    Hide Wikipost
Old 08-10-2017, 01:11 PM   -   Wikipost
R/C Tech Forums Thread Wiki: Yokomo YZ-2
Last edit by: Bob Barry
Welcome to the YZ2 Wiki!
If you edit the page, please add your name and date prior to your addition. While an admin can view the history, this makes it easier for everyone to just check updates. We'll put the newest additions at the top
Setup Sheets can be found here
Print Wikipost
Like Tree39Likes
Old 01-20-2017, 11:00 PM   #2626
gokarter64's Avatar
Anyone have any wheelbase measurements for the yz2 at its minimum and maximum wheelbase. Im trying to make a stadium truck conversion and i need to figure out how much i need to add to the chassis to get the correct wheelbase. Ballpark estimates put me at about 50-60mm. Then from there all i need to do is get my hands on a set of xt2 towers so i can grab the hole locations and build some new shock towers. From there you should be able to bolt on towers, chassis, xt2 arms and truck shocks of your choice and have a pretty sweet truck. It would be too expensive for me to produce them so my grand plan is to put out free cad files for everyone so they can build their own.
gokarter64 is offline   Reply With Quote
Old 01-20-2017, 11:04 PM   #2627
Originally Posted by josh18_2k View Post
Please elaborate. Is there a parts list? I've never seen a rear bar mounted to aluminum rear mount.
I have one on my yz4 which uses the same alum rear bulkhead as the CA.
KW Raceway https://m.facebook.com/kwraceway
Mugen Seiki/Yokomo Usa/Protek/Amain/R1 Wurks/Flashpoint/KW Raceway
robbie_gtc is offline   Reply With Quote
Old 01-21-2017, 07:29 AM   #2628
draboyd19's Avatar
Trader Rating: 19 (100%+)
Originally Posted by MX304 View Post
Can the 4 gear trans from the original yz-2 be used in the new DT edition?
No reason it can't, but you will need the waterfall brace from an original or CA, along with the wing mounts, rear shock tower, and camber brace.
draboyd19 is offline   Reply With Quote
Old 01-21-2017, 07:32 AM   #2629
draboyd19's Avatar
Good to know - honestly first time I had seen a rear swaybar used with the aluminum stuff.
Josh - I have the plastic turnbuckles and plastic clips if you are looking to piece this together, but I don't have metal ball holders and swaybars. My guess is you will buy the whole kit, but if you just needed a few parts I could help you out.
Good luck.
Old 01-21-2017, 07:44 AM   #2630
draboyd19's Avatar
My orginal YZ-2 is as follows:
Front to Rear (center of axle to center to axle) - 279mm
Front wheelbase (center outer hinge pin to center of outer hingepin) - 184mm
Rear wheelbase (center outer hinge pin to center of outer hingepin) - 182.5mm
If you need something more specific let me know, and I can try and measure as needed.
Good luck.
Old 01-21-2017, 12:20 PM   #2631
The part numbers are
Z2-412F for front roll bar
Z4-412 for the rear roll bar (and it fits the ali block)
MattPR8 is offline   Reply With Quote
Old 01-21-2017, 10:14 PM   #2632
i have the YZ4 sway bar kit, but it doesn't come with parts to mount to the Al bulkhead. What are the mounting parts?
josh18_2k is offline   Reply With Quote
Old 01-21-2017, 10:43 PM   #2633
YOKB7-204
https://www.amainhobbies.com/yokomo-...b7-204/p242247
Old 01-22-2017, 07:27 AM   #2634
What are the part numbers for the 2x1.6 and 2x1.7 machined shock pistons?
Thanks!
M.Boos is offline   Reply With Quote
Old 01-22-2017, 10:10 AM   #2635
JimmyMac's Avatar
Thanks!
http://www.fast-webshop.com/tonispor...m-2-Hole-Black
http://www.fast-webshop.com/tonispor...m-2-Hole-White
M.J. McIntyre
Yokomo YRX12
Yokomo YZ-2 DT/CA
JimmyMac is offline   Reply With Quote
Old 01-22-2017, 02:26 PM   #2636
Regional Moderator
RobsRacin's Avatar
I know we were talking about Mobisport before, do you guys know if US buyers have to pay the VAT taxes?
RobsRacin is offline   Reply With Quote
Old 01-22-2017, 03:28 PM   #2637
And how popular is a front sway bar on dirt please for the original
jagman1 is offline   Reply With Quote
Old 01-22-2017, 04:46 PM   #2638
JimmyMac's Avatar
You don't have to pay VAT from Mibosport or Tonisport. All you have to do is send them an email with the items you want and tell them you are from the USA. I usually just put all the items I want into the shopping cart, then copy/cut/pasted that into an email. Pretty simple and easy with fast 2-3 day shipping. I've ordered stuff Monday morning and got it on Wednesday. Excellent service.
M.J. McIntyre
Yokomo YRX12
Yokomo YZ-2 DT/CA
Old 01-22-2017, 04:57 PM   #2639
Regional Moderator
RobsRacin's Avatar
Wow that is incredible. Thank you for the info sir!
Old 01-22-2017, 06:04 PM   #2640
JimmyMac's Avatar
No problem. Of course I try to support Amain, but they don't always have stock of what I want. So gotta reach out to other sources. Mibo and Toni are the first ones I go to.
M.J. McIntyre
Yokomo YRX12
Yokomo YZ-2 DT/CA
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
