    Hide Wikipost
Old 08-10-2017, 01:11 PM   -   Wikipost
R/C Tech Forums Thread Wiki: Yokomo YZ-2
Last edit by: Bob Barry
Welcome to the YZ2 Wiki!
If you edit the page, please add your name and date prior to your addition. While an admin can view the history, this makes it easier for everyone to just check updates. We'll put the newest additions at the top
Setup Sheets can be found here
Print Wikipost
Like Tree63Likes
Old 01-18-2017, 08:31 AM   #2611
Potoczak's Avatar
Trader Rating: 111 (100%+)
Going to be buying a yz2 ca for carpet racing. What parts or hopups should I get while ordering the kit?? Thanks.
Pete Potoczak
Home entertainment specialist
Secure Technologies/ www.stiworldwide.com
Potoczak is offline   Reply With Quote
Old 01-18-2017, 09:22 AM   #2612
draboyd19's Avatar
Trader Rating: 19 (100%+)
You really don't need much at with all the aluminum and carbon parts that cone with it.
If you don't run a sway bar you can try an aluminium rear camber brace. Only other thing you might consider is the aluminum hubs. If you stick with plastic just put set screws in unused holes to give it more strength.
draboyd19 is offline   Reply With Quote
Old 01-18-2017, 12:38 PM   #2613
Swaybars and under battery-weights. And machined pistons, 2x1,7 rear and 2x1,6 front. Maybe some yatabe springs to play around with. I also like the Yokomo alu front wing mount, but it's expensive.
matterooth is offline   Reply With Quote
Old 01-18-2017, 01:21 PM   #2614
draboyd19's Avatar
+1....totally forgot the kit comes with molded shock pistons....definitely get some machined ones. There are good setup sheets out there with AE, kyosho, Yatabe, and even avid springs, so pick your preference there and get you a few to play with.
Good luck.
Old 01-18-2017, 01:58 PM   #2615
the incubus's Avatar
Trader Rating: 17 (100%+)
Originally Posted by jagman1 View Post
Well it arrived today awesome looking car yz2 original, I just want to push the suspension up and down and roll it on the work bench, yeah you know, after examining the rear weight addition of the incubus how about running the two steel rear hangers to pull the weight bias back, I have a rear front that came with the car, yes med grip dirt, I have been admiring these cars for a while, I might just got push it along the lounge floor.
I ordered both those pasts but since I've not been able to race in over 4 months they are still in my toolbox waiting to be installed. They feel about the same as the weight I installed so I imagine it will have a similar if not identical effect on my car's handling.
ROB RIVERA
≈ PRS1 2014 :: SP Reventon Pro 1.1 :: Team Powers Plutonium17.5 ≈
≈ DEX410 :: SP Reventon Pro 1.1 :: Reedy Sonic 6.5T ≈
WWW.TRICOUNTYHOBBIES.COM :: WWW.CRPPLUS.COM
the incubus is offline   Reply With Quote
Old 01-18-2017, 05:35 PM   #2616
You can run sway bars with rear alum bulkhead as well.
KW Raceway https://m.facebook.com/kwraceway
Mugen Seiki/Yokomo Usa/Protek/Amain/R1 Wurks/Flashpoint/KW Raceway
robbie_gtc is offline   Reply With Quote
Old 01-18-2017, 06:22 PM   #2617
Thanks incubus, does someone know if the aluminum rear upper arm mount off the dirt fits the original i see they are shaped different but the dirt one is less than half price.
jagman1 is offline   Reply With Quote
Old 01-18-2017, 07:46 PM   #2618
OriginalDonk's Avatar
Trader Rating: 41 (100%+)
The DT aluminum rear camber link doesn't fit the original. Looks like Maifield may be running the DT version on his CA which has a similar rear end to the original with a yet to be released spacer of some sort.
So the answer is no, not right now, but maybe soon.
OriginalDonk is offline   Reply With Quote
Old 01-19-2017, 05:30 AM   #2619
So thinking about getting back into this again, with a buggy this time, since my last foray into short course truck racing wasn't great. Had a lot of radio problems to start, and well, never was that great of a truck racer anyways.
Question is, what is the main difference between the yz-2 and yz-2 ca? My plan is to find a used yz-2 to run, to save on the cost a bit to get back into it. Does the CA seriously outmatch the original? Can the original be "made" into a CA? Or is it just not worth the $$ spent to do so?
{tpc} is offline   Reply With Quote
Old 01-19-2017, 10:38 AM   #2620
draboyd19's Avatar
Save some money and get a nice used original. If you decide you want to get the 3 gears laydown trans the kit is $30. Outside of the transmission and idler gear the cars are basically the same thing. The cva driveshaft and rear arms are longer on the CA but you can swap those later if you want, and as a you are getting back into it you are not going to notice that difference right away.
Others may disagree but you will be fine to start with an original.
Old 01-19-2017, 10:43 AM   #2621
^This is good advice. Lots of nice used YZ-2's around. If you pick up a 3 gear transmission you can try both out and see what you like. A lot of people are clamoring for the 3 gear but Jared Tebo over at Kyosho only runs 4 gear. He says he loses braking power with the 3 gear.
I feel both setups have their place based on track conditions. All based on preference but it will be interesting for you to see the difference since you're getting back into things.
Old 01-20-2017, 06:25 AM   #2622
Thanks for the info. I have a couple lines in the water so to speak on a yz-2. Also have some interest in a b6, but just waiting to hear back from folks so far.
Old 01-20-2017, 06:33 AM   #2623
motorfinger's Avatar
Trader Rating: 16 (100%+)
Send a message via Yahoo to motorfinger
If anyone is interested, I have a YZ2 DT for sale. Has had a handful of races on it outside. Has B6 ball cups and Lunsford super duty tie rods. Steel front suspension hanger, longer dog bones, slipper eliminator and 2 bodies. One custom painted by Darkside. PM for more info.
motorfinger is offline   Reply With Quote
Old 01-20-2017, 06:57 PM   #2624
Can the 4 gear trans from the original yz-2 be used in the new DT edition?
MX304 is offline   Reply With Quote
Old 01-20-2017, 07:11 PM   #2625
Please elaborate. Is there a parts list? I've never seen a rear bar mounted to aluminum rear mount.
josh18_2k is offline   Reply With Quote
