    Hide Wikipost
Old 10-18-2017, 07:19 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Yokomo YZ-2
Last edit by: Bob Barry
Welcome to the YZ2 Wiki!
If you edit the page, please add your name and date prior to your addition. While an admin can view the history, this makes it easier for everyone to just check updates. We'll put the newest additions at the top
Setup Sheets can be found here
DT CA DTM parts comparison
Print Wikipost
Like Tree105Likes
Old 01-25-2015, 08:52 PM   #316
Jack Smash's Avatar
Trader Rating: 29 (100%+)
Originally Posted by Arn0 View Post
Values given by Yokomo on the chart are measured, not calculated.
As for unit, check this page (Buggy Big Bore Spring Chart - PDF / XLS), conversion is done.
Thanks for your work on this kind of stuff Arn0. Is the big bore spring chart measured or calculated or both?
Kyosho / Orion / Amain.com / Protek / MIP /
Jack Smash is offline   Reply With Quote
Old 01-25-2015, 09:20 PM   #317
gticlay's Avatar
Saw a kit yesterday - wow, the attention to detail is absolutely amazing. Actually have the lexan body sitting here on the table as I'm going to mail it off for a friend tomorrow.
Thanks to Lunsford, Proline, Schelle, Xray, RCAmerica, and SMC for your support.
gticlay is offline   Reply With Quote
Old 01-25-2015, 09:50 PM   #318
FLHX1550's Avatar
Take note, you can't run a full droop setup in the rear running the 60.5mm axles on the YZ-2 or you will pop axles out of the out drive.
I run full droop as much as possible and have switched to BMax2 axles, which are about 3mm longer
JConcepts - TKO - RW Mods - B-Fast - MODX Motors & Batteries - Skare OCD Designs
FLHX1550 is offline   Reply With Quote
Old 01-25-2015, 10:25 PM   #319
Ultraspeed84's Avatar
Trader Rating: 45 (100%+)
I noticed same thing as i posted back a couple pages most you can get is 27mm from the bottom of the shock body to the shock Eyelet, I ran 26.5 but knowing there is a option to a longer setup I may go that route, But 3mm might be to much does the shaft not bottom out on full in travel?
yokomo yz-2
Ultraspeed84 is offline   Reply With Quote
Old 01-25-2015, 11:00 PM   #320
STLNLST's Avatar
Trader Rating: 21 (100%+)
Originally Posted by jmoneym View Post
Could you share your set up?
Kit set up with the following changes:
FRONT
middle hole on tower
1.6 yokomo piston
32.5wt oil
White Kyosho spring
camber (-1)
Rear
1.6 yokomo piston
30wt oil
white Kyosho spring
camber (-2)
Will be trying the car on medium bite track track next time out.
Comments all day on the corner speed of the car. Driver didn't get it done but the car was there. Rear traction wasn't a problem. I'd like a little more forward bite out of the car but never played with the set up much. AE springs and Kyosho spring were what I tested with today.
REMEMBER THE GOOD OLE DAYS..........THEY'RE NEVER COMING BACK SO WE'RE STUCK WITH THE MESS IN FRONT OF US!!!!
STLNLST is offline   Reply With Quote
Old 01-25-2015, 11:00 PM   #321
Take consideration of droop is changed with position of the different shock mounting. Good question about up travel with the longer axle bottoming out befor the chassi. Take consideration.
jake alton is offline   Reply With Quote
Old 01-25-2015, 11:41 PM   #322
WillS's Avatar
Trader Rating: 30 (100%+)
Send a message via MSN to WillS Send a message via Yahoo to WillS
Thumbs up
Well after a long day of racing, I managed to get some wheel time with my YZ-2. Car felt really good. Was on a top 5 a main run until I got taken out by lapped traffic. Cost me the A but that is part of racing. Ran the B finished 6th after some bobbles was as high as 2nd but that did not last long. Honestly this car felt great and I did not get time to compare to my B-max2 setup.
