    Hide Wikipost
Old 08-10-2017, 01:11 PM   -   Wikipost
R/C Tech Forums Thread Wiki: Yokomo YZ-2
Last edit by: Bob Barry
Welcome to the YZ2 Wiki!
If you edit the page, please add your name and date prior to your addition. While an admin can view the history, this makes it easier for everyone to just check updates. We'll put the newest additions at the top
Setup Sheets can be found here
Print Wikipost
Like Tree63Likes
Old 03-02-2015, 04:14 PM   #646
WillS's Avatar
Trader Rating: 30 (100%+)
Send a message via MSN to WillS Send a message via Yahoo to WillS
Originally Posted by jmoneym View Post
Looking for little more traction coming out of the turn. Currently running 1.6 F/R will going to 1.7 rear help.
More setup information will help. Its easy to take an editable setup sheet and post so we can examine what other conditions that maybe present.
Will Smith
Sponsors:
Cheater Racing, Team Powers, Amain.com/Protek, Dialed RC Hobbies/Soar
WillS is offline   Reply With Quote
Old 03-02-2015, 04:18 PM   #647
WillS's Avatar
Originally Posted by mojo tom View Post
Alloy rear hubs for Low grip ?
I didn't think back when the car was presented that it will be that fast and easy to drive, really happy with the car and for once no need for anything besides springs and maybe turmbuckles. Bought a lot of 2wd and I always had to buy things before running it.
I normally run alloy hubs on high bite. There could be some characteristics of the weight properties that could help in low bite conditions.
Will Smith
Sponsors:
Old 03-02-2015, 04:36 PM   #648
vr6cj's Avatar
Trader Rating: 124 (100%+)
I really like my yz2.
Took about two quals and practice to get used too and setup but man, gotta say its nice. feels fast in corners. Faster then my 22 2.0 and almost as fast as my b5m was. I could easily see it faster then my b5m with track time here soon. Guess it fits my driving style.
vr6cj is offline   Reply With Quote
Old 03-02-2015, 10:35 PM   #649
STLNLST's Avatar
Trader Rating: 21 (100%+)
Here's a pic I took during my rebuild tonight. The left side is the Bmax2 dog done and the right side is the YZ dog bone. I added rear droop to my car a while back and have been running the Bmax bones since. I finally got around to taking a pic to show where the pins now sit in the out drive. The YZ is too close to the edge for my liking but some may not care. It's personal preference.
REMEMBER THE GOOD OLE DAYS..........THEY'RE NEVER COMING BACK SO WE'RE STUCK WITH THE MESS IN FRONT OF US!!!!
STLNLST is offline   Reply With Quote
Old 03-02-2015, 10:37 PM   #650
STLNLST's Avatar
So you're the one Derek was helping the other day :-)
Old 03-03-2015, 02:38 AM   #651
FLHX1550's Avatar
Originally Posted by WillS View Post
Honestly with the weight of the car as it is, you don't need titanium turnbuckles.
Shock pistons have always been a tuning aid not an upgrade. the car come with 2x1.5, 2x1.6, 2x1.7 with the kit build of 1.6 front and 1.7 rear.
Rear hubs are a tuning aid as well. The flex characteristics change when you run aluminum or plastic. Ask any of the associated guys
My comment was mainly regards to durability. I invested in Ti turnbuckles to not have to worry about a DNF due to broken turnbuckles. And a car in this class should come with Ti turnbuckles.
As far as the rear hubs go, I myself won't run a car with vertical ball stud design with plastic hubs. Just have seen so many DNFs. The plastic B5 hubs have an alum insert that is significantly more stout of a setup, and they are not of the vertical ball stud design. Along with that they use a much larger ball stud and a tie rod end that is more durable also.
On the pistons, a car in this class should come with either machined or much better molded pistons. At least the stock setup pistons should be machined.
JConcepts - TKO - RW Mods - B-Fast - MODX Motors & Batteries - Skare OCD Designs
FLHX1550 is offline   Reply With Quote
Old 03-03-2015, 02:53 AM   #652
FLHX1550's Avatar
I actually never ran the stock bones, and went to the B-Max ones right out of the box. Other than weight, I don't see why they felt they needed to go to a shorter one?
As far as droop, once properly built, this car has a tremendous amount of droop. The most I have seen in a 2wd buggy. And once you get the setup right, the droop will give a major advantage.
This car was one of the most difficult for me to setup, but once I got it close, the car was on the next level. I out qualified the local AE, TLR, and Kyosho hot drivers, all of which are half my age. And I've seen some sell their cars and buy YZs due to my results.
Once dialed in, this car has allot of predictable steering and is increadably stable. I can run a much more aggressive front tire than anyone else, which has my corner speed has higher than anyone else at the track right now.
Old 03-03-2015, 06:24 AM   #653
Suspended
Trader Rating: 61 (100%+)
If the Bmax bones work, Why doesn't someone try the pucks for the Bmax then?
Best Avatar on rc-tech
Socket is offline   Reply With Quote
Old 03-03-2015, 06:33 AM   #654
Racing4Evo's Avatar
Send a message via AIM to Racing4Evo
There are none. MIP hasn't made pucks for any Yokomo, at least not yet.
Racing4Evo is offline   Reply With Quote
Old 03-03-2015, 06:35 AM   #655
Suspended
http://www.amain.com/mip-pucks-shiny...system/p300922
Old 03-03-2015, 06:37 AM   #656
Wildcat1971's Avatar
Trader Rating: 81 (100%+)
pff, besides MIP drivers who uses MIP shiny pucks, lol
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 03-03-2015, 07:03 AM   #657
STLNLST's Avatar
If you build the car to kit specs it doesn't have enough droop IMO. From day one I mentioned lack of droop. My car came alive once drop was added front and rear. There's a reason why guys want to take my car to the Cactus Classic.....lol
Old 03-03-2015, 07:13 AM   #658
STLNLST's Avatar
There are a few running the pucks currently and they work just fine.
Old 03-03-2015, 07:54 AM   #659
vr6cj's Avatar
yes, and droop did help tons. also some small other things we tried but thanks!
Old 03-03-2015, 08:00 AM   #660
STLNLST's Avatar
Glad it helped. Talking to people about droop is like kicking a dead horse. I'll just continue to turn heads and leave them wondering what I'm running.
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
Woulvesbaine
