo YZ-2
Last edit by: Bob Barry
Welcome to the YZ2 Wiki!
If you edit the page, please add your name and date prior to your addition. While an admin can view the history, this makes it easier for everyone to just check updates. We'll put the newest additions at the top
Setup Sheets can be found here
DT CA DTM parts comparison
Print Wikipost
Like Tree74Likes
Old 03-17-2015, 04:54 PM   #766
WillS's Avatar
Trader Rating: 30 (100%+)
Send a message via MSN to WillS Send a message via Yahoo to WillS
Originally Posted by pumpkinfish View Post
Anyone have Lee Martin's Cactus setup? Curious how he was setup.
Team Yokomo posted pictures to Facebook. No setup sheet as of yet.
Will Smith
Sponsors:
Cheater Racing, Team Powers, Amain.com/Protek, Dialed RC Hobbies/Soar
WillS is offline   Reply With Quote
Old 03-17-2015, 05:33 PM   #767
Rouleau's Avatar
any chance there will be a different body coming out?
Rouleau is offline   Reply With Quote
Old 03-17-2015, 05:44 PM   #768
WillS's Avatar
I doubt it, this body is pretty perfect as it is...
Will Smith
Sponsors:
Old 03-17-2015, 09:19 PM   #769
STLNLST's Avatar
Trader Rating: 21 (100%+)
This car is so nice to drive. It works at every indoor track in our area. Can't wait to take it outdoors for a race coming up. The car adapts very well to different surfaces. Get the correct tire's and you're in the ballpark from the begining.
REMEMBER THE GOOD OLE DAYS..........THEY'RE NEVER COMING BACK SO WE'RE STUCK WITH THE MESS IN FRONT OF US!!!!
STLNLST is offline   Reply With Quote
Old 03-17-2015, 09:40 PM   #770
teeforb's Avatar
Trader Rating: 94 (100%+)
Send a message via Yahoo to teeforb
I'll use you're setup on petite. Let me know of any running changes
$$ Team High Budget $$
17.5 stock buggy fb page
https://www.facebook.com/groups/17.5stockbuggy/
teeforb is offline   Reply With Quote
Old 03-17-2015, 09:58 PM   #771
STLNLST's Avatar
Laid the rear shocks down.
Old 03-18-2015, 05:26 AM   #772
pumpkinfish's Avatar
I used STLNST's petite setup last week at my local track and the car felt nice and neutral. The only thing I changed was lowered ride height to 21mm due to the track's high traction. I was traction rolling every turn until I lowered it. The last pictures I posted in here of our local track (craters and tectonic plates) is a thing of the past. The owner really worked on getting the track a lot better and it is so much better now.
Does anyone recommend the brass tow blocks for mod?
Yokomo YZ-2, B-Max4 III
Kyosho RT6
Losi 22b, XX4 Worlds
Associated SC10.2, RC10B2, RC10T2, RC10
pumpkinfish is offline   Reply With Quote
Old 03-18-2015, 06:03 AM   #773
STLNLST's Avatar
Glad it worked for you. My setup's normally are easy to drive and allows you to actually learn the layout rather than searching for that hot lap and running out of time. It may not be for everyone but it's a start and has worked great at every track I've run it at in my area.
Old 03-18-2015, 06:14 AM   #774
Suspended
Trader Rating: 61 (100%+)
LMR posted his cactus setup.
Best Avatar on rc-tech
Socket is offline   Reply With Quote
Old 03-18-2015, 06:15 AM   #775
WillS's Avatar
Rather interesting information on Lee Martin's clay setup for Cactus
Will Smith
Sponsors:
Old 03-18-2015, 08:19 AM   #776
B-Max4 III rear arms?
Kyosho RT6
Old 03-18-2015, 08:33 AM   #777
WillS's Avatar
yes that would be correct. I have been testing my car with the setup since the amain.com outback shootout. For me it helped with stability of the car, it also helps with on power steering as it will make the rear a little wider than the front.
REAR TRACK-WIDTH
Wider
Increases rear grip at corner entry
Increases high-speed on-throttle steering
Use to avoid traction rolling
Will Smith
Sponsors:
Old 03-19-2015, 04:44 PM   #778
kbish76's Avatar
I will be picking up my yok tomorrow and very excited to run it. I've read pretty much every post on this thread and think I've made the right choice over the B5m "lite". I'm looking for some setup help as I run a med size, dirt/clay mix. It's usually damp to drying and gets dusty offline. Fast guys run worn chain links or electrons rear and ribbed in the front. Compounds soft or superfsoft, depending on temp. I've downloaded some of the setup sheets from here but any additional help would be much appreciated!
kbish76 is offline   Reply With Quote
Old 03-19-2015, 05:12 PM   #779
Ill post a set up later tonight that i have found to work amazing. It does include running a brick pack though. i have ran this set up with a shorty also and it is good, just not as good.
Everyone looses races, few change them......
nitrorush27 is offline   Reply With Quote
Old 03-19-2015, 05:17 PM   #780
kbish76's Avatar
Ok thanks nitrorush27. I still have a stick pack from my SC. I didn't notice the yok could hold a traditional stick