Things I figured out:
  • Schelle b5 caster spacers fit snug but take out slop that the stock ones have. This provided a more positive and consistent feel. It will be a tight fit, but it will break in.
  • For Clay- Heavier front fluid and springs allow for a smoother transition.
  • Pay attention to the ball diff- make sure to bark test it every round. Also make sure your diff is smooth, if not and your not running a caged bearing buy a tungsten avid set.
  • Buy a b5m foam set, this will allow for more battery adjustments.
Will Smith
Sponsors:
Cheater Racing, Team Powers, Amain.com/Protek, Dialed RC Hobbies/Soar
WillS is offline   Reply With Quote
Old 01-26-2015, 06:38 AM   #323
anthonyjesmond's Avatar
Trader Rating: 87 (100%+)
Not sure if this was covered in the thread already but has anyone fitted a direct spur mount to this car yet? I run stock on a carpet track and I think that would be the ticket if someone makes one that will fit.
Anthony Jesmond
CT
Schumacher KF, KR, Mi5 Evo
Kyosho ZX6, Xray XB4 SCTE Ten 2.0,
Kyosho Scorpion, Monster Beetle
anthonyjesmond is offline   Reply With Quote
Old 01-26-2015, 07:39 AM   #324
LoudOne's Avatar
Trader Rating: 31 (100%+)
Hey all,
I'm thinking of getting one of these. Are the shock bodies aluminum like what's on the Kyosho RB6? Thanks!
LoudOne is offline   Reply With Quote
Old 01-26-2015, 08:03 AM   #325
Trader Rating: 315 (100%+)
Do you guys build shocks with zero rebound?
Jermaine Mitchell
I laugh at serious racers acting like B****
Free Agent racing team. No sponsors needed.
Mercenary Racer
jmoneym is offline   Reply With Quote
Old 01-26-2015, 08:15 AM   #326
WillS's Avatar
Originally Posted by LoudOne View Post
Hey all,
No 2 companies shock bodies are the same due to trade rights. These shocks are extremely smooth and have yet to leak or build air on me.
Will Smith
Sponsors:
Old 01-26-2015, 08:16 AM   #327
303slowdown's Avatar
Trader Rating: 24 (100%+)
Hey all,
Yes they are aluminum. The shocks are very nice .
I do, I've built shocks with rebound before and didn't notice a difference, but the track I run on is pretty smooth and from what I've read rebound is for bumpy tracks to help keep the tire in contact with the ground.
Ryan Borgheiinck
303slowdown is offline   Reply With Quote
Old 01-26-2015, 08:44 AM   #328
FLHX1550's Avatar
No problems with the longer axles bottoming out in the outdrives. No bind anywhere actually.
The diff itself and outdrives are the same as the B-Max2, arms are the same length, and the hubs / bearings are in the same spot.
With no limiters in the rear shocks, with the top of the shock mounted in the middle hole on the tower and the inner hole on the arm (shocks mounted on the front of the arm / tower) and it would pop-out. Using the inside hole on the tower may have eliminated it, but I want to be able to mount the shocks in every position and not worry about it. Heck, on the B-Max I had run as much as 2 turns out on the shock ends with no issues.
Good news is that you can get just the dogbone for about $7ea and not have to ditch the entire axle setup.
Old 01-26-2015, 08:46 AM   #329
FLHX1550's Avatar
I think Serpent has a direct drive setup for their car, and several of the locals here running B5s are running the serpent top gear in their mid trans, and I think the Yokomo top shaft and AE top shaft are the same.
Old 01-26-2015, 09:07 AM   #330
WillS's Avatar
The Arms and bearing position are not the same. The arms are shorter by a few millimeters. This was last checked with a pair of calipers and hinge pins installed inner and outer.
Will Smith
Sponsors:
Currently Active Users Viewing This Thread: 5 (1 members and 4 guests)
Motorman007
