Yokomo YZ-2
#2656
#2658
Looking into buying a new yz-2 dirt edition to get back into the hobby. Want to break up the monotony of a B6D. What are the mandatory upgrades while building other than the shock pistons and tie rods?
#2659
Welcome to Yokomo!
#2660
I noticed the hubs are plastic, no issues with ball studs tearing out? Thanks!
#2661
No need for hop ups really. However I do like the rear aluminum ball stud mount as well as the front aluminum one. I've never broken one but I have seen others do it.
In regard to the rear hubs. Use M3 grub screws to fill in any holes you're not using to strengthen the part.
#2662
The track isn't open yet but I was told the local pros who have been on it have been running stand up. Is this car convertible to laydown?
#2663
#2664
Yikes, the aluminum hop ups are pricey but it's all relative I suppose. Is there anything else I should buy or is most of it just bling? Or rather, has anyone else broken anything or found they should have upgraded something from the start? What parts break most often? Are shock towers an issue like the b6?
#2665
Other that what you have listed, you are good to go. The car is race worthy out of the box. No need for aftermarket hop
ups like another brand you might be familiar with. No need to send it to Exotek, JC, MIP, etc. to create an episode of "Pimp My RC"...
Welcome to Yokomo!
Welcome to Yokomo!
Enjoy it! Yokomo stuff is top notch and tons of setup sheets out there to get you started.
#2666
The recently released rear hub kit is pretty nice as well and so is the rear camber block. The car had more grip with the updated hubs. This hub kit from Yokomo does what the AE guys are currently piecing together for their rear hub mod (~67mm TLR dog bone, bore out hub so that the bearing is over the hinge pin, etc. I felt that the car had more grip after installing the hub kit. However, you will need to use the YZ-2 CA/YZ-4 rear arms for the kit.
#2667
What was Maifield running at Reedy? Any special setup? Always read he laydown had traction issues and needed a lot of setup help for medium bite. Didn't look like it
I've been running 17.5 in the YZ-2 since June 2016 and have yet to break a part. The kit comes with most of the aluminum parts you will need. The rest are really clean looking bling. Also, if you get the CA kit, it comes with the aluminum front camber mount. The DT comes with a plastic front camber mount that has different dimensions. I bought both kits so it was interesting to see the differences between the two.
The recently released new kit is pretty nice as well as the rear camber block. The car had more grip with the updated hubs. This hub kit from Yokomo does what the AE guys are currently piecing together for their rear hub mod (~67mm TLR dog bone, bore out hub so that the bearing is over the hinge pin, etc. I felt that the car had more grip after installing the hub kit. However, you will need to use the YZ-2 CA/YZ-4 rear arms for the kit.
#2668
CA Transmission Case
CA Idler Gear
CA Motor Plate
CA Rear Shock Tower
CA Battery Strap
CA Waterfall
CA Rear Arms aka "S4 Arms" (Z4-008RS4)
CA Rear Wing Mounts
CA Shock Tower Spacer
CA Rear Upper Arm Mount
CA Dog Bones (B2-010R)
#2669
It appeared that he was running the CA, but had some prototype parts to use the DT rear camber mount and a brace against the rear tower. He also appeared to be using the DT steering plates. Other than these items, the car was a CA.
#2670
I have had no issues with my shock towers breaking.
