    Hide Wikipost
Old 10-18-2017, 07:19 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Yokomo YZ-2
Last edit by: Bob Barry
Welcome to the YZ2 Wiki!
If you edit the page, please add your name and date prior to your addition. While an admin can view the history, this makes it easier for everyone to just check updates. We'll put the newest additions at the top
Setup Sheets can be found here
DT CA DTM parts comparison
Print Wikipost
Like Tree105Likes
Old 01-26-2015, 09:11 AM   #331
WillS's Avatar
Trader Rating: 30 (100%+)
Send a message via MSN to WillS Send a message via Yahoo to WillS
Originally Posted by FLHX1550 View Post
I think Serpent has a direct drive setup for their car, and several of the locals here running B5s are running the serpent top gear in their mid trans, and I think the Yokomo top shaft and AE top shaft are the same.
The topshafts are not the same. With how tight the stock slipper gets, there is no need at the moment to figure out a mod to run a lockout.
Will Smith
Sponsors:
Cheater Racing, Team Powers, Amain.com/Protek, Dialed RC Hobbies/Soar
WillS is online now   Reply With Quote
Old 01-26-2015, 09:15 AM   #332
WillS's Avatar
Take note, you can't run a full droop setup in the rear running the 60.5mm axles on the YZ-2 or you will pop axles out of the out drive.
I run full droop as much as possible and have switched to BMax2 axles, which are about 3mm longer
Why are you running that much droop? With the 2 limiters in the rear I had more than enough steering for my car. Yokomo is pretty on point with their engineering.
Will Smith
Sponsors:
Old 01-26-2015, 09:25 AM   #333
Trader Rating: 315 (100%+)
Still learning slipper and diff setups. Question is it normal for the slipper to still slip no matter how tight I have it. Using a 69 spur and stock pads, 17.5 Shurspeed motor.
Jermaine Mitchell
I laugh at serious racers acting like B****
Free Agent racing team. No sponsors needed.
Mercenary Racer
jmoneym is offline   Reply With Quote
Old 01-26-2015, 09:44 AM   #334
WillS's Avatar
I currently am running schuurspeeds and have it near bottomed out. You might get your diff for slip as it may not be from your slipper. I found a decent video that will allow for some understanding into diffs/slippers. Watch the video so you can inform yourself of sounds and settings.
Transmission Sounds Video
Will Smith
Sponsors:
Old 01-26-2015, 10:57 AM   #335
Thanks, so on the slipper nut. You have the nut cranked all the way down. I though compressing the spring that much would damage it.
Jermaine Mitchell
Mercenary Racer
Old 01-26-2015, 11:04 AM   #336
Ultraspeed84's Avatar
Trader Rating: 45 (100%+)
Cool im going to try the bmax2 axles on the rear 27.00 for both complete not bad price. But again does any one know what the #1 and #2 shock piston sizes are?
yokomo yz-2
Ultraspeed84 is offline   Reply With Quote
Old 01-26-2015, 11:05 AM   #337
WillS's Avatar
not quite all the way. I tightened but I can still see light in between the coils.
Will Smith
Sponsors:
Old 01-26-2015, 11:08 AM   #338
FLHX1550's Avatar
1 - More droop tends to make a car more forgiving on landings (more down travel)
2 - More droop allows one to get more rebound if running rebound setups
3 - On low grip tracks (the outdoor tracks here are VERY low grip, much lower than anything in the warmer states) more droop can allow for more roll, which can make the difference in going into corner and turning or pushing
I dial change front drop / limiting to help dial in on power steering, but run full droop in the rear almost 100% of the time
JConcepts - TKO - RW Mods - B-Fast - MODX Motors & Batteries - Skare OCD Designs
FLHX1550 is offline   Reply With Quote
Old 01-26-2015, 11:09 AM   #339
FLHX1550's Avatar
I have no interest in running a lock-out, someone previously mentioned they would like to, and thought I would shed some light into what I have seen some of the others locally here are doing with their B5's
Old 01-26-2015, 11:12 AM   #340
big chris's Avatar
Trader Rating: 50 (100%+)
Anybody found any setups that Jorn, Ronnefaulk, or Hara used at Reedy.
B6 Carpet
B6 Clay
B6D dirt
SC5M
big chris is offline   Reply With Quote
Old 01-26-2015, 11:14 AM   #341
fullsyzz's Avatar
Trader Rating: 107 (100%+)
Found this a few pages back.....
Originally Posted by neallewis View Post
Piston 1 = 2x 1.7mm
Piston 2 = 2x 1.6mm
Piston 3 = 2x 1.5mm
kit comes with a pair of each.
3k diff oil supplied. 300/400 CST shock oils. Enough for one fill.
fullsyzz is offline   Reply With Quote
Old 01-26-2015, 11:17 AM   #342
Corrected
Jermaine Mitchell
Mercenary Racer
Old 01-26-2015, 11:18 AM   #343
WillS's Avatar
Here is the Setup I ran for a med bite indoor clay...
Will Smith
Sponsors:
Old 01-26-2015, 12:00 PM   #344
pumpkinfish's Avatar
Here is the setup I currently have on mine. First race weekend is this Saturday so it may change depending on how things go. Race day track conditions will be different than practice!
pumpkinfish is offline   Reply With Quote
Old 01-26-2015, 12:11 PM   #345
WillS's Avatar
Just wondering why your running your ride height so low on a bumpy track?
Will Smith
Sponsors:
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
