Like Tree485Likes
Yokomo YZ-2
    Hide Wikipost
Old 11-11-2021, 01:35 AM   -   Wikipost
R/C Tech ForumsThread Wiki: Yokomo YZ-2
Last edit by: lexusbest
Welcome to the YZ2 Wiki!
Features for the lastest specification YZ-2DTM3.1
  • Long specification for dirt Main chassis Inheriting the chassis cut of dirt specification, it is longer with the same wheelbase as CAL3.
  • Aluminum front suspension mount.
  • Z2-DTM2B F2 body.
  • JConcepts ASTRO High Clearance 7inch Wing.
Features for the lastest specification YZ-2CAL3.1
  • Long specification main chassis for carpets. Long wheelbase that enables even higher speeds.
  • Steel front suspension mount.
  • Z2-DTMBL S2 Lightweight body.
  • Z2-CAL2W LMR Wing.
Common features for the lastest specification YZ-2DTM3.1 / YZ-2CAL3.1
  • The conventional position and the position of the suspension arm pin 1 mm higher can be selected on the front and back of the front suspension mount.
  • Bulkhead integrated side plate with increased rigidity.
  • The kingpin position has been changed with the new steering hub carrier, the axle position has been lengthened by 1 mm, and a steering stopper has also been added.
  • Battery holder that is easy to adjust according to the height of the battery.
  • Separate the rear mount base and upper arm holder to increase the flex around the rear and improve traction.
  • Z2-018-5 5-hole shock mounting specification Rear shock tower.
  • S4-S1S 3.0mm shaft specification front shock.
  • S4-S1M 3.0mm shaft specification rear short shock.
  • S4-008R5B L5 / LD Rear suspension arm (Φ3.5 pin).
  • Z2-01069 Rear universal shaft (69mm bone).
Setup Sheets can be found here
DT CA DTM parts comparison
YZ2T Tranny Conversion List
YOKZ2-300RFT
YOKZ2-302CT
YOKZ2-302T
YOKZ2-304T
YOKZ2-503I
YOKZ2-0023
CAL3 manual
DTM3 manual
Print Wikipost
Old 11-26-2016, 07:35 PM
  #2506
Trader Rating: 25 (100%+)
Originally Posted by HeavyD99
Update! The TLR aluminum horn did not work because it is too short, so full throw left to right was not possible. Threw the stock horn back on, using a slight 3mm gap, it all works nicely and nothing hits the bulkhead. Full throw both sides. The horn is still off centre but not as drastically as per the manual. I'd like to get an aluminum horn however, something in the 21-22mm centre to centre is needed.
Gotta use the 22-4 horn. I've been using it for months, no issues
kerby is offline
Old 11-29-2016, 03:25 AM
  #2507
Can you put a mip pucks in the Yokomo yz2 ca ?
Deerek761 is offline
Old 11-29-2016, 06:49 AM
  #2508
MIP does not make an official puck kit for the YZ-2. I am sure you can take measurements and use parts from other puck kits to create a custom one that fits. After switching to Yokomo from AE, I stayed away from the puck kits and don't miss it at all. I never had any issues with the OEM Yokomo parts.
MIP also dropped support for Kyosho so I am back to OEM parts for my SCT as well.
rbk1115 is offline
Old 11-29-2016, 10:34 AM
  #2509
Team Tekin
Randy_Pike's Avatar
The Shiny MIP pucks from the Bmax2 fit just fine.
Randy_Pike is offline
Old 12-11-2016, 04:03 AM
  #2510
Anyone running 17.5 stock buggy on astroturf?
rippen is offline
Old 12-12-2016, 11:49 AM
  #2511
twindad98's Avatar
Trader Rating: 20 (100%+)
I have a DT for sale if anyone is looking for one.
twindad98 is offline
Old 12-12-2016, 12:03 PM
  #2512
PM me if you have spare parts for sale.
Mcgurik is offline
Old 12-13-2016, 04:03 AM
  #2513
Yes!
Have a look at Shin adashi setup.
Tires:Schumacher yellow
varikoz is offline
Old 12-14-2016, 12:21 AM
  #2514
gokarter64's Avatar
Default Taking the plunge
Im finally doing it. Im buying two yz2 buggys after getting fed up with the 22 3.0. I race on carpet, bumpy astro, and high grip clay and there are b6 and rb6.6 buggys everywhere. So should i buy two carpet editions and get dirt parts (minus the gearbox as laydown is dominant on our clay) or two dirt editions and get carpet parts. The carpet kits look like they have a little more value in the box to me.
Another question i have is are there any lightweight drivetrain parts avaliable for the yz2? i usuually run aluminum topshafts, outdrives, and dogbones on my stock buggys in order to get the max power i can from my motor...
gokarter64 is offline
Old 12-17-2016, 09:30 AM
  #2515
I can't find the 48mm turnbuckles for the rear for sale anywhere. Do people just use the 52mm turnbuckles?
Mcgurik is offline
Old 12-17-2016, 03:37 PM
  #2516
Does anyone know if they yz2 uses the same trans idler gear as a b5 or b6?
turtle189 is offline
Old 12-17-2016, 03:58 PM
  #2517
Amain hobby
https://www.amainhobbies.com/yokomo-...-tb48a/p481808
rippen is offline
Old 12-17-2016, 06:27 PM
  #2518
Yeah I saw those but I wasn't looking to buy the ti ones.
Mcgurik is offline
Old 12-17-2016, 09:11 PM
  #2519
Trader Rating: 21 (100%+)
Will the CA edition take a square pack, or is it shorty only?
MX304 is offline
Old 12-18-2016, 03:26 AM
  #2520
Trader Rating: 43 (100%+)
52mm are just fine my friend.
Norse is offline
