    Hide Wikipost
Old 08-10-2017, 01:11 PM   -   Wikipost
R/C Tech Forums Thread Wiki: Yokomo YZ-2
Last edit by: Bob Barry
Welcome to the YZ2 Wiki!
If you edit the page, please add your name and date prior to your addition. While an admin can view the history, this makes it easier for everyone to just check updates. We'll put the newest additions at the top
Setup Sheets can be found here
Print Wikipost
Like Tree43Likes
Old 01-25-2017, 07:17 AM   #2671
Ray Kindstrom's Avatar
Trader Rating: 147 (100%+)
Looking around for a CA if any of you fellas have one your thinking of selling. Please feel free to send me a message. Thanks!
Ray Kindstrom is offline   Reply With Quote
Old 01-25-2017, 06:37 PM   #2672
Trader Rating: 30 (100%+)
Ray also try posting on Yokomo YZ2/YZ4 Facebook page.
Norse is offline   Reply With Quote
Old 01-25-2017, 06:50 PM   #2673
Trader Rating: 19 (100%+)
Why does maifield run TLR and AE parts on his yokomo?
Coke in a can is offline   Reply With Quote
Old 01-25-2017, 08:04 PM   #2674
Trader Rating: 16 (100%+)
Yokomo ball cups are terrible, so that explains the AE parts swap. The TLR 22-4 2.0 hubs I'm not sure. It has to be some sort of geometry change. Either relating to drive shaft geometry or suspension geometry.
MX304 is offline   Reply With Quote
Old 01-25-2017, 08:40 PM   #2675
We were using the white yokomo rather than black ballcups on carpet. They seem to be made from a much more durable plastic like delrin.
zzztech is offline   Reply With Quote
Old 01-25-2017, 08:59 PM   #2676
So that's what those are. I saw pics of one of the Yokomo cars at the reedy with them and wondered what they were.
Old 01-25-2017, 10:20 PM   #2677
Originally Posted by rbk1115 View Post
For the laydown transmission, you will need:
CA Transmission Case
CA Idler Gear
CA Motor Plate
CA Rear Shock Tower
CA Battery Strap
CA Waterfall
CA Rear Arms aka "S4 Arms" (Z4-008RS4)
CA Rear Wing Mounts
CA Shock Tower Spacer
CA Rear Upper Arm Mount
CA Dog Bones (B2-010R)
The arms and dog bones are not necessary. Unless you are trying to.go full CA.instead of DT
KW Raceway https://m.facebook.com/kwraceway
Mugen Seiki/Yokomo Usa/Protek/Amain/R1 Wurks/Flashpoint/KW Raceway
robbie_gtc is offline   Reply With Quote
Old 01-26-2017, 08:43 AM   #2678
Would you be able to quantify why the Yokomo ball cups are terrible? The only issue I had with mine are that they can bend/disfigure. Using longer turnbuckles solves that problem. Other than that, they have never popped off and remain tight.
Yokomo YZ-2
Yokomo YZ-4
Fantom | Lunsford | MurfDogg | Pro-Line | R1 | Racing Performer | Sanwa | Schelle | Tekin | TLR
rbk1115 is offline   Reply With Quote
Old 01-26-2017, 08:50 AM   #2679
Lots of guys have had issues with them breaking and popping off more than other brands.
Old 01-26-2017, 08:54 AM   #2680
Interesting... Maybe I am lucky.
On the flip side, some of the AE guys at my local track complain about the B5/B6 ball cups and how they get a lot play in a short amount of time. I should give them some of the Yokomo ball cups to try...
Yokomo YZ-2
Yokomo YZ-4
Old 01-26-2017, 09:04 AM   #2681
Yokomo ball cups are not terrible. Actually the have a great snug smooth fit. Guys we're replacing them as they had a tendency to bend thus over flex in hotter environments. Thus was the main reason causing some to switch to AE HD cups, and some will just use longer turnbuckles and lots of pep's stick with the stock cups as they do have promblems.
Old 01-26-2017, 09:08 AM   #2682
RBK1115 is spot on correct. The Yok ball cups are some of the snuggest fitting while being super smooth and last a long time. Heat is the issue combined with the turnbuckle length. Longer turnbuckles resolves the issue with over flex due to heat.
Old 01-26-2017, 10:44 AM   #2683
It is interesting to see other manufacturer parts on the Yokomo platform. RM is a fully sponsored driver by Yokomo. I wonder if Yokomo is a little bit more relaxed when compared to other brands when it comes to sponsored drivers running other manufacturer parts on the cars they are supposed to promote/represent. I have never seen AE, Kyohso, or TLR drivers "cross the streams"...
Yokomo YZ-2
Yokomo YZ-4
Old 01-26-2017, 10:47 AM   #2684
Agree on this!
For my YZ2 CA/DT setup, here are the turnbuckle lengths I am using:
Front Camber Link: 64mm
Steering Link: 52mm
Rear Camber Link: 62mm
Yokomo YZ-2
Yokomo YZ-4
Old 01-26-2017, 11:00 AM   #2685
Agree on this!
Steering Link: 52mm
Nice! I essentially did the same as you. I picked up some purple Schuey Titanium TB's for dirt cheap 60mm which I trimmed down the steering TB to 52mm the front and rear camber I left the TB's at 60mm. Bought 3 pairs new for $12
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
