    Hide Wikipost
Old 10-18-2017, 07:19 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Yokomo YZ-2
Last edit by: Bob Barry
Welcome to the YZ2 Wiki!
If you edit the page, please add your name and date prior to your addition. While an admin can view the history, this makes it easier for everyone to just check updates. We'll put the newest additions at the top
Setup Sheets can be found here
DT CA DTM parts comparison
Print Wikipost
Like Tree105Likes
Old 02-11-2015, 10:20 PM   #496
DaveG28's Avatar
Trader Rating: 64 (100%+)
Originally Posted by Racing4Evo View Post
I have a comparison here. The top arm is from the YZ-2 and it is definitely shorter.
Shorter arms, bigger hex... I know some team guys have tried that on the 4wd but not sure what difference it makes to move the width outboard?
Which de setup set works on the yok's by the way, see in your pic you are using one?
Viper ESC's ~ Xpert Servo's ~ Sanwa Radio
DaveG28 is offline   Reply With Quote
Old 02-11-2015, 10:23 PM   #497
joehundy's Avatar
Trader Rating: 15 (94%+)
Default Cars
I'm back to my bmax 2 MR V3 factory lol mouth full
It's just to me it has way better traction for low-medium bite
My Yz was great but side bite just wasn't there ...if you are on higher grip it's great but for me I couldn't drive it hard at all I just had to cruise.
Thanks to
AmainHobbies/Protek/RB/Upgrade Rc/Jconcepts/Odonnelle fuel
joehundy is offline   Reply With Quote
Old 02-11-2015, 11:36 PM   #498
Racing4Evo's Avatar
Send a message via AIM to Racing4Evo
You can use the set configured for the B5M. I just have two of them with deep hex inserts that I use for the front and rear.
Racing4Evo is offline   Reply With Quote
Old 02-12-2015, 05:37 AM   #499
STLNLST's Avatar
Trader Rating: 21 (100%+)
I run on that exact type of surface and have no problem with side bite. What setup were you running?
REMEMBER THE GOOD OLE DAYS..........THEY'RE NEVER COMING BACK SO WE'RE STUCK WITH THE MESS IN FRONT OF US!!!!
STLNLST is offline   Reply With Quote
Old 02-12-2015, 08:14 AM   #500
WillS's Avatar
Trader Rating: 30 (100%+)
Send a message via MSN to WillS Send a message via Yahoo to WillS
When you put hinge pins in and measure (the proper way), they measure the same length.
Will Smith
Sponsors:
Cheater Racing, Team Powers, Amain.com/Protek, Dialed RC Hobbies/Soar
WillS is offline   Reply With Quote
Old 02-12-2015, 04:54 PM   #501
Ti screw kits are in stock now for the YZ!!!!
http://www.amain.com/protek-rc-yokom...kit-88/p424168
Everyone looses races, few change them......
nitrorush27 is offline   Reply With Quote
Old 02-12-2015, 05:31 PM   #502
vr6cj's Avatar
Trader Rating: 124 (100%+)
so foound one these at Baniza place in Japan. 374 shipped. be here next week.
Excited to try it out. I see the b5 fronts and rears work fine correct?
Anyone working on maybe a carbon chassis?
Avid clutchs fit or got to use the RB6 topshaft still?
vr6cj is offline   Reply With Quote
Old 02-12-2015, 07:43 PM   #503
WillS's Avatar
Car is already underweight in some configurations.
Topshaft is a different tooth count. Heard there is a company already in works for a topshaft to fit Triad/Nova spurs.
Will Smith
Sponsors:
Old 02-12-2015, 09:03 PM   #504
FLHX1550's Avatar
Sorry to call it out, but on Jan 26th when I mentioned in this thread that the YZ will pop driveshafts if one runs it at full droop, and to correct it one can run BMax driveshafts, you had commented that you had measured the distance over the pins and the YZ arm was 2mm shorter and that the configuration wouldn't work. So which is it?
Upon measuring myself, the YZ arm has a center to center distance that is 1.42mm shorter than a BMax-2 Arm. That's comparing a brand new out of the package YZ arm to a new B-Max2 arm.
FYI - I ran the YZ with full droop (plus a little more), with the 62MM driveshafts with no issues using the YZ arms, by the way, and just about TQ'd the first night out with the car.
JConcepts - TKO - RW Mods - B-Fast - MODX Motors & Batteries - Skare OCD Designs
FLHX1550 is offline   Reply With Quote
Old 02-12-2015, 09:26 PM   #505
WillS's Avatar
It is very possible that I grabbed the bmax4-iii arm and measured it by mistake.
Will Smith
Sponsors:
Old 02-12-2015, 09:34 PM   #506
Racing4Evo's Avatar
The two rear arms are definitively different lengths. The older arm from the BMax2 is longer. I'm not sure what you mean by proper measuring method. I can only think of one way to measure length from the inside pin to the outside pin.
Old 02-12-2015, 09:37 PM   #507
WillS's Avatar
Ok Rear arms as measured hinge pin to hinge pin with the calipers I own:
YZ-2: 75.53mm
BMax2: 76.86mm
Bmax4-iii: 76.86mm
These will be the measurements I use for my notes.
EFFECTS OF TRACK-WIDTH ADJUSTMENT
FRONT TRACK-WIDTH
Wider
• Decreases front grip
• Increases understeer
• Slower steering response
• Use to avoid traction rolling
Narrower
• Increases front grip
• Decreases understeer
• Faster steering response
REAR TRACK-WIDTH
Wider
• Increases rear grip at corner entry
• Increases high-speed on-throttle steering
Narrower
• Increases grip at corner exit
• Increases high-speed understeer
Will Smith
Sponsors:
Old 02-12-2015, 09:55 PM   #508
Racing4Evo's Avatar
For future reference. This could be a good tuning option. YZ-2 owners can try the old arms so long as they are mounting the shocks on the rear of the tower.
Old 02-13-2015, 05:52 AM   #509
hollywood3705's Avatar
Your tuning will also have to change by the look of it. The older arms are off set half a hole to the outside compared to the yz-2 arm. So that will have to be taking into account
hollywood3705 is offline   Reply With Quote
Old 02-13-2015, 08:09 AM   #510
Taz_S's Avatar
There is a full write up of parts in the BMax2 thread. Check the first page out, we locate all the information on there so it can be found easily. As of right now the gullwings are only possible until an option for the shock tower allows for the flat arms to be used.
If you notice on Yokomo Europe they now claim the bmax4-iii stock rear arms to be 1mm longer option. They are also optioning the YZ shocks on the bmax4-iii. When the parts get here for the shocks I will be getting them to build up a set for my bmax4 and testing out the improvement that is said to come from them. I really would like to see an option for brass toe blocks. I will just have to wait until Yokomo Europe comes out with them or get a set machined.
Might be some coming out soon. I made sure Rocket RC got a few items that he can work on. I will find out time frame after parts get there.
What would you like to see made?
Outdrives have been sent out to get machined. Lets hope they are reduced to 10-12g a set.
I just hit mip on there facebook page and ask about the 17.5 puck systems. We do not stop email them and ask on facebook. It will take a bit but there get the hint.
Jake's Performance Hobbies http://www.jphracing.com/
https://www.facebook.com/groups/757500284356171 Facebook Group for Pro 10
Taz_S is offline   Reply With Quote
Currently Active Users Viewing This Thread: 5 (4 members and 1 guests)
BK24, Kyosho Kid, tonyd, Y8Duster
