    Hide Wikipost
Old 08-10-2017, 01:11 PM   -   Wikipost
R/C Tech Forums Thread Wiki: Yokomo YZ-2
Last edit by: Bob Barry
Welcome to the YZ2 Wiki!
If you edit the page, please add your name and date prior to your addition. While an admin can view the history, this makes it easier for everyone to just check updates. We'll put the newest additions at the top
Setup Sheets can be found here
Print Wikipost
Like Tree42Likes
Old 11-15-2016, 10:12 AM   #2491
Moderator
MarkA's Avatar
Trader Rating: 21 (100%+)
Originally Posted by HeavyD99 View Post
I am going to try a TLR aluminum horn for the 22. It seems to have a similar off set tot the OEM Yokomo plastic horn. I had to drill and tap it for the 3mm ball stud however. I also ordered a 20mm Kyosho turnbuckle from AMain I plan to use between the ball cups. The manual says to screw the cups together but I don't like the angle of the servo like that, I like th servo to point straight up for straight ahead wheels. I plan to add 5mm of a gap with the new turnbuckle and the cups.
If the horn is straight up for straight ahead wheels, it will almost certainly hit the bulkhead on the rh side of the car before you achieve full left-steering throw unless you've altered the geometry in some other way as well.
Originally Posted by YellowClip View Post
The original Yokomo horn puts the servo link at a such big angle, which in my opinion makes the steering uneffective.
They didn't arrive at the steering rack/servo mounting setup via amateur internet engineering - the steering works very well built the way it was meant to be.
I don't want to sound harsh but I've seen many attempts in-person by people to "fix" the optics of a steering setup that just "doesn't look right" and haven't seen one yet that didn't leave them with a car that then doesn't even turn the same left and right.
MarkA is offline   Reply With Quote
Old 11-15-2016, 05:26 PM   #2492
What servo arms do you use on your buggies?
I use the stock supplied servo horn on a savox 1258 with no issues. Angle looks funky but works nice and smooth.
RB6.6/YZ-2 DT/'17 XB2 CE
YZ-4/B64D/22-4 2.0/D413
YMMV is offline   Reply With Quote
Old 11-15-2016, 05:27 PM   #2493
Trader Rating: 15 (100%+)
I got the idea by looking at pics of Lee Martin and Marc Reinhards EOS buggies. Maybe you're right and straight up and straight wheels won't work, I'll prove it to myself one way or another this evening
Daragh Slowey
22-4 2.0/R10/Scorpion5.5/S6040/Nosram shorty
B5R/R10/LRP8.5/1258TGBlk/Nosram shorty
EB48SL/RX8/TekinT8i/Hitec7599/SMC4500(4S)
Grasshopper/Tekin FX/Twister 27T/FutabaS9551/Speed power
HeavyD99 is offline   Reply With Quote
Old 11-15-2016, 10:14 PM   #2494
Moderator
MarkA's Avatar
I should have clarified that you can go to a gap of a max of about 2.5mm on the servo rod before it jams the bulkhead ala Rienhard if it helps with some servos in evening out your endpoints but even then, you'll note the horn not straight. If you get it to work with a 5mm gap, let us know!
Old 11-16-2016, 10:14 AM   #2495
Update! The TLR aluminum horn did not work because it is too short, so full throw left to right was not possible. Threw the stock horn back on, using a slight 3mm gap, it all works nicely and nothing hits the bulkhead. Full throw both sides. The horn is still off centre but not as drastically as per the manual. I'd like to get an aluminum horn however, something in the 21-22mm centre to centre is needed.
Daragh Slowey
Old 11-16-2016, 12:23 PM   #2496
MHeyne39's Avatar
What are some "must have" upgrades for the YZ-2 CA?
Mugen Seiki Racing, RawSpeed RC, Maclan, Xpert, Lunsford, MIP, VRP, VooDoo Racing Cells, Leadfinger Racing, 92ZeroDesigns,
MHeyne39 is offline   Reply With Quote
Old 11-16-2016, 02:03 PM   #2497
Moderator
MarkA's Avatar
Machined shock pistons; possibly the under battery weights. Otherwise, the car comes with a B6-sized bag of aluminum parts in the box already...
Old 11-16-2016, 06:17 PM   #2498
MHeyne39's Avatar
I have the weights already. just need to add VRP Pistons
Old 11-17-2016, 08:35 PM   #2499
I just build a DT edition. Still all stock setup. Which piston best matches the stock ones? I was curious about tapered ones as well.
Mcgurik is offline   Reply With Quote
Old 11-17-2016, 11:06 PM   #2500
Front: Yokomo BM-S162
Rear: Yokomo BM-S172
Yokomo OEM FTW!
Yokomo YZ-2
Yokomo YZ-4
Fantom | Lunsford | MurfDogg | Pro-Line | R1 | Racing Performer | Sanwa | Schelle | Tekin | TLR
rbk1115 is offline   Reply With Quote
Old 11-18-2016, 07:15 AM   #2501
For my yokomo i mont this optional:
Z2-300FLB5;Z2-008GFG;Z2-017G;Z2-107F;Z2-110;Z2-203A;Z2-412F + REAR BAR; Z2-413A; Z2-415GS; Z2-415RS; Z4-008RS4; Z2-670V; Z2-RW52 + 80G under battery;Z2-S2LD;Z2-S2SD;B4-011F;BM-S162; BM-S172; SD-008RC; YS-8BH; ZC-N4FLT; SPRING YATABE ARENA.
i should have put them all.
Facciohgt is offline   Reply With Quote
Old 11-24-2016, 08:46 AM   #2502
Regional Moderator
RobsRacin's Avatar
What kind of spares would you guys purchase? Hobby shop doesn't really want to stock parts since yokomo isnt big there.
RobsRacin is offline   Reply With Quote
Old 11-25-2016, 02:32 PM   #2503
KrAcOn's Avatar
Like most cars you want a set of front and rear arms. This car doesn't break too often but I did bend allot of from tie rods on the first Yz-2.
AE:RC10B5ML,B5M,B4.2,B44.3,B3,RC10TeamRPM,Rc10T,RC10B64D
Yokomo:YZ-2 LD,YZ-2 DT,YZ-4 and MX4
LRH RACEWAY So. Cal
KrAcOn is offline   Reply With Quote
Old 11-26-2016, 01:18 AM   #2504
Arms, ballcups and front bulkhead.
matterooth is offline   Reply With Quote
Old 11-26-2016, 04:00 AM   #2505
Do you use the OEM ballcups?
